Question about Asrock P4I45GV R5 Motherboard
No beep,No Display on my monitor,only CPU... - Asrock P4I45GV R5 Motherboard
  • 506 Answers
Connect the same monitor to anothe CPU if it works, Get an add-on Video card to your systems and disable the on board video card. If your monitor has a problem repair or replace it.
Posted on Sep 14, 2010
I am currently on my laptop because when I turn on my desktop, the monitor (ViewSonic VX2235wm) powers on with a message that says No Signal Digital and then turns off. Any suggestions?
hi; your monitor has no problem, its your cpu. Try to hook your monitor to your laptop,and change the display setting to your LCD monitor. If LCD has displaying no signal mean signal coming form the Video card of your CPU try to visualize if you hearing some beeps into from CPU, some motherboard has beep codes if there's an error or failure to your CPU, 1 beep means its good system test. if you don't hear any beeps, try to check first your Video Card marmeto12_21.jpg if you have Spare try to replace it, try to reset all the connectors even Memory card to its slot. reset means pull the connectors and place it back again, also check the power supply of cpu if still functioning good.but you can test it by multi volt meter. if nothing happens check your motherboard most common failure is bloating capacitor, and overheating chipset. thanks....................hope this helps...................
Sep 07, 2011 | ViewSonic VX2235wm LCD Monitor
My monitor is not responding to anything. what can i do aside from rebooting?
do you see the light blinking in the monitor? I mean the POWER led light up? If so, then the monitor is ok and is working good. It is your CPU which has a problem and not sending digital signal for the monitor to display.
Try to turn off your computer. After 3 minutes turn it back on. then notice if you will hear a short beep from the CPU. That signals a successful video initialization. If you went through that process, then your computer will get back to life.
However, if you dont hear a short beep from the CPU, then definitely your CPU is frozen therefore there is nothing to display to the monitor.
You need to open the CPU case, pull out memory modules then plug them back in. Then try booting.
If not successful, try to open case and pull out the processor. Put it back in after 30 seconds. Try booting again.
Do ALL THESE while your PC is UNPLUGGED.
Good luck.
Oct 09, 2009 | Computers & Internet
My Viewsonic monitor flashs but noscreen display. Is this the power supply
If the light (yellow or pink) is flashing, your monitor is well. It's your CPU that is not giving a video signal to your monitor. Try to reset and notice if your CPU beeps. If it doesn't beep, then there is something wrong with the CPU... or the CPU's speaker.
Regards!
Jul 09, 2009 | ViewSonic (A-AD-0114-0011) Power Supply
One long beep tone---NO Display on monitor(monitor checked ok)
Definitely not your monitor. It is either a CPU or a Memory problem, is this a new build or did an existing computer suddenly start doing this?
Is that your motherboard, the Gigabyte 7VM400M ?
Jun 26, 2009 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
No display
Beep codes are usualy heard when there is a problem with either your display card or your RAM.
Your problem could possibly be a faulty CPU.
Does your CPU work in another board, or can you try another CPU in your board?
Regards,
Graemevm
Apr 23, 2009 | Intel Motherboard, 945GC, Core 2 Duo,...
No signal then orange light on my Gateway FPD1975W 19Inch Monitor
If you have a add on display/graphic card in your CPU then shutdown the system, open the case and try to press the display card gently. Sometimes if the card get loose the display will not come.
If you don't have add on display then try to press the Memory gently after shutting down the PC and try the signal again.
If not resolve let me know whether any beep/sound is coming out of your CPU box?
Rate my answer please.
Thanks.
Jan 04, 2009 | Gateway FPD1975W 19" LCD Monitor
No beep,No Display on my monitor,only CPU heatsink fan is moving
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
Oct 29, 2008 | Asrock K7S41GX Motherboard
No Beep No Display
Immediately change your motherboard.
Jul 03, 2008 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
No Beep No Display
motherboard problem motherboard can't display when switch on, the cpu fan faster no beeping . I had change power supply, but same.Check the keyboard LED,Not flash.I had remove the ram but can't hear beep. PC speaker ok conferm. Monitor display tested monitor its ok . But no comming display. Can you help me? How i can solve this problem?
Jul 03, 2008 | Intel Motherboard
Asrock P4I45GV R5 Motherboard Logo
81 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
