Question about HP 22" Widescreen Flat Panel TFT LCD HD Monitor
The monitor goes off after three minutes - HP 22" Widescreen Flat Panel TFT LCD HD Monitor
    Genius:
  • 1,622 Answers
You can make it work by yourself,having a basic knowledge will be an east in rectifying the fault.
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where.
Hope this help in solving the problem,Take care
Posted on Sep 14, 2010
My acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
my acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
Nov 27, 2010 | Acer AL1711 17" LCD Monitor
Monitor starts, about three minutes no picture but
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after few seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 07, 2010 | Proview PL926WBi 19" LCD Monitor
Screen appears on for three seconds then goes black
Try the monitor on another computer that you know works, If it works on another computer then that means you have no video output on the original computer and you'll need to reseat the memory on that computer.
If you get the same response on another computer, then that means the monitor is bad and you'll need to replace it.
Apr 19, 2010 | Samsung Syncmaster 2033SW Monitor
My monitor goes into power saving mode all the time!
Three years old will more likely to hav bad caps by now, common problem on ALL brands, see example of failed monitors due to bad caps, you need to open it up and see, http://s807.photobucket.com/home/budm/allalbums
Feb 13, 2010 | Computers & Internet
When turned on, monitor power light comes on for a moment and then goes out. Monitor eventually comes on after several minutes. The same happens if the monitor is left on but goes into sleep mode.
This is a common problem on these monitors. There are three or four capacitors in the power supply, three on the inverter board and anywhere from 2 to 6 on the main board that go bad.
The number on the main board depends on how long the monitor has been having problems before it was serviced. The longer the wait, the more capacitors will have gone bad.
The power and inverter boards are easy to repair, the main board is not. As mentioned, it is a multi layer board so removing the old capacitors and the old solder can be troublesome. I would suggest you have someone experienced at soldering repair the main board.
Btw, our shop would charge $60 labour plus $2 for each capacitor.
Dec 18, 2009 | ViewSonic VP2030b 20.1" LCD Monitor
My new monitor turns on then goes blank after a few seconds.
It sounds like a power issue OR weak signal. If you use an extension cable on your monitor cable this can couse the problem.
Nov 29, 2008 | Computers & Internet
Acer Monitor will not function
Monitor is getting hot and cutting off. Try on another computer. Try another video card. If it does the same thing then it is BAD
May 24, 2008 | Gateway FPD2275W LCD Monitor
Medion monitor
There might be a problem with the cable where u connect with the pc. if not so then u need to open the monitor on the yok of the pictiure tube there are three transistors ( three leged IC )wg\hich might be dry soldered or might be damaged. just change all three of them will not cost u more than 100 rs or more at home. 100% guarantee to work.
Aug 28, 2007 | Computers & Internet
HP 22" Widescreen Flat Panel TFT LCD HD Monitor Logo
46 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
