I have a HCL TFT17W80PS LCD Monitor screen is slight vibrating the text. how can i solve the problem.
2 Suggested Answers
  • 135 Answers
SOURCE: my lcd monitor colours are
Hi There!
Sounds like this may be the cable between the monitor and computer. It may also be dry joints on the logik board. The board where the signal cable plugs into. This socket may have loose connections or dry solder points on the board. Hope this will help you. Please be careful when opening the screen as it can damage easily. Try refrain from handling the screen on the front. Best Wishes and Good Luck, JUS004
Posted on Sep 14, 2009
When on the system monitor shaking
Maybe we need more information. Try locating the computer away from the monitor if they are next to each other. Maybe try placing the LCD monitor on a soft mouse pad to help absorb vibration.
Feb 11, 2014 | Dell Computers & Internet
Hcl crt color 15" digital monitor.red color is
Unfortunately, this is not a fixable problem. Samsung CRT monitors are well known for losing color; they have defective cathode ray tubes. I recommend that you buy an lcd screen. sorry if that wasn't what you wanted to hear! don't forget to rate
Jan 13, 2011 | Samsung SyncMaster 753 DFX 17" CRT Monitor
I am having hcl monitor, recently monitor shows automatically contrast 100 message in red colorer box, i tried to use eixt button on the monitor screen but dos't work. how can solve this problem,
what is the motherboard model number ? what computer model are you using
what is the model number of LCD
what do you mean HCL, what is that ?
Oct 15, 2010 | Computers & Internet
Screen menu problem of HCL Monitor
jain rajendr, You or electronics technician will need to verify proper operation of your monitor's internal AC to DC power supply first. When very strange things start to appear on the lcd panel, the first place I would look would be the units SMPS/inverter power supply. 12fixlouie
Jun 02, 2010 | Computers & Internet
HCL Monitor Screen Display Problem with Contrast menu showing up.
my hcl 17inches monitor is displaying contrast,brightness etc automatically
in the middle of the screen.even if i press the menu buttons it
disappears for a sec and comes again and again.what should i do to
solve this?
Sep 13, 2009 | Computers & Internet
HCL LCD Monitor display problem
NO Bad Capacitors on the power board i have some problem in my HCL lcd monitor, my monitor display is on but at a time the display is gone. when i swicth off and on monitor power the monitor display is on ofter 2 sec the display is gone so that is the problem.
Jul 05, 2009 | ViewSonic VA702b 17" LCD Monitor
Hcl lcd monitor osd locked
my moniter was automatic restarted, and osd lock not open,where is is osd open option?
Dec 19, 2008 | Acer AL1916W 19" LCD Monitor
Monitor not working
You will need to change the display settings for the type of lcd monitor you have, it is a wide screen I am assuming, you can change this by right clicking on the desktop select properties then settings the screen resolution should be on the middle left side and change this until you get a screen that you like There is also an advanced setting then select monitor at the top tab and change to refresh rate to the lowest setting (60 hz) this should get the HCL monitor up then change the setting until they dont work the operating system will revert to the previous settings if you cant see anything after a change. you may also need to use the automated setup on the lcd monitor select auto from the menu (osd). Now if you can not do this on the HCL lcd you may need to use that other Samsung monitor and then set up on that at the lowest resolution so that the lcd can be changed with a working screen. Lastly you may need to uninstall the samsung monitor drivers if you installed those, and leave the generic drivers in for the monitor (plug and play monitor).
I am making some guesses here as you did not tell me if the 1st Samsung monitor was a lcd also , and if the second HCL monitor is a wide screen etc what type of operating system are you running is also important 98 is fussy and 2000 is much more simplified as is XP , vista would be garbage (if you could get it to run on a pIII),
As for reasons for resolution problems, way too many variables to discuss in a short answer forum like this, sufficed to say that the resolution is different because in the past there were lower resolution (less pixels) on monitors, the refresh rates were different by manufacturers and the way the lines were scanned could be different, so setup of the monitor with the video card was also very important interlacing etc was also handled differently until that industry decided on a common standard.
I hope this helps you to get the monitor up and running.
Jul 17, 2008 | Computers & Internet
Computers & Internet Logo
335 people viewed this question
David Payne
David Payne
