Question about Vacuums
My pen drive is faulty error showing insert a disk into drive and let me kingston service center in kanpur or gwalior or gurgaon
  • 17,130 Answers
Check your pen drive on another PC, if it works then your OS does not support unless you have the software disk . Contact your local store who sold you this drive.
Posted on Sep 14, 2010
Replace drive pulley part number38537013
Hi there! The drive pulley part 38537013 is not a sellable part. We do not recommend repairing this part on your own. Follow the link below to locate the nearest authorized service center to take your vacuum for repair. Thanks!
Service Center Locator
Oct 20, 2014 | Hoover Ultra U6430-900 WindTunnel Bagged...
Drive pulley replacement
Hi there! The drive pulley is not a sellable part. We do not recommend repairing this part on your own. Follow the link below to locate the nearest authorized service center to take your vacuum for repair. Thanks!
My neato keep asking "put in my dirty bag"
Neato's dustbin, when inserted into the recess, makes contact with a switch that indicates that the dustbin is in place. First, ensure that when you insert the dustbin, you press down FIRMLY to make sure it's all the way in. You should hear it "click" into position.
If you hear the click, but it still isn't working without errors, it may be that the dustbin is not pressing down on the switch with sufficient force. The easiest fix for this problem is to tape a small piece of paper to the switch (to add some "height") so the switch will make better contact with the dustbin.
Finally, if neither of these methods works, it may signal a faulty switch in the dustbin receptacle. If the switch is faulty, you'll need to have the Neato serviced.
Jun 04, 2014 | Neato XV11 Vacuum
Brush drive gear
Hi Ivan. I'm sorry you're experiencing difficulty with the drive gear. You may want to contact one of our Authorized Service Centers for assistance.
Here's a quick link to help you locate one: http://www.bissell.com/service-centers/?cid=ccsocial
Aug 12, 2013 | Bissell 7901-R Clearview Proheat Plus...
Bissell proheat clearview red pump pulley
Yes, it should be spinning and driving both belts. If it is not you would need to have it fixed by a service center. This should be covered if your machine is still in warranty. Here is a link to find your nearest BISSELL Authorized Service Center:
May 23, 2013 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell wont turn on
Hey, you may want to remove the upper handle to see if the wire harness is protruding, then reinstall making sure the handle is fully inserted onto the machine.
If you continue to experience no power, you may want to have one of BISSELL's Authorized Service Centers inspect your machine.
Here's a quick link to locating one in your area:
Feb 13, 2013 | Bissell 9400 ProHeat Upright Wet/Dry...
Just recently purchased a perfect sweep turbo,and now it is making a rattling noise when I use it ,was wondering if this is usual,
Hey Jean! You may want to make sure the dust cup is inserted correctly and the brushes are clear of hair.
If you continue to experience a rattling noise, you may want to have a technician at one of our Authorized Service Centers inspect your machine.
Here's a quick link to locating one.
Feb 02, 2013 | Bissell Perfect Sweep Turbo Cordless...
Sir, I have TDK 4 GB Pendrive. I was formated some
this the great solution... try low level format..
1. plug ur usb flash
2. run Formatter v2.9.0.9.exe
3. follow the instruction and wait for the format (might take 5min for 4GB)
4. after complete, may the small volume (about 2MB...here the solution
5. plug your usb flash on other computer and format like regular (make sure u untick quick format) and click on "restore device defaults" then click format
6. now your usb flash drive was like a new one
Dec 14, 2009 | Vacuums
Kirby g4 vaccum
please clarify what you mean?
Do you mean motor bearings or brush roll bearings?
brush roll bearings can be adjusted to lower the brush closer to the carpet when worn.
to do this remove the front brush assembly, there is usually a sticker below the belt hole showing RED = POSITION 1 HIGHEST (ie a new brush roll)
GREEN = POSITION 2 MIDDLE (brush part worn)
BLACK = POSITION 3 LOWEST (brush fully worn)
At each side of this there are 2 clips unlock these and remove the bottom cover.
Release the belt tension by rotating the belt release at the front.
Before removing the brush roll, at each end of the brush roll there is a grey plastic bearing carrier (Square at the ends) MARK this with a pen or marker just so you know the original position, also look closely for the coloured markings as indicated above or numbering 1,2 or 3.
If RED or "1" is showing you need to remove the brush roll by pulling it out and rotate the endcaps to Green or "2" and re-insert the brush roll, If Green or "2" is showing then rotate the endcaps to Black or "3" and re-insert.
If Black or "3" is showing then the brush roll is worn and cannot be adjusted any more, fit a new brush roll and insert with RED or "1" showing.
To re-attach the belt, move the belt to the middle of the roll and rotate the belt knob at the front ensuring the belt engages with the hook on the inside.
May 09, 2009 | Kirby G4 Bagged Upright Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
