Question about Vacuums
The steam is to comeing out of the nozzle but underneath the machine
  • 17,130 Answers
You will need to check to see if there is a break in the steam track so a physical examination of the leak with an investigation into the steam track will needed.
Check for block in the nozzle track to confirm.
Posted on Sep 14, 2010
Oreck steam cleaner, it doesn't give out steam
Use the tool that came with it to clean the nozzle where steam comes out. End nozzle also comes off so you can clean the larger hole with the other scrublike side of the tool.
Also, listen for steam assembly working, a low rumble like sound. If you do not hear it, it is broken and needs to be replaced.
Oct 07, 2016 | Oreck Vacuums
The steam comes out of the water reservoir cap instead of the steam Jet Nozzle.
I can only guess since I have never worked on one of these units, but I think you lost a gasket on the cap. Pressure must build in the reservoir before being forced out the nozzle.
Jul 13, 2015 | Tristar SB Steam Buggy Vacuum
Why is vax s7-a+steam mop steamer dripping water and cuts on and off
I managed to fix mine after a little effort. It was blocked well up in the nozzle into a small pinhole where the steam comes out of the 'small kettle' in the steam mop.
To fix:
  • take the blue side bit off by unscrewing the two small screws
  • Undo the screws inside (there are about 11)
  • Once these were undone there was two screws holding the nozzle cover.
  • After unscrewing these pull the nozzle cover of and scrape limescale from inside the small hole where the steam comes out
  • Put it all back together and it should work much better
You should only really do this if you are competent as there are lots of wires etc. and if your steam mop is not covered under warranty as messing around with it will void this.
Hope this helps :)
Jul 04, 2014 | VAX Appliances Vacuums
Little yellow steam cleaner wont work no steam coming out of nozzle
I have got a little yello steam cleaner there is no steam coming out of the nozzle wot should I do to be able to get this to work again if some one can help me please
May 06, 2012 | Vacuums
We have a Magimix M 200 Purchased at John Lewis Registration No: 278739 approx Dec 2008. We have not got the purchase receipt. The nozzle for frothing up the milk is not working at all so we are unable to...
There might be a blockage in the steam tube or the frothing nozzle itself. Make sure the nozzle is clean and try inserting a pipe cleaner gently into the steam tube to clear any blockage that may be preventing steam from passing through.
Jun 30, 2011 | Vacuums
Cleaning mr coffee ecm3 how
Deliming
SUGGESTED CLEANING SCHEDULE
Type of Water Cleaning Frequency
Soft water every 80 brew cycles, Hard water every 40 brew cycles
Your espresso maker may be delimed using one quart of white household vinegar. Clean the water tank first, following steps l-5:
1. Make sure the steam control knob is in the center off position and that the plug is disconnected from the electrical outlet.
2. If the machine is cool and the pressure has been released, remove the pressure cap and pour 10 ounces of undiluted white household vinegar into the water tank.
3. Screw on the pressure cap and allow machine to sit overnight with the vinegar solution in the water tank.
4. Remove pressure cap and discard vinegar through the top opening of the espresso maker.
5. Rinse the water tank thoroughly with tap water, repeating this step twice.
To wash internal parts:
Make sure you clean the inside of the water tank first. Remove the pressure cap and pour 10 ounces of fresh white household vinegar into the water tank. Screw the pressure cap back on top of the water tank. Make sure the cap is on tight. Insert the filter holder into the brew head and place the glass decanter with lid on the drip tray. Plug the machine into the electrical outlet and turn the power switch on. An indicator light on the power switch will tell you the machine is on. Place a cup with cold water under the steam nozzle. When vinegar begins to flow into the decanter, insert the nozzle into the water and open the steam nozzle slowly by turning the steam control knob downward. After a few seconds, close the steam nozzle by turning the knob back up to center. This will clean any residue left in the nozzle from frothing milk. When all the vinegar has been pumped into the decanter and the flow has stopped, turn the power switch to the center off position and allow the machine to cool. Repeat steps 1-7 twice using only tap water to rinse any remaining traces of vinegar out of the machine.
Decanter cleaning
1. Pour warm white vinegar in the decanter and let soak for 20 minutes.
2. Discard the vinegar, Wash and rinse the decanter thoroughly using a
soft cloth. Do not use harsh abrasive cleaners.
Dec 12, 2010 | Vacuums
My shark steam mop will not shoot out steam. Is
This machine is made in China. It was never meant to be repaired or serviced. It sounds like your heater core is shot. The machine will need to be totally replaced.
Dec 01, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I need instrution on how to change the belt on my kirby 4 power
you have to be more spicific on the model but: if you take off the front nozzle by loosen the nozzle lock, make sure the name kirby is horizontal, loosen the latches at the back of the nozzle un hook the rugplate located at the bottom of the nozzle...take out the brush..... slip out the old belt...in with the new one. put back the rugplate, lock the latches. NOW turn the nozzleknob anticlockwise until it stops at where the 2 arrows align, put the nozzle back on the main machine and lock the nozzle lock underneath the light.then turn the knob ALL the way clockwise until arrows allign again....switch on machine ..make sure green lihgt on nozzle comes on....
May 17, 2009 | Kirby G4 Bagged Upright Vacuum
No steam release
I solved the problem, the metal (hot!) release rod gets stuck & needs a little push.
Unfasten the top by prying off the rubber gasket after removing the top. Remove the 2 small phillips screws, then remove the front that holds the nozzle, & remove those 2 phillips screws.
Carefully pry up the top with a putty knife, inside you will see the tip of a metal piston that the plastic release knob is supposed to contact. Set it on its front, & soak the piston with a light household or sewing oil, giving it a few taps with a blunt object occassionaly to loosen, heat up & test before reassembling, but remember, the piston is very hot. When you push on the piston with a screwdriver, it should release the steam, but also stop when you let go. Work with it a little & it will come back to life.
Dec 12, 2006 | Euro-Pro Super SC710Z Steam Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
