Question about Transcend StoreJet 320 GB USB 20 Hard Drive
I have my Transcend Storejet 320GB USB HDD. On my laptop it detect the drive but it not showing any data inside and hang the PC. Is there any utilities to get my data recovery?
    Problem Solver:
  • 13 Answers
In this case you should use data recovery software to try recovering the files and data, provided those lost data are not fully overwrtten.
Be careful: Before your files are recovered, do not attempt to save more files to the HDD in case the original files are overwritten.
Posted on Dec 15, 2010
MY PC WINDOWS XP ASKS TO FORMAT MY STOREJET 25 320 GB TRANSCEND PORTABLE HARD DRIVE
If it's asking to be formatted you need data recovery help. For remote data recovery and do-it-yourself data recovery see http://FreeDataRecovery.us
Sep 04, 2012 | Transcend StoreJet 25 Mobile - Hard drive...
I was using one of my StoreJet 25M (I was watching movie on my laptop). And then, I have pull out USB cable from that one, and put it in my second StoreJet 25M to see something else. Now I can't reed...
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use asoftech data recovery program to recover your files.
http://www.asoftech.com/adr/
Aug 28, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
My transcend 320gb external hdd sometime disconnected automaticall. At present i can not even view my valuable data. If the folder inside the hdd are not show by my computer, how can i recovered my data...
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
May 21, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
How to remove write protection my transcend storejet 320gb. Now I'm just using 32Gb of space and that's it, I can't copy anything. But property shows me 278Gb of free space. HDD- WD3200BEVT-00A1TT0...
try right clicking and going to the properties and and reset the permissions of the drive. some times the user account will be write protected and the default hidden admin account will have full access.
Feb 28, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Hi.. i need help.. my external hdd transcend store jet 320gb have problem... when I conect HDD to pc blue led blink just one time and hdd stop working..
Check that the USB cable can provide enough power to the hdd. Check that the USB port is powered. Older USB slots may not have enough power to run larger external HDDs, there you may require separate power to be plugged into the hdd. Are you using the original USB cable provided with the external HDD?
Feb 28, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
One day i connected my Transcend storejet with Macbook laptop of my friend and when he clicked the drive,computer started to make backup.He stopped the backup process in between.After that when i connected...
This is because of the file system...Mac uses a different kind of file system, while windows uses a different one...
You need to format the hdd before using in windows machine...
because your HDD file system would have altered by MAC...
Now format the HDD from device manager and you will be able to see the HDD under windows explorer...
Feb 07, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
I have got transcend storejet 25M 320Gb external hard disk.....when i started using it i transferred some data from my PC to the hard disk and the transfer speed which it was showing was 1.2mbps which is...
You connected it to a "USB 1.1" socket in your computer, which is only 1/40 of the speed of a "USB 2.0" socket (if your computer has any such USB sockets). If you don't have any USB 2.0 ports, buy a PCI add-in card to add some ports to your computer.
Nov 01, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
Hi, my Transcend Storejet 320gb has the following problem:
These things die like flies, for no good reason I have found. Especially if you have tried it in a PC that has never had it in before. You may as well try to reformat it. At least this way you may get a working drive again. But FIRST also Check the drive is OK, or Not by removing it and try connecting to a PC's SATA port. OR get a USB to SATA drive dongle, and see if the drive will work with that. Sometimes the USB electronics in the USB Drive is the actual culprit.. If the drive is OK, then you can use it on the dongle you tested it with.
Feb 11, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
Detection problem
check it on other usb ports, also replace the usb cable
Oct 07, 2008 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Transcend StoreJet 320 GB USB 20 Hard Drive Logo
831 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Josh Whitehead
Josh Whitehead
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
