Question about Buck Ford Econline Van 1998-2006 Stereo Radio Wiring Harness
The radio will not turn on in my 52 reg ford transit
  • xxxxxx xxx Sep 14, 2010
    Does it require a code?
    If you do NOT have the code , remove the radio from the dashboard and post the SERIAL NUMBER found on a label on the casing
Code for Radio on 05 Ford Transit Connect
hi harry can you see a number starting with m it should b on the side of the set next to the serial number get me that number and i can get you the code to unlock it for you send it to my email add a2wul@hotmail.com
Dec 08, 2013 | Ford Cars & Trucks
Fuse for the brake lights for a ford transit 260 y reg
I have a ford transit 2001 van and need to change the fuse as brake lights have gone but do not know what fuse it is in the fuse box. Can anyone help.
Apr 18, 2011 | Ford Transit Connect Cars & Trucks
Have a ford transit T280 100 04 reg and the radio code as been lost and cannot reset it been away turned ignition on and radio code needed to get radio working again
Post the SERIAL NUMBER beginning with M++++++ or V++++++ found on a label on the radio casing.
=================================== Here is a videoshowing how to remove a standard radio from the dashboard. A pair of extractorsare required (available from Ebay etc ) but these can be made from 2 pieces ofbent, wire coat-hanger or 4 smalldrills(using the blunt end) or 4 small Allen Keys or 4 small screwdrivers or 4 nails or even 4darts. An assistant isuseful to pull the radio out whilst you are releasing the 4 securing clips http://www.youtube.com/watch?v=urC-4NbXvDQ note: on some radios, these 4 holes are protected by 4 small screws. These can be unscrewedusing the appropriate of Allen key. ====================================================
Mar 06, 2011 | Ford Vehicle Parts & Accessories
Transit radio code
Your FORD radio code is: 5456.Do You know how to entered?If not just follow the steps bellow: Press preset[1]repeatedly for the first digit, [2] for the second,[3] for the third and [4] for the fourth.Then press [5] to accept.If the display showsLOCK 10,turn ON the radio whilst holding down [6]You can then enter the code. If you are unable to enter a code,leave the radio powered up for one hour to reset.
Jan 12, 2010 | Car Audio & Video
Diagram of Location of a Starter Motor on Ford Transit 2002/2003
i have a 2001y reg transit tipper and i think the starter motor is going when i go to start it like grinds then some times it starts perfect
Nov 24, 2008 | Ford Festiva Cars & Trucks
Ford transit alternater
I am assuming your Transit is an older model. To get rid humming noises out of Car radios in the old days from generators and alternators there was a device they used to put on the alternator. I think it was like a capacitor. I am pretty sure you can still buy these at places like Jaycar and Dick Smith. They also used to put a device in the spark plug leads to stop interference from the motor/alternator. I don't know if this will help or not but is worth a try. Of course it could be a squealing fan belt and will do it until the belt warms up. That being the case a bit of soap or crayon on the belt will/should stop it. Hope I have helped.
Soleman13au
Nov 28, 2007 | Radio Communications
Buck Ford Econline Van 1998-2006 Stereo Radio Wiring Harness Logo
157 people viewed this question
Top Buck Car Audio & Video Experts
xxxxxx xxx
Libran Moreno
handygirl911
handygirl911
Are you a Buck Car Audio and Video Expert? Answer questions, earn points and help others
