Hisense TL2020 LCD TV
I have 12 volts going to the voltage inverter board coming from the main board until I plug the connector into the inverter board. Then, it drops to about 5 volts. If I connect an external 12 volt 1 amp DC adapter to the 12 volt lead, the voltage comes up to almost 10 volts and I can see the picture good. There is no sign of any burned components and all other voltages look fine. Any help would be appreciated. Thank you very much
Frank
  • 2,326 Answers
You should check the 12 volts capacitors on your power supply for dry or leaky, bulging conditions.
Replacing those capacitors will restore the functionality of your TV.
Posted on May 15, 2008
CAN YOU DIRECT ME TO EITHER THE INVERTER BOARD OR THE MAIN BOARD.
Hello Calvin,
I would suggest to change the input to a video with audio source to eliminate a main board failure.
If the back lights are not working, this could indicate that the inverter board is defective but there could also be a defective CCFL light failure.
You can find service parts in the link provided.
Let me know if you required further assistance. Search results for kdl 40bx450
Jun 08, 2017 | Sony Televison & Video
I have a Hisense LCD T.V. model H32V77C. Power indicator is red. When I push the power button, indicator turns blue, then blinks red 3 times and returns to blue, then shuts off.
hi sounds like there's no backlight voltage, check power supply board for any swollen caps, if ok, test the voltage on the white connector from the power board to the inverter board , with a meter should be 24v dc thanks
shaun
Mar 21, 2017 | Hisense Televison & Video
Vizio TV model E470i-AO with no backlights, was able to see the menu and run netflix with a flashlight and hear sound. Do you think is the power supply or the actual backlights?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Feb 18, 2016 | Vizio Televison & Video
I have a sanyo 37 inch tv model # DP37647. The inverter is not working and I ordered A replacement inverter board and still have the same symptoms. The fluorescent tubes are not coming on. The voltage is...
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you,
Sep 28, 2017 | Sanyo DP37647 37 in. LCD TV
TV turns on and off immediately after??
well the problem its the main board see your tv has 2 boards the power supply and the main one that its incharged of the picture and all your imputs tll you this have the same pro with my element tv made by hisense call them they sell it to me for149 but one of them told me to go to shopjimmy.com hey better price found it for 98.10 plus shipp 108 and got the info of what was causing it from the tv repair guy but he was charging too much just to fix the old board
Apr 13, 2010 | Hisense LCD1504 15 in. Television
Westinghouse HDTV TX42F430S, No picture or sound.
From where do you get the 3 volts to feed the master inverter board?
Have you measure all the voltages from the power supply to the main board?
Since the screen is ON when applying the 3.3 volts and the CCFL lights are ON, the backlight inverter boards and the CCFL lights are working. At this point there could be a LCD controller inverter board failure but if that is the case, you could still have audio but no video.
I have the module from a TX47F430S that had a broken screen, the 42 and 47 inches use the same parts.
Let me know if you need further assistance.
Mar 17, 2010 | Westinghouse TX-42F430S Television
Hisense TL2020 just locked screen and now won't unlock....
try opening the back, first remove the stand, unplug all the wire connectors to the circuit boards., wait and then replug all the wire connectors circuit boards. it may or may not work.
Dec 19, 2009 | Hisense TL1700 17 in. LCD Television
Same problem. red light flashes 3 times, but will not turn on.
The blinking light means the controller QA01 in the AV_TERM system board is booting and driving the TIMER/REC RED LED light accordingly. This failure mode is true for many conditions, not exclusively for the main PS board PE0071. It could be caused by many things, LOW B, SEINE, AV_TERM, LCD, PROTECT, etc.
Specifically for PE0071+12VDC circuit failure, which is the most common , listen for the LINE relays SR80, SR81 coming online. If several (3) or more clicks are present when applying power to the TV set then suspect the +12, 20, +32 VDC inverter is faulty.
As a quick check, you can disconnect P807B. If the relays cycle every 1-2 seconds then is most definitely the +12VDC inverter. Check for voltage level at optocoupler Q881 pin 4 and this should not be cycling. This point is the VCC for the oscillator. Repair or replace board 75002913 as necessary.
TROUBLESHOOTING: (this is my own, not the OEM !, try at your own risk!)
  1. Check for LINE1 input voltage level at inverter on sheet [4].
  2. Check for LINE2 input voltage level at inverter on sheet [3].
  3. Check for STBY +5VDC & +25 VDC ( observe correct GND REF) page [4]of PE0071 POWER
  4. Check for +22 VDC out of regulator on page [3] out of Q822 Emitter
  5. Check P809B connector for :
  • P809B (12) POWER = 3.00 VDC (+/-0.2)
  • P809B (11) POWER_SIG = 0.00 VDC (HIGH to Power on TV)
  • P809B (10) PROTECT = 0.00 VDC
  • P809B (9) ACDETECT = 3.00 VDC (+/-0.2)
  1. Check for PFC_OUT = 368-371 VDC
  2. Check for +12, +20 & +32 VDC inverter page [5] of schematic manual.
For +12 VDC Inverter, suspect components:
Q880 STR-W6765 PSR (works really hot!!)
C888-C890
D884A and related switching circuit components.
Good luck,
mrwindex
Jul 03, 2009 | Toshiba 42HL196 42 in. LCD HDTV
Low voltage on voltage inverter board
Probley got a week capacitor in the 12 volt supply, but without even a make or model number your guess is as good as mine
May 15, 2008 | Televison & Video
Hisense TL2020 TV repairing
To unlock your Tl2020 with a universal remote just go into the menu and select V chip setting. The password from the factory is four zeros (0 0 0 0 ). Once you get in you will the letter "B" nect to everything. Set everything to the letter "U". Then, turn off the television. The set should be unlocked now. Good luck !
Frank
Sep 15, 2007 | Hisense TL1700 17 in. LCD Television
Televison & Video Logo
228 people viewed this question
Top Televison & Video Experts
