Question about Intel Motherboard
Gigabyte GA-X85a-UD7 can not start, LED shown error code 69
I need the front panel connections location, which ones go where for the ga-73pvm-s2h motherboard
Gigabyte has the manual for the GA-73PVM-S2H on the product support site: http://www.gigabyte.com/products/product-page.aspx?pid=2691#manual . The full manual is near the bottom of the list. The direct link to the English version of the manual is http://download1.gigabyte.us/Files/Manual/motherboard_manual_ga-73pvm-s2h_e.pdf . The Motherboard Installation Guide at the top of the list is a generic manual for all motherboards.
The front panel connections are shown on page 28 of the manual. There are two lines of pins. From left to right, the inside line of pins are the Power LED +, Power LED -, Power Switch +, Power Switch -, then the Case Speaker +, Case Speaker -. (The speaker - is next to a Case Fan connector; so there are a couple of blank spots between the speaker + and - pins.) On the line of pins at the edge of the board, again from left to right: HD LED +, HD LED -, Reset Switch -, Reset Switch + . There is no contact on the last pin in this group.
I hope this helps.
Jun 06, 2016 | Gigabyte Computers & Internet
Sound card interference. Gigabyte. I hear background sound...
Hello the sound driver could be the wrong one.
Download the right one here:
http://www.gigabyte.com/products/product-page.aspx?pid=3251#dl
By selecting your windows system 32 or 64 bit.
Please uninstall the old driver, before installing the new.
If you have a microphone connected, please lower the gain level, for that and see if it helps.
Good luck
Aug 19, 2012 | Gigabyte GIGA-BYTE GA-X58A-UD7 Desktop...
How to connect wires power Led+ & power Led-, Hdd LED, Reset SW, power SW in Gigabyte GA-81865GME-775 Dual Core Motherboard
You can download a manual from this WEB site.
http://freemanualonline.blogspot.com/2011/04/gigabyte-ga-8i865gme-775-rh-manual-user.html
Jul 09, 2011 | Computers & Internet
Installed new Gigabyte GA-P67A-UD7 mother board. Have checked the connections numerous times. It starts up and then shuts down in about a sec. I even unplugged the 8 pin 12 v connector to try and locate...
When mounting a motherboard to the case you need to add some spacers between them so the MB doesn't contact the case directly, most the MBs today have a protection to shut down so they don't get burned
Try starting your computer outside the case (you can use a key or a screwdriver for the power pins to start it).
Feb 14, 2011 | Intel Motherboard
Hi.i have a motherboard gigabyte ga-8i945pl-g and i don't know where to plug , hdd led , power led , restart into the motherboard
user manual
http://www.gigabyte.com.ro/Support/Motherboard/Manual_DownloadFile.aspx?FileType=Manual&FileID=16542
Oct 16, 2010 | Gigabyte GA-8I945PL-G Motherboard
Connecting hdd led lead and power led lead,where do they go ?
Hi, There are 3 versions of this motherboard; 1.0, 2.0 & 3.3, but the layout is identical. The general layout is shown in pins.jpg. For the power led, the white wire goes to the (-) terminal either pin 2 or 3, both are MPD- while the green goes to the ( ) or pin 1 (MPD ) as shown in powerled.jpg HDDpins.jpg shows the connection of HDD led, the white goes to pin 3 or HD- while the red goes to pin 1 or the HDD . I cropped these images from the manual which is also available at the gigabyte website. Hope this gives you some ideas and workout of you. Good luck and pls post again how things turn up. Kind regards.
Aug 15, 2007 | Gigabyte GA-965G-DS3 Motherboard
Intel Motherboard Logo
239 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
