Question about Chili Systems ChiliBox Network Router And NAS Server (S5564110) Firewall
Change in IP resulted in inablitiy to access the box
Our computer guy changed the ip on the chilibox, restarted it and we couldn't access it anymore. They brought it into their shop and said the hard drive was crashing?
Is it possible to access the box another way, change the ip and get back the data?
  • Lisa May 15, 2008
    It will not ping
  • Lisa May 16, 2008
    Is anyone going to help me with this?
    President:
  • 1,944 Answers
What happens when you try to access the router?
Posted on May 15, 2008
HOW TO CHANGE PASSWORD
Access your router by entering your IP address into the IP address tool bar at the top of the page. The linksys address is 192.168.1.1.You will be prompted to enter the user name & password. Enter admin for user name and admin for the password. It will probably update firmware automatically and you will now have unrestricted access to the system's utility software including change of password.
Jun 27, 2015 | Linksys RV082 10/100 8-Port VPN Router...
I've forgotten the username and password for my router. The router I have is the DSA-3200. Airport wireless G public/private gateway. Is there any way I can reset the password to default
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Dec 29, 2010 | D-Link AirSpot DSA-3200 (F56772) Firewall
My computer is telling me "limited or no connectivity." I spoke with my cable company and they said everything was ok on their end and to check with my modem. what should I do?
This error comes when there is same ip address in 2 computers.
So make sure in networks there are not same ip address.
You can also solve this issue with DHCP .
Enable DHCP in router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
Enable DHCP if you want to get ip from router.
Then set "ip get automatic " in network adapter property.
Mar 11, 2010 | HotBrick SoHo 401 Firewall
Pix 515 E allow few websites only.
Do the nslookup for the three websites and write an access list to permit the traffic only to the said website ip addresses
Eg.
1. go to dos prompt
2. type "nslookup"
3. type "www.rediff.com
Note : You will get the ip address of the websites
4. Create an object group for these websites
5. Add ip addresses of the websites
6. create an access-control list element to permit the traffic from your circle office to this object group for port tcp 80 and 443
You are done
Mar 09, 2009 | Cisco PIX 515E Firewall
Chilibox CB-160 GUI / Web default username and password?
Hi billmanjd,
I used to work for Chili Systems so I do have the information you're looking for:
username: admin
password: password.99
Hopefully you can get access and do what you need to do. If you need any other help, reply to this post. Also, if you would like the quick-start or configuration guides, I have those too.
Alistair
Jan 30, 2009 | Chili Systems Computers & Internet
Port Forwarding
Instructions for DG834, DG834G, DG824M, FR114W, FM114P, FR114P, FR328S, FVL328, FVS328, FVS338, FVX538, FWAG114, FWG114P, or FVS318v3 These routers do port forwarding by assigning port numbers to a "service" associated with the application you want to run. "Rules" are set for particular services. Rules block or allow access, based on various conditions such as the time of day and the name of the service. To Create a New Inbound or Outbound Rule 1. Submit the router's address in an Internet browser. (The default is 192.168.0.1). 2. Enter the router's username and password. 3. From the main menu, click Security > Rules. 4. Click Add for inbound or outbound traffic, as appropriate to the application you are planning to run. 5. Select the Service. The services the router knows about are listed in the drop down. If the service you want is not listed, add it as described in the next section. 6. Select the Action, for example ALLOW always. 7. For Send to LAN Server, enter the IP address of the local server. Note that this is also the IP address the computers on your LAN will access. 8. For WAN User choose Any, or limit access to particular IP addresses. 9. For Log selection it is reasonable to turn logs on, especially at the beginning when you are unsure of the result of the changes you are making. Later, you may want to set logs to "Never" for performance reasons. 10. Click Apply. As noted in user manual for some models: * Consider using the Dynamic DNS feature on the Advanced menu, so that external users can find your network when the DHCP lease is renewed by your ISP. * If your own LAN server uses DHCP, and your IPs change on rebooting, consider using the Reserved IP Address feature in the LAN IP menu. To Add a Service for These Routers 1. Click Security > Services > Add Custom Service. 2. Enter any name you choose for the service. 3. Select whether the service is to use TCP or UDP. If you are unsure, select both. 4. Enter the lowest port number used by the service. 5. Enter the highest port number used. If the service uses only one port number, enter the same number. 6. Click Apply.
Feb 19, 2006 | NetGear ProSafe FWG114P (fwg114pna)...
Port Forwarding
Feb 19, 2006 | NetGear ProSafe FVX538 Firewall
Port Forwarding
Feb 19, 2006 | NetGear ProSafe FVS338 (FVS338NA) Firewall
Port Forwarding
Feb 19, 2006 | NetGear ProSafe FVS328 Firewall
Port Forwarding
Feb 19, 2006 | NetGear FVL328 and FA311...
Open Questions:
See all Chili Systems ChiliBox Network Router And NAS Questions
Chili Systems ChiliBox Network Router And NAS Server (S5564110) Firewall Logo
89 people viewed this question
Top Chili Systems Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you a Chili Systems Computer and Internet Expert? Answer questions, earn points and help others
