Question about Frigidaire Washing Machines
I have a frigidaire front load washer model ftf2140fso, i washed a rug, and it stopped, can i access the filter from the front of the washer? aleidalyons@yahoo.com
My front load washer won't spin fast
Posted on Jul 18, 2011
After washing bathroom rugs, my Frigidaire Affinity front loading washer would not drain the water out or refill with water
Often washing things like rugs and matts can cause real problems for the drain pipes on you machine. Have you tried clearing out the drain plug, located at the bottom of the front of the machine? If that doesn't work, the whole drain hose from the drum will be blocked.
thanks
www.recycledrum.com
Jan 12, 2013 | Frigidaire Affinity ATF7000E Front Load...
I washed a rug and the back fell apart clogging the washer somehow so the water wont drain what do i do?
You may need to do more than just a filter cleaning. Your sump and hoses are all probably clogged too. Looks like you will have to take the washer apart and give it a good flush out.
WM2277 service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 13, 2011 | LG WM2277H Front Load Washer
I washed a rug and now it won't spin or drain
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 08, 2010 | Frigidaire ATF6000ES Front Load Washer
Stopped spinning from heavy rug
what is error, most likely plugged the pump
Apr 18, 2010 | Frigidaire Affinity ATF7000E Front Load...
Hello, I washed an old very LINTY WOOL rug, 3'x3', in the front load washer. After running a bit, the machine stopped. Would not drain. Would not spin. The motor hummed but would not re-start. I may...
Remove thye power Take off the back panel
Lean the machine forward onto a solid surface
Put something underneath it to stop it falling on you
Locate the main hose coming down from the drum to the pump , put a dish under that area
Loosen the clips holding the hose on
Take off the hose and clean out the crud
Reassemble, fill the machine with water via the front door using a jug
Check for leaks, if there are none put the power on and switch the machine into spin mode
The water you put in should come out
Put the back panel on and off you go
Jan 14, 2010 | Washing Machines
I have a frigidaire front load washer, it and the clothes stink.
I have read that using Nu Fresh in a few of your loads will take care of this problem.
Sep 06, 2009 | Frigidaire Affinity ATF7000E Front Load...
Need to remove the front panel of front load washer
you will have to remove the rear panel in order to remove the front panel. The bolt and clamp are inside the front panel.
Jul 09, 2009 | Frigidaire ATF6000ES Front Load Washer
How to diagnose
Sounds like your motor is blown. That's going to require a repairman.
Mar 31, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire GLTR16704 Front Load Washer 417.39012891
Time for a new one.
Sound like you have done the main shaft bearing.
Nov 18, 2017 | Frigidaire GLTR1670A Front Load Washer
14 Cycle Front Load Washer Frigidaire
COLGGED PUMP! CALL SERVICE BEFORE IT COST YOU MORE TO REMEDY THE PROBLEM. do not try to use this!
Aug 08, 2008 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
180 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
