FixYa.com
Tags:
Umax Astra 1220P Flatbed Scanner
Need driver for Windows 2000
posted by pat j on May 15, 2008
need driver for Windows 2000.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 15, 2008
Not Rated (0)
morg1981
Rank:Guru Guru
Rating: 95%, 205 votes
http://www.umaxtech.de/ftp/vs355p.exe these should be the correct drivers for you. Best of luck.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Scanners problems?
Scanners
problems scanning
I have a new Photosmart C7200... Answer This...
Scanners
how to put the drain hose out...
hook up the drain hose so the... Answer This...
Scanners
Scaner
I need Draive Scasi Scaner... Answer This...
colour of the scanned copy
when i use the scanner the... Answer This...
Need Driver for XP of Umax...
Hi, I will appreciate if you... Answer This...
Repair Service
Find Scanner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
