Question about Hoover Washing Machines
Hoover 210 washer. which is the incoming neutral terminal?
  • lescrock Sep 14, 2010
    Which terminal on the timer module does the active or brown wire connect to?
    Yes, which terminal do I connect the brown wire of the power supply to.
    Could you attach a diagram?
    Top Expert:
  • Hoover Master
  • 75,822 Answers
Nuetral is white wire
Posted on Sep 14, 2010
  • Hoover Master
  • 17,129 Answers
Did you mean the neutral of the power supply. If so there are three wires inthe core, the blue brown and the green. The brown is the main lead, blue is the neutral and green is the ground which goes to the body.
  • Hoover Master
  • 12,061 Answers
The Neutral terminal should be the WHITE wire, USA, AC wiring is BLACK, is PHASE, WHITE is NEUTRAL. EARTH IS GREEN.
EUROPEAN AC wiring, PHASE IS BROWN, NEUTRAL IS BLACK. EARTH is GREEN?YELLOW.
Other permutation, RED is PHASE, BLACK is NEUTRAL, EARTH is GREEN.
Below you can get a copy of your service manual, one should have this if one is attempting any work on a unit such as this.
http://service.hoover.co.uk/manuals/
I have a Tork 1103 24 hour time switch and I need directions on understanding the wiring diagram.
I assume this is the wiring diagram you have for your timer. I don't know what you're trying to control with this timer, but it has a 110V timer motor so it must have a neutral conductor connected. The L terminal would be your incoming line conductor (hot, usually black) The X terminal would be your Load terminal (usually black too) The unmarked terminal would be your neutral conductor. The incoming and outgoing neutral conductor would be connected here (usually white) If you're using this for 220V load, the hot conductor would be connected to the terminal marked 1 and it's load connected to the 2 terminal. Or you could use it for two separate circuits4591020.jpg
Aug 13, 2010 | TORK Variable Cycling Timer 8601
I wired a TORK #1103 - hot (black) from the panel to terminal 1 - neutral (white) from the panel to terminal X - hot to the GFCI recepticle terminal 2 - neutral to the GFCI recepticle terminal X. The GFCI...
If you look at your diagram, the neutral connects to the box with no number on it. This also supplies the nuetral to the timer motor. There is no need to switch the neutral conductor (white)
Connect line (incoming hot) to terminal L connect the load(black) out to the GCI on terminal X. Put both neutral white wires on the terminal with the square box.(this terminal should have the other timer motor wire already connected to it.
Aug 11, 2010 | TORK Digital Interval Timer Ssa100r-24
I just installed a new intermatic T101 timer, the lights work when i flip the switch manually, but the timer isnt moving
By chance did you connect both the incoming and outgoing white (neutral) wires together without also connecting them to the "A" terminal? If so, untwist them and connect both of them under the "A" terminal. The timing motor will not work if the "A" terminal is not connected to a neutral.
With the circuit energized from the breaker, you should be able to read 120 volts from the "A" terminal to the #1 terminal.
Also, check to make sure the yellow dial is pushed in and set to the correct time.
Otherwise the timer is defective and a return to the store is in order.
The wiring for the T101 is as follows:
Connect _both_ the incoming and outgoing neutrals (white) wires to the "A" terminal. The incoming [(LINE) (hot) (from the breaker or source)] black wire is connected to the #1 terminal and the outgoing (LOAD) black wire is connected to the #2 terminal.
Both of the bare or green wires are twisted together along with a 6 inch or so pigtail using a red or yellow wire nut. The pigtail is then connected to the green "GR" screw on the enclosure
May 05, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Hotpoint TCD 970 completely failed
check the terminals behind the incoming power terminal strip,this terminal block handles a lot of current and after time terminals burn off,it sounds like the neutral wire is burned or broken off which will give you these results you speak of,unplug the unit first before opening the access panel in back
May 02, 2010 | Dryers
With a 4-prong plug and a Samsung dryer, the incoming red and black (power) lines and the white (neutral) line all have a place to go on the terminal block. The green incoming (earth or ground) line has...
you nead to remove the green wire from the interior and tape it off.the whole point of the four-wire cord is to separate the ground from neutral,the green wire on the cord is attached to the cabinet.
Jan 19, 2010 | Samsung DV218AEW Electric Dryer
I have a T103 Intermatic timer controlling the circuit for outdoor lighting. I used it to replace a wall timer with inadequate capacity (was designed to control a lamp or similar). Problem is that when the...
Let's review your wiring. There's probably something miswired when you get symptoms like that. Let's work one circuit at a time.
For circuit #1, the incoming (LINE) black (hot) wire is connected to the #3 terminal. The white (neutral) is connected to the "A" terminal. The bare equipment grounding wire is connected to the "GR" terminal (the green screw on the case).
The outgoing (LOAD) black wire to the first set of lights is connected to terminal #4 and the outgoing white (neutral) wire connects to the "A" terminal. The outgoing bare wire to the lights goes to the "GR" terminal. It's best to twist the wires together with a pigtail, wirenut them and connect the pigtail to the "GR" terminal.
Now for separate circuit #2. The incoming (LINE) black (hot) connects to terminal #1. The incoming white (neutral) connects to terminal "A". The incoming bare wire connects to the "GR" terminal.
The outgoing (LOAD) black wire to the 2nd set of lights connects to the #2 terminal. The outgoing white (neutral) goes to the "A" terminal. It's OK to twist all the white neutral wires (incoming _and_ outgoing for _both_ circuits) together with a pigtail that goes to the "A" terminal. Use a red wirenut.
As long as you don't load the 15 amp breaker over 12 amps (this is considered a continuous circuit and it cannot be loaded over 80% per NEC), you don't have to have two circuits if you don't want too. Figure about 1 amp per light as long as the lights aren't over 100 watt. (100 watt lamp/120 volts = 0.83 amps (round to one amp)
Jan 02, 2010 | Intermatic T103 Indoor 120-Volt 40-amp...
Clock doesn't work
The wiring diagram for that timer is somewhat misleading. The 120 volt clock timer motor is connected internally to the "A" (neutral) terminal and the #3 terminal. The "A" (neutral) terminal is to the immediate left of the #1 terminal.
Here's how to do the wiring for your use, (assuming a 120 volt supply circuit and a 120 volt lighting or other load):
Connect the incoming power (line) black wire to terminal # 3. Connect the incoming (neutral) white wire to terminal "A".
Connect the outgoing (load) black wire to terminal # 4.
Connect the outgoing (neutral) white wire to terminal "A".
Mar 08, 2009 | Intermatic T103 Indoor 120-Volt 40-amp...
Clock want work
The wiring is incorrect. The wiring diagram for that timer is misleading. The 120 volt clock timer motor is connected internally to the "A" (neutral) terminal and the #3 terminal. The "A" (neutral) terminal is to the immediate left of the #1 terminal.
Here's how to do the wiring for your use, (assuming a 120 volt supply circuit and a 120 volt light circuit):
Feb 27, 2009 | Intermatic T103 Indoor 120-Volt 40-amp...
Washing Machines Logo
35 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
