Question about Canon MV600 Mini DV Digital Camcorder
Hi my camcorder has a black screen with a red flashing symbol. it does still play tapes. is this a major problem.
    Genius:
  • 1,812 Answers
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Posted on Sep 14, 2010
  • 30 Answers
SOURCE: LCD won't project
You may have a problem with the image sensor device (CCD). From October 3, 2005 through October 2, 2007, Sony will repair, free of charge, affected products exhibiting the above-mentioned problem where it is caused by the image sensor device. Sony will also cover the cost of shipping and handling from and to addresses within the United States and US Territories for service to correct this issue. To see if you have this problem: Power On your camcorder (make sure the battery is fully charged). Check the LCD screen and verify that the display icons are turned on. If you cannot see the icons, press the Display button until the icons are visible. Put a tape in the camcorder. With the lens cap off, record some video. NOTE: Be sure to speak during the recording so the video will contain your voice. Rewind this section of the tape (using tape counter to verify start of your recording). Play back the recorded video and use the LCD screen on the camcorder to view it. You should hear the audio you recorded and the Display icons/text will still appear. If your camcorder is affected by this CCD issue, the picture will either be extremely distorted, or there will be no visible picture (just a blank LCD screen with the display icons still visible).
Posted on Mar 27, 2006
SOURCE: Help with my Panasonic nv-ds1 camcorder ? ? ?
I had the same problem with my camcorder. I removed the battery for about 3 days and when i turned it back on it worked. is there a battery in camera to keep the time and date? maybe it is in safe mode and by removing power for long enough it will reset itself. paul sa
Posted on Jan 09, 2007
cropp
  • 377 Answers
SOURCE: Sony Analog Camcorder quit playing the tape. The motor runs, but the screen is blank
hi dear
just using a tape cleanr hi-8
after that record your video using a tape cleaner, it's about $5 usd
oke
cropp
Posted on Mar 21, 2008
Bubbabear64
  • 2794 Answers
SOURCE: 8mm analogue camcorder tape playback at double speed
If you ran it through that many 8mm players, I'm going to say that the tape has something wrong with it.
You can see visually if there is anything wrong with the tape by releasing the cover by moving the tape and visually inspect the tape for anything that could be frayed. Usually you can see it on the bottom of the tape.
Sometimes the takeup can be messed up in the tape too. Once you release the tape cover, you can turn the white wheels to see if there is any slack in them.
Good luck on that.
Posted on Jun 11, 2008
welcomejee
  • 10594 Answers
SOURCE: The no tape and eject symbols are flashing at the same time.
Those signs means Record tab on tape is ON, eject tape and check record tab and make sure to set it on Record position.
Posted on Feb 26, 2009
Sony CCD FX500E ejects tapes
Mechanical fault. Contact any service technician; or the authorized service centre for Sony. Electro help
Nov 29, 2014 | Sony Video Cameras
Play back of video recorded on a different camcorder
sir,
you must have run a dry run before recording them in blank tape
Jan 11, 2008 | Sony Handycam CCD-TRV87 Camcorder
When i try to record it dosent let mi and in the screen it shows a tape with a line through it. what do i do?
The tape with line through it indicates that there is some issue with tape/tape mechanism. I believe that the tape symbol is as follows:
If the tape warning indicator flashes slowly, the reason may be.
  • The remaining tape becomes shorter than the length of five minutes recording.
  • No tape is inserted
  • The write protected tab on the cassette is set to LOCK(red).
If you're confirmed that the reason is not the first and second, it should be because of the write protected tab on the tape.
Don't worry, I will help you with that. Please see the below picture to view the LOCK slide switch:
If the tape with line symbol flashes quickly, it indicates that the cassette has run out of tape.
If the issue persists, please follow the troubleshooting steps and check if that helps.
  1. Reinsert the tape.
  2. Reset the Camcorder by pressing the reset button behind the LCD panel using a sharp pointed object.
  3. Perform a power resetting
  • Turn off the camcorder. Disconnect AC power adapter. Remove the battery pack.
    Move the POWER switch to the CAMERA position for 15 seconds.
    Move the POWER switch to the OFF position.
    Reconnect the AC power adapter or reinsert the battery pack.
    Turn on the camcorder.
    If the issue persists, service may be required.
    I hope performing the above steps should resolve the issue.
    If you need any assistance please get back to me.. Thanks for understanding.
Feb 17, 2011 | Sony Handycam DCR-TRV250 Digital Camcorder
My Sony Model CCD-F301 camcorder is not working properly and it flashes the eject symbol when I am trying to play a tape or rewind or fast forward... What can I do to fix the problem?
Your ccd-f301 camcorder if as old as the hills and should be replaced. I can fix them but it a total rebuild due to major capacitor failure . Then also can have issues with the guide arms coming off the guides and very loose guide rollers. It's a 20 year old camcorder. What is going on with your ccdtrv608? that is a cool camcorder. Larry's Electronics ledstiles@hotmail.com
Apr 19, 2010 | Sony Handycam CCD-TRV608 Camcorder
Feb 26, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
Code C:31:23 quikly flashing over a underlined triangle...HELP!
Error C:31:23 problem means that System Control is not getting Supply Reel pulse. This can be electronic or mechanical problem in camcorder.
Qualified camera tech will fix it properly.
Feb 22, 2009 | Sony Handycam CCD-TRV318 Camcorder
Flashing red symbol like a bowl crossed out
it means you have no back up battery installed to save time/date info. I know on the GL2 if you open the LCD screen there is another small plastic tab you can open and insert a relatively small battery. Do it and the icon will disappear. Otherwise its no big deal. If you dont need time/date stamps on your tapes then there is no need to install the battery unless you are just annoyed.
Feb 22, 2008 | Canon GL2 Mini DV Digital Camcorder
Flashing icon
I just fixed mine accidentally... Try this: with Camera on open tape deck, then manually press in the tape cartrige till it clicks in and you hear the tape gears turning then close the tape door last. email me if it works for any of you. lbclassics@gmail.com
Nov 27, 2007 | Canon XL1S Mini DV Digital Camcorder
Tape rejection - droplet symbol shown
Hi there, the small water type symbol means that the internal dew sensor is activated. Please use the fan (low temperature) or leave it in a warm place for some time. If you need more info please advice.
Apr 26, 2007 | Sony Handycam DCR-TRV130 Digital Camcorder
Canon MV600 Mini DV Digital Camcorder Logo
149 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
