Question about Teac R-H300 Dual Cassette Deck
Hi, I have a TEAC R-H300 Casette Deck. Could you possibly advise me how I can assess the Heads, Capstan and Pinch Roller in order to clean them directly? Unfortunately I tape that was playing got jammed and after removal when I play a tape now the sound results in a severe case of 'wow and flutter' - there may be tape matter still caught around the capstan/pinch roller but I'd need to access these directly to eliminate the problem, Any advice would be much appreciated Thanks Glenn
  • Teac Master
  • 1,267 Answers
Hi Glenn,
The correct way to service a unit like this is to get a service manual and then see how the transport comes out of the unit- the cleaning of the tape path is always a pain when dealing with this kind of deck. That is why I stick with the well known C-3RX and like models. They will last a very long time but are not the size of this unit.
Posted on Mar 05, 2013
  • 199 Answers
SOURCE: Where can I buy a Capstan drive belt for a Teac
Go to a consumer electronics repair shop, preferably an old mom&pop op and they will have what you need. If not they can order it for you when they do stocking and save you shipping money from any internet company. I used to work at one is how I know. Have a good one
Posted on Aug 07, 2009
  • 141 Answers
SOURCE: I have a TEAC reel to reel stereo tape deck, Model
That's a rarity but easily fixed. Before pulling anything apart spray some penetrating oil (WD-40) or similar into a small container. Then with a cotton bud soak the tip in the penetrating oil and apply it to the base of the capstan where the bearing is. Allow this to sit for a few hours and even repeat it if it looks to have soaked the oil up. NOW, with the power lead out of the wall socket remove the top cover of the deck. You will have to remove a few knobs and mode switches too. Now see if you can rotate the capstan flywheel by hand. It might take a bit of pressure to get it to turn but once it does keep going until it starts to rotate freely.
By the way, check that the capstan drive belt is in one piece and not slipping first.
If it's running freely then reassemble the cover and other pieces tyhen put a few drops of light oil on the capstan bearing (sewing machine oil is ideal) Do this because penetrating oil will dry out after a while. That should fix it.
I'm assuming you know exactly how to thread the tape through the machine. Don't forget to position the stop lever on the upper side of the tape otherwise nothing will operate. If you are unsure about that write back and I will elaborate.
Posted on Apr 24, 2010
Grubhead
  • 5309 Answers
SOURCE: I need a capstan drive
Just measure the diameter in MM and put the result into google with the words 'cassette drive belt'. Belts are not maker specfic.
Posted on Nov 06, 2010
  • 115 Answers
SOURCE: I have a Teac A-1500 reel to reel tape recorder
I cant persobonally help you but you can try the manufacturers web site, and call for a replacement belt. Possibly try Radio shack and make a make shift belt.
Posted on Mar 31, 2011
SOURCE: I have a Realistic TR-3000 reel to reel tape deck.
You have to take the back cover off. You also have to take the knobs and guides off as well. The guides unscrew.
Once the back cover is off, there are about 6 screws that hold the cover on.
Posted on Apr 23, 2011
Why does tape go slow, then stops?
Gary hi! I am not sure whether your machine is solenoid controlled but if it is then I would suspect the solenoid that operate the capstan roller to be overheating, I had the very same problem with my Studer and Revoxes and when I smeared some heat sink compound (Available from electronic stores selling components like Radio Shack etc.) and fit if the chassis is cast aluminium like the better manufacturers use,as a heat sink. You can chech the belts and the lubrication of the drive system but I doubt that. Clean the capstan roller with denatured alcohol or cleaning alcohol.
Nov 11, 2014 | Audio Players & Recorders
Teac x-1000r tape skewing off pinch roller
In the Teac X1000R this is most often caused by dirty Pinch Rollers and secondly bu a ring of oxide or a wear mark being developed into the capstan shaft. If cleaning the Pinch Rollers does not do it then a trip to the technician is required. These decks also have a touchy servo tension system that if upset can also contribute to the failure of this kind. I still work on these in Chicago area all the time. Russ the other ex-Teac guy is in New Jersey. Be careful of local shop with this model as many of them turn up the servo tension to resolve this problem which is the wrong thing to do that then burns out parts and the cost goes up. I have seen this mess many times as people bring me these decks as a last stop-- of course I fix then correctly with the use of the Tentelometer as is required. Pinch Rollers are often reconditioned with Naphtha after cleaning then with Denatured alcohol.
Teac Tascam Repairs Skywave Tape Deck Repair Bensenville IL
Mar 14, 2014 | Audio Players & Recorders
TEAC R-H300 Forward Play Fault
The unit need some work by a technician. The bad thing about the drawer type decks is that it makes it hard or impossible to clean the tape path. I have not seen one of these but I could probably fix it.
Some of your description sound like a loose capstan belt and then other times the Pinch roller is not engaging- they may be related if the mechanism is tied to the capstan motor system.
Sep 11, 2012 | Teac R-H300 Dual Cassette Deck
Teac a-3440 will not play
Hi Gary,
This makes me think the Capstan Shaft is not turning either due to a broken or stretched belt or that the capstan motor itself has stopped working. This may be a job for a Technician. You first determine if the Capstan is turning or not- this is the metal post that contacts the Pinch Roller that rotates and is the way the deck gets it's speed regulation. If it is not turning look inside the deck from the side to see if the flywheel is turning and that the belt is on that flywheel. Lastly make sure the capstan motor is turning.
Beyond that a Tech may have to take over from there. I am in the Chicago area and can repair it if you are close. Many people send me units from all over the USA anyway.
My name is Sam. I operate Skywave Tape Deck Repair
skywavebe@sbcglobal.net if you need my help.
Aug 17, 2012 | Teac Audio Players & Recorders
How do you thread a teac model 40-s tape player
There is no such model.
If you have a A4010S. The tape comes off the reel under the tension arm, over the reverse sensing post, under the heads and lifters, over the
capstan shaft (in between the capstan and Pinch Roller) then under the right tension arm and on to the take-up reel.
Dec 15, 2011 | Teac Audio Players & Recorders
Thaks for helping. My tape deck door has suddenly stopped working. the tape is inside and when i turn on the wpower there is a clicking sound. it is a TEAC AD-500 CD player/reverse cassete deck
Without physically looking at the cassette deck myself, I cannot be 100% sure the tape is wrapped around the pinch roller and capstan. The capstan is the chrome rod which the rubber pinch roller pushes to regulate the speed of the tape moving across the head. However it is approximately a 90% chance the take up reel for the tape stopped working from a bad tape or a loose belt which drives the tape take up reel. The clicking sounds like it could be the auto reverse solenoid because it thinks the tape has reached the end of play. The fun part is to remove the tape which you may have to disassemble the front panel if you cannot gain access to the tape from the top or bottom. You will need to cut the tape and remove it from the capstan and pinch roller to open the cassette door. Sometimes you can remove the capstan to free the tape. Once you have cleaned all the tape out of the unit make sure the belt for the take-up is good. If it is glazed, cracked, loose or broken order a belt. Clean all the pulleys and capstan and replace the belt. Your unit should be functional after the above procedure.
Jul 14, 2011 | Teac R-H300 Dual Cassette Deck
The tape plays songs so fast sounds like donald duck. The speed the tape is feeding is to fast.
Hi, the casette deck has a mechanical system (servo-driver) most of the problems that happen when in your case, plays song so fast is that you look at the pinch roller. The pinch roller is a rubberized free spinning wheel typically used to press magnetic tape against a capstan shaft in order to create friction necessary to drive the tape along the magnetic heads with a normal tape speed if the pinch roller brakes, get lost from his place or got dirty then you get this fast sounds play, check the pinch roller if still good in his place or clean his rubber with alcohol, then the problem should be fixed.
Jan 29, 2011 | Sony CD Radio Cassette Boombox, CFD-E90...
Threading Diagram
Send me a picture of the front of the deck and I'll mark the picture with the threading pattern, and e-mail it back. ****@rsaaa.com
Jun 12, 2008 | Teac Audio Players & Recorders
Teac R-H300 Dual Cassette Deck Logo
145 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
