Question about Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier
Front has moisture on fins, runs but does not take out much water even though basement is real wet, I noted the whole front was frozen last week...
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on Sep 16, 2010
Unit comes on briefly then kicks out bucket without getting any water out of the air. Basement is very wet
Hello friend, I appreciate your post!
From my understanding your Frigidaire dehumidifier is shutting off and on without removing any moisture from the air. I would recommend trying a different outlet within your basement and adjusting the setting to see if that would help. Additionally, try to turn the unit on continuous drain to see if it pulls any moisture out of the air. If your appliance continues to shut on and off I would reach out to the manufacturer to see if they could assist with any additional resolution. Hope this information proves helpful. -Matt
Aug 24, 2014 | Dehumidifiers
Water is not collecting in the bcket. I have had this on and it
whats it set on, check and verify the the compressor running if not wont pull out any humidity
May 10, 2010 | Fedders A7DH45B2A Dehumidifier
My Haier dehumidifier Model #39R171E is operating intermittently. The bucket is not full - power is on - temp in room says 59- do I increase the humidity to get it to work? Have a large amount of water in...
If your carpet is wet ... like mine was ... the best thing to do is bite the bullet and get the carpet out of your basement or where ever it is ... so your dehumidifier has a chance.
You reduce the % on the machine to reduce the humidity in your room. You should probably also get some fans going.
I have removed my carpet and padding and everything that I can reasonably remove from the room. I have 4 fans going and 2 dehumidifiers and two sump pumps. I also keep the windows open in the day time because it is more dry outside than in the basement. I have heat in the basement which I run at night. My goal is to save my house from damage due to moisture. It will be a good month for the electric company, that is for sure.
I'm sorry you are in this perdiciment ... I'm sorry for me too. My carpet was less than a year old and we have not had any water in the basement for 30 years.
Mar 03, 2010 | Haier HDN655E Dehumidifier
The dihumidifidier is not drawing water. It is
In order for the Dehumidifier to remove moisture, the coil temperature has to be below the dewpoint temperature. If you check with the weather station and find out what the dewpoint is in your area, then measure the coil temperature or cold line coming out of the coil,it has to be below the dewpoint to get moisture, you can also look at the coil and see if it's wet which will also tell you if the coil is below the dewpoint.
Aug 05, 2009 | Whirlpool Gold AD70USS 70 Pint Per Day...
Kenmore 54501 turns on but nothing happens in my damp basement
A dehumidifier heats and cools the air to remove moisture. Most are like a small air cond. The Condenser coil is right in front of the evap.coil. So the compressor may not be coming on. Does it sound the same as before? It may be low on freon. You will have to get in there and listen and feel the lines at or near the compressor, Learn how to get down in there to the compressor. Run it for 10 Mins. unplug it, open it up, and feel the lines. Some lines should be or can be HOT to the touch. Some should be cool. The smaller the line the hotter it should be, and the compressor should be warm (to hot) to the touch. repost for more info.
Jul 08, 2009 | Kenmore 54501 Dehumidifier
Works well but
Yup, they eat energy.
An electric dehumidifier includes a refrigeration cycle that is very similar to a window AC units and refrigerators. They cool the air in the basement to condense and collect water and remove humidity, heat the air as a required consequence of the refrigeration cycle and dump it back to your basement.
Two sources of humidity in basements include warm outside air that naturally cools due to below grade earth contact and water passing from the ground though the floors and walls and evaporating into the basement. Dehumidifiers do most of the work in the summer when higher temperatures outside enable air to hold more water content.
In the winter, cooler outside air contains less moisture by weight eventhough it may be raining and the relative humidity in basement will be less because the air is warmed relative to the outside. The lower moisture content in the winter also absorbs the water passing through the walls and floor.
From an energy perspective, you may want the humidity set NOT below 50%. This will keep humidity below the level mold desires, but prevents the dehumidifier from doing more work and eating more energy than needed. A cheap battery powered temp/humidy meter left in your basement will help. Sources that include the "mold triangle" (temperature, water & food) often separate fact from expensive hype.
If the dehumidifier doesn't keep up, consider adding a moisture barrier to the basement walls and floors such as Dry-lock and floor paints to ****** moisture entry. Moisture barriers act very similar with water as insulation does with heat. They don't eliminate the need for a dehumidifier, but they reduce the work they do and energy they eat.
Oct 02, 2008 | DeLonghi DH40P Dehumidifier
Humidifier coils freeze
I believe a dehumidifier is supposed to operate in temps above 60 degrees. Even though your house is warmer than that, the air entering the dehimidifier may be getting into that range due to it being on a basement level etc. This is perfectly normal and is not a malfunction with your humidifier.
Your options are to either place the dehumidifier closer to a heat source in order to keep the air which is entering warmer. (I've even heard of someone placing a light bulb in front the unit during winter to warm the air slightly as it enters). Because the dehumidifier's coils get cold in order for it to collect moisture from the air, if they are freezing, giving the unit a rest for a few hours every few hours may allow the coils to thaw in between and prevent them from reaching freezing temperatures while running. You could use a timer to accomplish this, but you'll want to insure that it's a commercial grade timer in order to handle the electrical draw that the dehumidifier requires.
Dec 29, 2007 | Eva-Dry EDV300 Dehumidifier
LG Dehumidifier Not Working
the freon has leaked out, must be replaced.
Jun 05, 2007 | LG LD65EL Dehumidifier
Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier Logo
161 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike
Mike Squire
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
