Question about Whirlpool Duet GHW9150P Front Load Washer
My Duet washer stinks so much. The wash does not come out smelling good. It is clean but it doesn't smell good. I do use those cleaning tablets but it still stinks. It has over-suds many times where the suds leak out the back of the wash.... Should I get a repairman? What could be causing the bad smell and what can I do about it???
    Problem Solver:
  • 6 Answers
I have found that using a l/4scoop of oxi cleaner any brand will do along with my regular wash detergent helps keep the odor under control . I leave my door open to the washer when not in use. Occasionally I will clean under the gasket with a mild cleaner. Remember the front loaders use less water and therefor less detergent. Good luck.
Posted on Sep 14, 2010
Obnoxious smell from washer
I use "Affresh" every couple of weeks to keep the washer smelling good. Here is the product to order.
Nov 23, 2012 | Equator EZ 3600 CEE Front Load Washer /...
Moldy smell in clothes, especially towels
need to clean the bellow ( rubber around door). theres a tablet you can buy called "Affresh". It will help to remove the moldy smell. just throw it in washer and run through a regular wash cycle. no clothes, just the tablet. If there is a clean cycle on the machine then use that cycle. Whenever you're finished washing, you should leave the door open for about 20-30 minutes so unit can air out. Also you should wipe around the glass and bellow after each use.
Mar 19, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer smells horrible. The clothes after being washed smell horrible. I have left the door open. I have run bleach thru there 2 or 3 times in a row...didn't help. Have also run baking soda thru...
Despite washers remain with some residual water in the pump and wet components it should no be so critical as you are indicating especially if you cleaned it as you stated. You are not describing the smell but try to isolate the source, like the washer drainage point (odors coming from sewage), behind the washer, and inside or under the washer where the mechanical components are. It wouldn't be surprising to find a dead rat, lizard or pests in there. Sometimes even wet laundry falling behind the appliances stinks strongly. Be safe moving and reaching on difficult places. Good luck.
Dec 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer smells even after cleaning cycle
It sounds like an air vent is either missing or clogged. That gurgling usually indicates some sy phoning action going on which is drawing water out of a gas trap. Hence you are getting sewer smell into the washer.
Thank you !!
Jun 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Clothes stink
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
May 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Laundry stinks
I find that the dryer does not dry the clothes enough. The washer can take a lot of laundry at one time but the dryer is not able to handle the load. The stink usually comes from a bit of moisture left in the the clothes, especially the towels. Break down your dryer loads or dry them on a timed cycle for a longer time.
Jan 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Duet washer with a severe odor problem. We keep the door open when it is not in use. We have tried the Affresh tablets with no success. I am currently running a bleach cycle weekly, and it only...
The Duet has a filter trap that's pretty easy to clean. There could be debris catching residue and not allowing the washer to drain right. Remove the toe panel with a torx bit and turn the filter handlt to the left. Have towels handy because there is always a gallon or two of water left in washers after they drain! Cleaning the filter trap should be regarded as regular preventive maintenance.
Leaving the door open will actually make the problem worse because it dries out the odor-causing residue and makes it much harder to remove. If your washer stinks with the door open or shut it's time for a good cleaning before it gets worse! The area of heaviest buildup is always between the inner stainless tub and the outer plastic tub. After your washer has been cleaned you'll need to change your washing habits so odor doesn't return. If this doesn't remove bad odor you'll need a good washer cleaner.
To compare washer cleaners watch this video
http://www.youtube.com/watch?v=Ua6OJPn0-fU
Apr 12, 2008 | Whirlpool Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
120 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
