Question about Homelite Mighty Lite Lawn Trimmer
I have a homelite whipper snipper from bunnings $99 , how do i change the cord
4 Suggested Answers
  • 17 Answers
SOURCE: cord stayes out motor not running
Take it back to place of purchace.
We get these all the time if its the cheap bent sharft with starter between shaft and motor. the easy start spring gets jammed and needs replacing.
Posted on Jan 08, 2009
  • 3 Answers
SOURCE: homelite whipper snipper is hard to start and its
I took mine back to Bunnings and the guy there said they had a number with this problem and have found that priming the bulb 20 times not 10 as per the manual, is the fix.
It certainly fixed mine
Posted on Sep 15, 2009
Testimonial: "Thanks, will try it!!!"
  • 122 Answers
SOURCE: what is the correct fuel
I believe Homelite calls for 40:1 (2.6oz. oil to 1gal gas) mixture, but if you are using a good current brand name two cycle oil, 50:1 (3.2 oz. oil to 1 gal gas) would be safe also.
Posted on Feb 08, 2011
Primer bulb for mightlite whipper snipper who can fix, Gailes.
It is pretty easy to fix if you are the least bit handy. Order what you need from Amazon or your local service center.
Or, contact your local Homelite retailer/service center directly or online here: https://register.homelite.com/sign-in
Feb 07, 2018 | whipper snipper Garden
Sthil whipper snipper fs38 won't engage the starting pull mechanism, it turns but won't grab drive coupling
remove the recoil cover and check the dogs that engauge the starter to the flywheel
Jul 28, 2012 | whipper snipper stihl fs 38
Homelite whipper snipper amnyal needed. I need to know the size of the cutting cord or citting line size and the fuel mix for the homlite whipper snipper model HBC265JSNB SN1008015039 LwA N197 are all...
This Homelite gas trimmer runs on a 50:1 mix of unleaded automobile gasoline and two-cycle engine oil. That is equivalent to 2.6 fluid ounces (80 ml.) of oil to one gallon of gasoline or 4 tsp. (20 ml.) of oil per quart of gas, or 2 tsp. (10 ml.) of oil per pint of gas. Don't use automotive motor oil or two-cycle outboard motor oil in your Homelite gas trimmer; they contain additives detrimental to trimmer performance. Use mixed fuel within 30 days.
Feb 07, 2018 | Garden
I wish to replace the trimmer head on my Ryobi PLT3043A Whipper Snipper. Its just worn from to much love ???? I know how to replace the cord but wish to replace the cord haed assembly. I brought the...
Hold the shaft to prevent it from turning, then turn the trimmer head clockwise (viewed from the bottom) The cutter adapter has left hand threads. Hope this helps you out, as this is from the service manual. Best regards and good luck.
Dec 30, 2010 | Ryobi Garden
The carburettor needs an overhaul or replacement.
take carby down to any mower shop ...most brushcutters use same carbys...
Mar 20, 2010 | Homelite Expand - It Brushcutter...
Homelite whipper snipper is hard to start and its new petrol mix is correct
Sep 14, 2009 | Homelite Garden
Cord stayes out motor not running
Dec 26, 2008 | Garden
Homelite Mighty Lite Lawn Trimmer  Logo
1,182 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
