Lexmark Optra T614 Laser Printer Logo
Posted on Sep 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lexmark optra t610 invalid refill error change cartridge......how do i reset the printer to disable the error
  • Official Brand Answer 3,344 Answers
  • Posted on Sep 14, 2010
Anonymous
Level 0:
Answers
3344
Questions
0
Helped
923774
Points
5508
The error may not be specifically a toner cartridge problem but may be due to a stuck cover open switch on the printer. Perhaps this article on Error: "Invalid Toner Cartridge" or "Invalid Refill" will be able to determine the root cause of the problem. Just click on this link: http://bit.ly/dupj2m. Just make sure you are using a genuine Lexmark toner in the printer. If you need further assistance, you can also contact Lexmark technical support. Thanks.
I want to change language - lexmark optra t610 printer
You can change the language on your Lexmark Optra T610 by pressing right arrow Menu button 6 times -> select Printer Language (first option to appear), hit Select -> select preferred language, hit Select button to save.
Hope this helps. Thanks.
Optra T610
If your printer only prints black pages it will require the high voltage power supply to be replaced. this will fix your problem
1helpful
Invalid engine code on Lexmark Optra T610
Sounds like you've experienced a fairly common problem with Lexmark Optra printers. The engine board has more than likely failed. Rather than go to to Lexmark, try this site for a less expensive replacement board...
http://www.partsnow.com//
I have a Lexmark t610 - I am getting 'Invalid Engine Code' - can someone help!
Here's an article in the Lexmark website that would describe the error code on your printer. It also includes some steps you can follow to remedy the problem. Just click on this link: http://bit.ly/aKbYSK . Hope this fixes the problem. But, if you need more assistance, just make a comment so I can get back to this. Thanks.
Reset password on a lexmark optra t610 printer
Please contact Lexmark Technical Support for assistance with this request.
Stopping the lexmark optra t610 from resetting
sounds to me like a dead back up battery. I think you'll have to call a dealer to confirm this, and they would have to replace it for you
INVALID ENGINE CODE
you can get bat file from lexmark that will reprogram the nvram chip. the problem is when those errors start it because of a corrupted control code. the nvram has reached its read write max. there is also an eprom that goes bad. we replace them both
Our lexmark Optra T610 laser printer keeps telling me to "change tray one to plain paper"
verify paper tray is set for correct paper. print the configuration menu and check the paper size for tray 1. If it does not have right size, examine the tray bottom to see if slider is in place
Optra t610 error 935/933/934
replace printhead - scanner assembly. The scanner motor is not working correctly. Need to remove side covers, back of printer assembly, the top cover. Printhead is below the top cover
LEXMARK
That error indicates that you need to replace the Engine board. The part number is 11K1416, a service tech would need to replace it due to settings needing to be reset.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
