Question about Iomega MiniMax Desktop - Hard drive - 500 GB - external - Hi-Speed USB - 7200 rpm - buffe
I plug the external HD into the USB port and the HD will show power but the HD will not appear on the computer...no drive is assigned the HD. Thanks, Tim
  • 1 more comment
  • tjspecht Sep 14, 2010
    1) working okay
    2)Tried all laptop USB ports - no difference
    3) drive not shown in disk management
    4) USB cable is not damaged
    5) restart did not correct problem
    6) Found red x for:
    a. network adpater - 1394 Net adapter
    b. portable devices - nokia 2330c-2
    Solution 2
    ...yes I'm using the USB cable. I don't have a fire wire.
    I deleted all the ghost icons in the requested categories, except SCSI and RAID controllers, because I could not find them in the list. And then I ran the USB viewer and uninstalled all devices not connected.
    I then restarted the computer and plugged the Ex HD in, but it still is not appearing on the computer.
    Other questions:
    a. Yes I can use my memory stick and other usb devices on the computer and the Ex Hd does not work on other computers either.
    b. It's not a new HD and it owrked well for some time...one day while I was installing it, it just would not appear on the computer.
    c. It does'nt make a clacking noise...only a simple whirling noise. And it not taken a hit (fall).
    Thxs,
    Tim
  • tjspecht Sep 23, 2010
    Hi Pelu,
    I've been away...thnaks for your last suggestions. I'll see if that route is available...I'm living in Uganda.
    Tim
  • 516 Answers
This is because there is CD for the EXTERNAL harddisk. You should install that cd after that connect to computer. Then drives will open.
Posted on Sep 14, 2010
  • 977 Answers
Hi!
Please check the follow:
1) The power cable is connected as will (if applicable).
If using a laptop/notepad - connect it's power cable as well!
2) The USB cable is connected to a REAR USB port on your computer (rather than a front one). Also, try using various rear ports...
3) Enter Computer Management (right click on My Computer/Computer and select Manage); Go to Disc Management; If your drive is shown, it might be partitioned incorrectly or not partitioned as all. Use the Computer Management to partition/assign a letter to the drive.
4) Make sure the USB cable is not damaged; Try using a substantial cable to eliminate this possibility.
5) Fully restart the computer. Connect the USB cable once it's fully loaded again.
6) Check Device Manager for any yellow question marks, exclamation marks or red X's... Report me if you find any.
Waiting for your reply...
Good luck,
Pelu.
  • 1 more comment
  • Ran Kedar
    Ran Kedar Sep 14, 2010
    It might sound like a silly question, but I have to ask... Are you sure you're using a USB cable and not a FireWire (IEEE1394) cable?! Because, according to (6), your FireWire controller is not installed/functioning correctly and it might be the problem...
    If it is a USB cable after all, UNPLUG THE EXTERNAL HDD, then do the following (do it with caution!):
    1) Click Start -> Run.
    2) Type in: cmd
    3) Press Enter.
    4) Type in: set devmgr_show_nonpresent_devices=1
    5) Press Enter.
    6) Type in:
    start devmgmt.msc
    7) Press Enter.
    8) On the Device Manager window, go to View and select "Show hidden devices".
    9)
    Uninstall/delete all devices that are ghosted (have faded icons) and appear under the branches: Universal Serial Bus Controllers, Disk Drives, SCSI and RAID Controllers, System Devices and Other Devices.
    10) Close the Device Manager.
    11) Download USB Device Viewer and unzip it.
    12) Run USBDeview.exe.
    13) Right-click and remove all devices that say "No" under the "Connected" column.
    14) Restart the computer and re-plug the HDD.
    BTW, do any other USB devices work for you? Mass Storage Devices (eg. USB pendrives) as well?
    Best regards,
    Pelu.
  • Ran Kedar
    PS: Few interesting questions:
    Is this a new drive?
    Has it ever worked on your laptop before?
    Does it work on other laptops/PCs??
    Does it make strange noise when it's powered on?
    Did it fell lately?
  • Ran Kedar
    OK... We are progressing a little!
    From your answer, I understand that the problem lies within the HD itself - and NOT related to your computer.
    With that said, it looks like the HD and/or the HD enclosure is damaged.
    If it's still under warranty - send it to repair/replacement.
    If not, it gets a little complicated...
    What you can do is take it apart (i.e. take the HD out of the enclosure) and connect the HD directly to a computer (externally, with a SATA to USB cable and a 4-pins power adapter; or internally, into a PC - easier, cheaper and more reliable actually).
    • If the HD is still unrecognized, your ONLY chance is to take it to a computers lab which specialized in data recovery and ask them to recover your data. I must tell you that it's an expensive process and the price varies, depending on the HD condition. If the data itself isn't important, you'll "only" need to buy a replacement HD, of the same brand and type as the HD you had - as IOMEGA don't make the HDs themselves - and put it back inside the enclosure case.
    • If the HD is recognized, it means that there's something wrong with IOMEGA's enclosure case. You can try send it for repair (I don't know how much will it cost...) - after you put it all together; or use the other settings I've mentioned (SATA to USB cable and a power adapter) instead, to keep using the HD as is.
    Best regards,
    Pelu.
Won't recognize external hd
If you have a SimpleTech SimpleDrive connected to your computer and you're experiencing problems with the external hard drive, there may be several reasons why it's malfunctioning. Troubleshooting your computer can help rule out common problems and the possibility that the hard drive may be defective. If you recently purchased the device and suspect there is something wrong with it, return the defective drive to SimpleTech or the reseller for a replacement. Incompatible USB Port Problems SimpleTech SimpleDrive plug and play options makes it easy for you to connect the device to your computer. But you may encounter problems if your computer's USB (Universal Serial Bus) ports are not compatible with the external hard drive. Make sure your ports are powerful enough to operate the drive. USB 2.0 ports are recommended, but if you're using an older computer with 1.0 ports, the hard drive will function much slower or you may receive an error message that the device is not compatible with your system. b> Missing External Drive Letter If you're unable to find the SimpleTech external hard drive's letter on your desktop after you have installed the drivers for the device, it's possible that the external drive may be assigned to another drive. Sometimes, the hard drive is assigned to a network drive and you may need to manually change the drive's letter in Disk Management. b> SimpleTech SimpleDrive Incorrectly Formatted b> SimpleTech SimpleDrive is normally pre-formatted for Windows NTFS (New Technology File System), but Mac users may need to copy the backup software and reformat the external hard drive for FAT32 or Mac OS to be able to use the external drive. If the external hard drive is not formatted correctly for your system, it may not function or work properly. b> External Hard Drive Inaccessible If you receive an error message that says "Drive Inaccessible," the SimpleTech SimpleDrive may not be able to read the service area of the platter. If the external hard drive emits a loud or abnormal sound, this could mean the device is failing.
Test the drive on another computer to see if it is working properly. Otherwise, the external hard drive's surface area may be damaged or corrupted.
Replacing a Defective Hard Drive You can return a defective hard drive that is under warranty to SimpleTech. The manufacturer will exchange the device if the seal is not broken. But if you break or tear the seal on the case, any warranty claims will not be accepted and the device will be returned back to you. SimpleTech will only accept the device if you contracted a commercial data recovery company to retrieve critical data from the external hard drive and the seal needed to be broken. Before returning the defective drive, you will need to secure a RMA (Return Merchandise Authorization) approval number from SimpleTech and furnish any invoices or documentation regarding the data recovery company's services
or if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output power USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/ these can be purchased on Ebay cheap and easy to install http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d for roughly $9 or $10free postage Hope this helps.
Dec 11, 2012 | SimpleTech SimpleDrive Pininfarina 500GB...
My new WD 320 GB external drive won't detect in my pc and laptop? pls help....
Hello there,
Please try to plug it into another USB port. There is a chance that your port could be faulty. If its not with the port, try to assign the drive letter if you are using windows. You have to right click on the My Computer icon, select Manage. Once on Computer Management, select Disk Management. Locate your WD drive and right click again. Finally, click on the Assign Drive Letter and follow the wizard.
Dec 26, 2010 | Western Digital Elements powered by WD 320...
No drive letter is assigned to a USB mass storage devise. it is recognised in devises and says it is working properly. A thumb drive works OK and is assesable. This as a 20GB external HD in a Centre X 2...
Well, you can manually assign the drive letter for the Drive. To do this, follow the instructions below:
Right-Click "My Computer" > "Manage" > on the left pane "Disk Management" > on the right pane check out which one is the drive that's not available with it's drive name, after it's located, right-click on the drive and select "Change Drive Letter and Paths" or "Assign Drive Letter", give any letter you want to assign and "Ok". Close the window and open My Computer, you'll be able to see the drive with the drive letter you just assigned. If it doesn't show up, restart your computer while the external hard drive is still connected to the system's usb port.
It's also important to try it on different usb ports or on another system to make sure there's not internal problem or connector/cable problem with it.
Good luck.
Thanks for using FixYa.
Aug 10, 2010 | EliteGroup ECS P4VXASD2 VIA P4X266A...
I have WD 160GB external hard drive. when i plug in to the computer.it shows on the taskbar as USB storage device but without an assined letter . on my computer window shows nothing about the external hard...
Attach your external HD with some other computer, that will definitely appear normal, the problem is due to a virus in ur HD. Your computer's antivirus software stops it to appear. Back up your data on the other computer, format ur external HD, remove un-necessary files and run a virus scan to the files u copied from HD, Hope this will solve the problem, if not, let me know and tell me what would be the response on the other compuer
Sep 20, 2009 | Western Digital 160GB 7200RPM HDD WD1600BB...
Mac OS X 10.4.11 SimpleDrive 1TB HD appears on Desktop only occasionally. Does not appear in Disk Utility. Have transferred files to it, light is on, plugged in, just takes several restarts to appear.
If you unplug the power and USB cables from the drive (but not the computer), plug in the power and then plug in the drive, the Mac will remount the drive on the desktop. I am having the same issue, only my old HDD used to be my TimeMachine drive and now I want my SimpleTech drive for that. The issue is that when the SimpleTech drive disappears, OS X automatically uses my old HDD for TimeMachine and all my disk space vanishes.
Very ARRGH!!!
I'm trying to find a better solution, because having to mess with the cables means it's no good for TimeMachine... and very frustrating on top of it.
Aug 12, 2009 | SimpleTech SimpleDrive Portable USB 2.0...
My Lacie HD will not show up on my MacBookPro when plugged
Brand new? It needs to be formatted / erased with the disk utility to work with your mac.
Jul 07, 2009 | LaCie (300728U) 250 GB Hard Drive
USB HDD not showing in My Computer
It could be that the USB port on that computer is not delivering enough power.  Will your Drive accept external power?
May 12, 2009 | Computers & Internet
Problem with accessing my external hard drive
It's probably NOT the voltage, but the current available at a given USB port. You might try using a USB cable that has two "A" connectors on one end that connect to the computer, one for power and data, the other is just for extra power. The other end of the cable should have the appropriate connector for your external drive. By connecting the second "A" plug to the computer, you double the current available to the external drive.
Apr 28, 2009 | Computers & Internet
My external hard drive is unreadable
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it. If not - try to remove the drive from USB casing and connect it directly to your PC or put into another USB enclosure. This should help if the problem is with the enclosure itself and not with the drive.
Dec 30, 2008 | Seagate FreeAgent Pro 1TB External USB...
Need instructions for eGo portable hard drive. This shold ave come wit th purchase but did not.
there's no much need for instructions.
you just plug the hd into a USB port avaliable in your computer. the operating system should be able to recognize it a few seconds after you have plugged the hd into the usb port.
some hd may require for 2 usb to be connected to the computer for the computer to see it.. usually they come with a "y" usb cord. one goes to the hd and 2 usb type a cord go to 2 usb ports on the computer
to check to make sure the computer sees the hd. go into my computer and check if a removable storage device has appear.
also check your hd is on, some external hd may have switch to turn them on.
also check if your hd requires external power if it does it should come with a power connector that needs to be connected and plugged into the power outlet for it to work.
post your finding if you need more help.
Oct 14, 2008 | Computers & Internet
Open Questions:
See all Iomega MiniMax Desktop - Hard drive - 500 GB - Questions
Iomega MiniMax Desktop - Hard drive - 500 GB - external - Hi-Speed USB - 7200 rpm - buffe Logo
62 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
