Question about HP EliteBook 6930p Notebook PC
HDD Test Failed test 1 (Quick) .... Error: Read Failure Error : Read Failure
  • HP Expert
  • 393 Answers
U need to repalce HDD . Thanks
Posted on Sep 14, 2010
Why does my pc beeps 4 times and will not boot up?
Sounds like you mother board is the problem.
Did you drop it, add memory.......
1 short DRAM refresh failure CH000996
2 short Parity circuit failure CH000607
3 short Base 64K RAM failure CH000996
4 short System timer failure CH000607
5 short Process failure CH000607
6 short Keyboard controller Gate A20 error CH000383
7 short Virtual mode exception error CH000607
8 short Display memory Read/Write test failure CH000607
9 short ROM BIOS checksum failure CH000607
10 short CMOS shutdown Read/Write error CH000239
11 short Cache Memory error CH000607
1 long, 3 short Conventional/Extended memory failure CH000996
1 long, 8 short Display/Retrace test failed CH000607
Jun 16, 2014 | IBM Computers & Internet
Cmos beep codes
do you know which bios your computer is running ?
AMI BIOS beep codes 1 beep - DRAM refresh failure
2 beeps - Parity Circuit Failure
3 beeps - Base 64K RAM failure
4 beeps - System Timer Failure
5 beeps - Processor Failure
6 beeps - Keyboard Controller / Gate A20 Failure
7 beeps - Virtual Mode Exception Error
8 beeps - Display Memory Read/Write Failure
9 beeps - ROM BIOS Checksum Failure
10 beeps - CMOS Shutdown Register Read/Write Error
Phoenix BIOS BEEP codes. 1-1-3 CMOS write/read failure.
1-1-4 BIOS ROM checksum error.
1-2-1 System timer failure. (Programmable Interval Timer PIT)
1-2-2 DMA (direct Memory Access) failure.
1-2-3 DMA page register failure.
1-3-1 RAM refresh failure.
1-3-3 64K RAM chip or data line failure.
1-3-4 64K RAM odd/even logic failure.
1-4-1 64K RAM address line failure.
1-4-2 64K RAM parity error.
2-?-? Any beep series starting with 2 beeps indicates a 64K RAM chip or data line error.
3-1-1 Master DMA register test.
3-1-2 Mslave DMA register failure.
3-1-3 Master interrupt mask register failure.
3-1-4 Slave interrupt mask register failure.
3-2-4 Keyboard controller failure.
3-3-4 Screen (video) memory failure.
3-4-1 Screen initialization failure.
3-4-2 Screen retrace failure.
4-2-1 Timer tick interrupt test failure.
4-2-2 Shutdown test failure.
4-2-4 Unexpected interrupt in protected mode.
4-3-1 RAM test failure above address 0FFFFh (64K +)
4-3-3 Interval timer channel 2 test failure.
4-3-4 Time of day clock failure.
4-4-1 Serial port test failure.
4-4-2 Parallel port test failure.
4-4-3 Math Co-processor failure.
BEEP codes may vary dependent upon the revision of BIOS. This list is for reference only
hope this helps
Oct 10, 2012 | Intel Mother Board S5520HCR (988889365963)...
Long beeps not booting up
problem....the beeps are beep beep beep beep..........contiues...........plus the computer will then not recieve signal????
May 25, 2011 | MSI K9VGM-V Motherboard
My computer beeps at start up
Depending on your beep code, this might be a hardware problem. Please refer here for a bit of details.
Hope this will give you a place to start.
Apr 26, 2011 | Computers & Internet
The PC does not start.Only it beeps and a red light blinks,also fen is not working.
here are some of the basic codes, depending on which BIOS you have...
Also you do not indicate which fan? I would guess you mean the main Power Supply (PS)? In which case it could just be you need to replace the PS.
Here is a link to some other codes as well...
http://www.computerhope.com/beep.htm
AMI BIOS ERROR BEEP CODES
  • 1 Beep - Memory Refresh Failure (check memory)
  • 2 Beeps - Memory Parity Error in first 64KB block (check memory)
  • 3 Beeps - Memory Read/Write Error in first 64KB block (check memory)
  • 4 Beeps - Motherboard timer not functioning (possible motherboard replacement)
  • 5 Beeps - Processor Error (may need replacement Processor)
  • 6 Beeps - Gate A20/keyboard controller failure (possible motherboard replacement)
  • 7 Beeps - Processor Exception Interrupt Error (may need replacement Processor)
  • 8 Beeps - Display Memory Read/Write Failure (reseat or replace video card)
  • 9 Beeps - ROM checksum Error (replace BIOS chip or motherboard)
  • 10 Beeps - CMOS shutdown Read/Write error (possible motherboard replacement)
  • 11 Beeps - Bad Cache Memory - test failed (replace cache memory)
Phoenix BIOS ERROR BEEP CODES
Phoenix BIOS beep codes are a series of beeps separated by a pause, for example:
beep --- beep beep --- beep --- beep beep would be 1-2-1-2
  • 1-1-4-1 - Cache Error (level 2)
  • 1-2-2-3 - BIOS ROM Checksum
  • 1-3-1-1 - DRAM Refresh Test
  • 1-3-1-3 - Keyboard controller test
  • 1-3-4-1 - RAM Failure on address line xxxx (check memory)
  • 1-3-4-3 - RAM Failure on data bits xxxx of low byte of memory bus
  • 1-4-1-1 - RAM Failure on data bits xxxx of high byte of memory bus
  • 2-1-2-3 - ROM copyright notice
  • 2-2-3-1 - Test for unexpected interrupts
I hope this helps.
Mar 29, 2011 | HP Computers & Internet
What does a AMI bios beep code of one long and 9 short
AMI BIOS beep codes Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code
Descriptions
1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed
Jun 01, 2010 | Asrock 939SLI32-eSATA2 (939SLIESATA2)...
Continuous beeping sound
Do you get video? If so then it could be a stuck key on the keyboard.
Do you get no video? If so then reseat the RAM.
Feb 10, 2009 | Sony VAIO PCV-RX370DS PC Desktop
Wont turn on
yes they tell you if there is something wrong
Beep Code Descriptions Document
Sep 25, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
HP EliteBook 6930p Notebook PC Logo
3,073 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
