I have an old tft monitor - I just want to check it is time for the bin. I have tried it on 2 systems. When I plug it in it comes up as per normal. After 1 minute approx it goes into a mode where the picture is very feint - you can just about see it if you shine a light on it. It will then stay like that forever. The process can be repeated by removing the power lea and reinserting it. Many thanks Roger
  • roger hiley Sep 14, 2010
    Thanks for that I will throw it in the bin.
    best regards Roger
  • 6,993 Answers
the monitor is obviously faulty and needs to be repaired. The problem is from the display board of the monitor.
You can take it to a repairman to fix it for your and if the cost of repairs is so such, then maybe you then put it in the bin and get another.
Good luck.
Posted on Sep 14, 2010
Neither picture is displaying on moniter nor sound is coming (DELL TFT moniter)
Which is a dell tft or compaq crt monitor ?
The Dell 1504FP is a flat panel LCD monitor that has a viewable area of 15 inches.
The monitor, which uses TFT technology, is designed to be used in a home or office and displays video at a resolution of 1024 x 768 pixels.
Over time, you may encounter problems using your Dell 1504FP monitor or it may cease functioning altogether.
Fortunately, there are variety of ways that you can repair the monitor to get it back up and running.
Shut down your computer and press and hold the power button on the side of your Dell 1504FP monitor if your monitor has a blank screen.
Unscrew the VGA video cable that connects the monitor to the computer.
Power the Dell 1504FP monitor back on and wait as it launches into the Self-test Feature Check.
During this period of time your monitor will make settings changes to ensure that it functions properly with your computer.
Firmly screw the VGA cable back into the rear of the monitor to ensure optimal video quality. Power both the monitor and computer back on and wait for your computer's desktop to appear.
Power off your Dell 1504FP monitor if the screen is dirty.
Wipe down the monitor using a dry microfiber cloth to remove any dust particles or smudges that have accumulated on the screen over time.
Power the monitor back on when you are complete and resume using it.
Press the "Auto Adjust" button on the right side of your Dell 1504FP monitor if the display is blurry and images appear out of focus.
Unplug the monitor's power cord for thirty seconds if the problem persists.
Plug the monitors power cord back into the rear of the device and power it back on.
This will reset the monitor and your display should now be focused properly.
http://support.dell.com/support/edocs/monitors/1504fpis/en/trouble.htm
Troubleshoot a TFT Monitor
TFT monitors can suffer from many potential problems, ranging from simple screen brightness issues to disconnected inverter or LCD cables.
These can cause video- and backlight-related failures on your TFT monitor.
Fortunately, you can attempt to repair these problems, even if you have no experience fixing a TFT monitor.
The only tool you will need is a Phillips screwdriver, although opening your TFT monitor will likely void its warranty.
Check the brightness settings on the TFT monitor.
There are dedicated adjustment keys on the bottom face of the TFT monitor.
If it is a screen incorporated into the design of a laptop, you'll find monitor adjustment keys on the top row of the laptop's keyboard.
A TFT monitor that has its brightness turned all the way down will appear to be almost completely dark.
Ensure the TFT monitor's power cable is still plugged in, if it is an external monitor. In the case of a laptop, make sure that the power cable is plugged in or that the battery is properly charged.
Disconnect the TFT monitor from the power source. If the TFT monitor is an external model connected to a computer tower, disconnect the video cable as well.
Remove the battery from your computer if you are using a laptop.
This is an important safety measure.
Turn the laptop over and slide the battery release mechanism over.
This mechanism is just below the horizontal outline of the battery on the underside of the laptop.
Remove the screws on the bezel of the TFT monitor.
The bezel is the plastic piece surrounding the TFT screen.
The screws will likely be covered with plastic seals for aesthetic purposes, so pop these seals off with your fingers and remove the screws using a Phillips screwdriver.
Pry up on the bezel gently and remove it.
Start at one corner and work along the bezel's perimeter with your fingers.
There will be small plastic latches between the bezel and the rest of the computer you'll need to disengage.
Check the TFT monitor's inverter cable.
This black cable lies at the bottom center of the monitor and should connect to a socket on the inverter board, which is the green color horizontal strip that lies just below the inverter cable.
If the cable is loose from the board, the TFT monitor's backlight will fail. Pull up on one side of the socket and slide the cable back in, then press firmly down on the socket to lock it down.
Remove the metal brackets on either side of the exposed TFT monitor if the inverter cable fix does not solve your issue.
There will be two to three screws in each bracket that must be removed using your Phillips screwdriver.
Pull the TFT monitor carefully away from the rear casing of the display to reveal the LCD cable. This cable runs from the back of the TFT screen and should be connected to a socket in a similar fashion to the inverter cable. If it is disconnected, lift up on the socket, slide the LCD cable back in, then press down on the LCD socket to lock it back down.
NOW FOR SOUND
if you can get a screen
Click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question / exclamation? ! mark or a red X Right click to reinstall drivers
If your computer came with a motherboard disk the drivers could be on it
or you might download slimdrivers.
Rather doing a driver hunt
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
Note: it will find all of your outdated drivers
This is a free driver solutions
which will automatically search for and find the correct driver
You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
It might take some time being free
Aug 09, 2013 | HP COMPAQ 7540 CRT Monitor
I have a Dell 1704 FPVt monitor I use it in conjunction with an touch board with a monitor split cable. when I plug the team board in the dell monitor goes blank. It doesn't do this with the old m
Isolate the problem per above. Eliminate the monitor, split cable and software settings so that each, individually work. Then eliminate team board - do you have a spare?
It could mean sharing the monitor signal means weakens it so that one can display and the other does not work. Prove it with a different source computer. Don't know if buffer devices exist or how to increase input sensitivity.
Mar 07, 2013 | Dell 1704FPVs 17" TFT LCD Flat Panel...
I have a 22' Dell monitor that goes black after a few minutes. I can still see the images in the background. The monitor's power stays on and when I turn it off then back on it comes back on with such a...
Hi
I think you have TFT monitor? If you are having TFT, the issue was occurring because of two problems.
1. Might be your monitor FL invertor was faulty.
2. Or your monitor FL light having problem.
Check with any local service person. Whether FL invertor or FL light having problem?
If you found the solution is helpfull please vote for me, Thank you.
Mar 22, 2011 | Dell Computers & Internet
Resolution problem with AOC TFT 185W80PF
Monitors don't need drivers to function. Either you need to configure it or it's dead.
Mar 16, 2010 | AOC 19" LCD HDTV Monitor
Every time I turn on the monitor it will work for 1 second and then gets a black screen
Hi ,
Check when you boot the system is there any display coming and when Operating system boots you get any Balck screen if it comes then there is a issue with the Graphics card in the system.
Dec 30, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
15" HP Pav. monitor turns on for a second but immed blacks out
Pls ask your dealer about the warranty..It depends as per the market.. If the light is comming then replace the AD card other wise The problem with the inverter card.. replace ...
Jul 06, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
Samsung SyncMaster 243T blacklight
indeed, probably the backlight...
Nothing to do about that but repair or replace, sorry...
Nov 13, 2008 | Samsung SyncMaster 243T (Black, Silver)...
SyncMaster 510N 15
It might be the connection loose of power cord problem or check your TFT power connector inside the TFT if you can open the TFT screen!!! It may be dry solder….
Other wise go to repairer and do the same….!!!
Dec 06, 2007 | Samsung SyncMaster 510N (Silver) 15 inch...
Open Questions:
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
