Question about Yamaha Boating
How to access impeller on 2m (2hp) mariner outboard engine...I think its made in the 80's...normally you drop gearbox but this is direct drive
SOURCE: Yamaha outboard engine
Procedure for carb. adjustment for 1992 Yamaha 30 h.p. 2 cycle outboard motor
Posted on Dec 30, 2008
  • 11 Answers
SOURCE: mercury 4 hp outboard engine wont go into gear
The lower gears arent hard to change, if your in there might as well get all of them there are only a few. the lshift lever does nothing but move the gears forward and back to engage forward and reverse, just pay extra attention to keep it water tight when done. A dealer should have the assembly chart for easy fix
Posted on May 01, 2009
finish line
  • 207 Answers
SOURCE: 1999 Mercury Mariner 9.9hp outboard motor
should be on the side with a lever but could you give me more info please
Posted on Jun 27, 2009
  • 3 Answers
SOURCE: Mariner 2 hp outboard engine (1985) not pumping water
My Mariner 8 has a thermostat fitted. It only pumps water when it heats to normal temp.
If your engine stops, it may be a fuel problem. Check the plug and go to Marine Doctor (a) fuel diagnostics, (b) spark plug diagnostics, sections. PK
Posted on Aug 14, 2010
Testimonial: "Thanks Peter, we will certainly try what you have said."
muffteck
  • 202 Answers
SOURCE: 25 hp mariner outboard runs ok for 2klm then
does it have the old type timming advance (non adjustable) get it timming through the cd switch. if so could be this but o/b man should have ched this change your gas hose and pump bulb if you sure no electrical problems
Posted on Mar 16, 2011
Procedure to replace 130hp honda impeller
Go to http://marine.honda.com/support/manuals and search your engine. Also try http://m.marine.honda.com/support/manuals
Aug 08, 2014 | Honda Water Pump Impeller Outboard 35, 40,...
How do i replace shift lever on a mercury 6hp 4 stroke
shift lever has a bolt in it and shift rod you need to remove powerhead complete to access also remove gearbox !
May 04, 2014 | Mercury Marine 4hp & 6hp Stroke Outboards...
Coleman outboard overheating
You should change your impeller.
It is located at the top of the gearbox, around the vertical engine shaft.
First, disconnect the gear control. Underneath the steering bracket, you'll see a long nut with a counternut. ( Maybe you'll have to shift FWD or BWD to get better access ). Loosen the counternut 1/4 turn and then turn the long nut up ( 2 open box wrenches 10mm ).
Then remove the 4 bolts holding from lower to upper the gearcase ( just above the anti-cavitation plate )
The gearbox should drop down easily.
Then remove the 4 screws of the waterpump ( top of gearcase, around the long vertical shaft ). Lift the waterpupp housing, you'll get the impeller.
To reassemble the waterpump, grease the cup in the housing with PTFE or silicone grease, and while pushing the housing down over the impeller, rotate the shaft clockwise.
Reassemble all the rest in reverse order.
Check and adjust the gear shifting...
Apr 01, 2014 | Coleman 9.9 HP Manual Start Outboard Motor...
How to Change the impeller on Suzuki 140 outboard motor
Suzukis are normally a mission to work on especially if it is a two stroke,so I suggest you get a workshop manual.all gearbox bolts must be undone,the gear linkage is under the bottom carb,this is the tricky part,you have to loosen a nut at bottom of gear arm where gearcable fits,then push in with screw driver,this releases gear change shaft.the biggest problem is trying to see what you are doing.good luck
Oct 08, 2013 | Suzuki Outboards - Zinc 115-140Hp Outboa
Where and how do u get to the water pump it is a 1978 105 chrysler outboard do u have any diagrams? BOAT
all the outboards i have repaired require the removal of the lower gearbox to get to the water pump impeller ,it sits on top of the gearbox driven by the engine drive shaft in a little housing
May 29, 2011 | Car Audio & Video
Jul 26, 2010 | Boating
Nov 07, 2008 | Boating
Boating Logo
236 people viewed this question
Top Yamaha Boating Experts
Phil Walker
Phil Walker
Colin Stickland
Colin Stickland
Mike
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
