Question about EliteGroup GeForce 6100SM-M Motherboard
Randomly shuts off
There doesn't seem to be any one thing that makes it shut off. I can be doing something, or I can be doing nothing & it'll just die as if I'd pulled the power cord. Any suggestions?
I'm running Windows Vista 32 bit, AMD 64x2 5600 processor, Geforce 8600 GTS video card, 2 GB RAM, a 400w power supply, and my temp according to Core Temp is usually between 30c-50c.
  • 2 more comments
  • Oniphire May 15, 2008
    Forgot to add that I have updated my BIOS & drivers.
  • Anonymous Sep 05, 2008
    Same Problem. I'll send it back...
  • troy-evans Sep 30, 2008
    SAME MOBO RAN 6 MONTHS WITH XP PRO. NOW SHUTS OFF AFTER 6 BARS ON STARTUP EVERY TIME. BOOTS IN SAFE MODE AND RUN FINE. TRIED REPAIR INSTALL AND IT NOW SHUTS OFF AT 39 MINUTES BEFORE PROGRESS BAR APPEARS.
  • Anonymous Dec 03, 2008
    I have the same issue with 5600+ perhaps it cant handle the 89w processors
I am having the same problem along with many others, seems to me that this board is a waste of time. PC repair tells me that it is due to the "system timer" how this is fixed, I dont know yet.
Checking for bios drivers at the manufactures web site at this time, will let you know how it turns out. sorry cant b more help
Posted on May 28, 2008
I have a 2011 raptor 250r it starts good runs for about 10 min then dies let it cool down and cranks right up same thing what can I do?
Hi Troy, The link below is a short youtube video showing how to test and fix a car that shuts off randomly, Hope this helps.....CHEERS..
Fixing Car That Shuts Off Randomly
Apr 07, 2016 | Cars & Trucks
95 Chevy tahoe randomly died twice on me today. 1st time it restarted and ran good for atleast 3-4 hrs. Second time it died as I was coming off the interstate & wouldnt restart for nothing! I had
Could be several things .... Do you have a distributor ... Have you ever changed it? There is a pickup coil on it that goes bad tale off dist. Cap and look to see if it has cracks or is broken .... Easier to just buy whole distributor (2) fuel pump try starter fluid to see if it will start by spraying a little in intake...
Feb 14, 2014 | Chevrolet Cars & Trucks
1998 Chevrolet C3500 dies randomly when driving down the road - uphill, downhill or flat surfaces. Typically doesn't happen when it's cold. Sometimes it starts back up and sometimes it doesn&#
my younger brothers' truck did the same thing and there was a relay up under the dashboard that would get hot and shut of(kind of a circuit breaker unit) most of the operating systems will flash at you when only battery voltage is available which explains the lights coming on..these newer trucks also have a performance chip in the system that will act up when it gets warm also..replace this and you may be ok..let me know what happens also.. good luck.
Jan 16, 2013 | Cars & Trucks
I have random restarts on my Vizio E421VA HDTV. Are there any firmware updates?
I have the same problem but only when using HDMI connection.
Jun 23, 2012 | Vizio 42 in. LCD TV
04 gmc envoy randomly shuts off. it does it when your at a stop light and about to proceed. it seems like it wants to stall (its a automatic) but either will shut off or it'll proceed but really slow....
Read the codes off of the engine computer with an obd-II scanner. If it's missing and shaking as badly as you say, then there probably are codes stored in the engine computer that can point you in the right direction.
Nov 04, 2011 | 2004 GMC Envoy
Acer Aspire 5742, Completely Shuts off, error free, randomly.
If your computer is shutting off randomly, there could be a multitude of issues. Most of the issues are hardware related.
1. If you're able to use your computer for a little while, and it randomly shuts off, it could be one of a few things.
a. Overheating processor: You may need to replace your processor, or clean out the inside of the computer.
b. Fans not working: Your fans could be disabled, and keeping the computer from receiving cooling which can overheat the processor as well as other vital components.
c. Dying battery: The battery in your laptop may be going bad, and could need replacement. Does it charge completely, or does it only fill up partially after a long period of charging? If it's the latter, you will need to replace it.
d. Dying hard drive: While this one isn't as likely, and usually doesn't cause the computer to shut off instantly, it's still something to consider.
2: If your computer shuts off before the desktop even loads, it's most likely a hardware problem.
a. Dying battery: Again, your battery may be dying, try removing it and keeping the laptop plugged in when you turn it on.
b. Broken hard drive: Your hard drive may be broken, try finding an external hard drive with Linux or another operating system installed on it, and go into the BIOS when your computer first starts up. Find the "Boot devices" option, and tell it to make the primary boot device the external device with the operating system installed on it. If the computer starts up fine after that, you may need to re-install your old operating system, or replace your hard drive.
May 04, 2011 | Computers & Internet
I left my iPod in a bag with a wet swimsuit . now it's messed . The top volume button won't work , the volume changes on it's own then the iCon stays on it and it randomly shuts off . What's wrong and can...
Unfortunately the chances are its suffered from moisture damage.... Apple will have to fix it, its unlikely you'll be able to go to a 3rd party store, or they may not do it correctly. I have a suggestion though. Shut it off. Don't turn it back on. Leave it in a hot press for 72 hours. That'll let it dry out fully. Then fully charge and turn on. If that doesn't work its probably fried. After something suffers moisture damage you shouldn't turn it on until its fully dried out or it gets worse. Sorry man.
May 03, 2011 | Apple iPhone Apps
Sometimes my jeep sputters like it is running out of gas but it isnt then when i press the gas all the way to the floor it does nothing ,and then it dies if i shut it off and crank it back up it its fine...
The first thing I check for this sort of symptom is the fuel filter. Sometimes you get a bad load of gas with sand or other stuff in it, and it clogs the filter. When you try to accelerate, it either fails to respond or dies. When the engine is off, some of the material seems to fall off and it will run again for a while. It's the cheapest thing to replace, and usually easy to do, so it never hurts to try.
Oct 27, 2009 | 1995 Jeep Grand Cherokee
EliteGroup GeForce 6100SM-M Motherboard Logo
90 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
