Question about Protron PLTV-32 Television
Tv repair can you get me a power supply board for a protron 32tv?
    Genius:
  • 3,422 Answers
HI,
Please CLICK HERE to buy the power supply.
Goodluck,
Please don't forget to rate the solution
Posted on May 15, 2008
  • Priya darshan May 15, 2008
    Also let me know if you need any other parts.
  • 4,234 Answers
It may be possible, but I would need the full model number. What is the problem with the power supply? Depending upon the problem, it may not be worth the cost.
Keep us posted.
Dan
  • ABRsvcs May 16, 2008
    The model number for the power supply is: 090-02180-I3
    Dan
Protron
Please take this steps on how to determine the problem:
1. Open the back cover.
2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..
3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..
4. If the power supply output is normal..The problem could be on the main board...
5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..
6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..
Hope this solution will be helpful..
Jun 13, 2012 | Protron PLTV-26 26 in. HD-Ready LCD...
I have a 32" Protron
The tv power supply board,that the board where the tv power a/c cord plug into it.U know basic electronic,have all the tools also can do soldering work too?Tries check the tv power supply board for dead components parts call capacitors parts,most of the times the capacitors parts are bulges ups or puffing ups onto it tops.These capacitors parts are dying or already dead.These capacitors parts are dead must to be replace.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
May 22, 2011 | Protron PLTV-32 Television
I have the protron 3750 the power light is red when i turned the power on the light turned green for a few second then turned red again and nothing happened. can you help?
Tries unplug,replug the tv like an hour later,the tv,now will reset itself back to the factory setting,tv should work now.Not,than the power supply board is having problems,not giving wright voltages to the tv anymore.The power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 25, 2010 | Protron PLTV-37 37 in. LCD Television
Tv comes on for a second and shuts off
Most probably power supply board and/or inverter board is cause of this problem.
Local tv repair shop will help you if you have no prior experience of tv repair.
Aug 24, 2010 | Protron PLTV3250 32 in. LCD Television
No power to Protron pltv-32tv changed power cord still no power
You need to check and find out if you do have standby +5vdc at the power supply connector, if you do and the the Red indicator on the front is not on, then you have the problem in the main logic board. Post back what you find.
You have to have this 5v or nothing else will be turn on. New or used power supply is installed?
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
May 23, 2010 | Protron PLTV3250 32 in. LCD Television
My protron will not turn on and no lights will come on. I have it plugged in and the switch is on in the back but no lights come on and it dosnt respond to commands
Ur tv power supply board is dead.Replaced the power supply board will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 16, 2010 | Protron PLTV-37 37 in. LCD Television
2 1/2yr. old Protron Tv will not turn on. power light dose not light... the outlet it was pluged into is live & running a diffrent Tv now. Can you tell me if the protron Tv is shot or is there a fix?
Make sure there is no other power switch anywhere. The problem may be bad caps on the power supply board, or the board itself is bad. Parts for some of these Protrons are hard to get. If its the caps it should be a cheap fix, depending on the repair shop, but the board could cost $100 or so, not including shop labor to install it.
Sep 01, 2009 | Televison & Video
My protron tv went off and won't come on pltv
Hi, most protons have power supply problems, the power supply is no longer available, but it can either be mailed in to a company called PTS to be rebuilt or you can attempt a component level repair yourself.
Most non technical people can not disassemble and solder there TV.
If you are comfortable soldering, you can open the TV and view the power supply (upper center section) look for any bulging capacitors (cylinder looking small components) sometimes replacing the swollen caps will fix your Proton, If any parts look burnt you will need to send the board to PTS to get it rebuilt , should cost around $100.
PTScorp.com can be found online here or bring the TV to a local servicer that agrees on a flat rate price to fix it
thanks'
Eric
Aug 12, 2009 | Protron PLTV-32 Television
Tv stopped coming on like it was a fuse problem
a common problem for that model is power supply board. you need to replaced it or repair it.
Aug 04, 2009 | Protron PLTV-32 Television
PROTRON PLTV 3750 POWER SUPPLY BOARD REPAIR
if you look at the power supply board you will see an aluminum plate remove the four screws and 9 out of 10 times it is a diode on the board that has gone out. go to radio shack and for 83 cents you can buy one the same size. I personally have tried all the diodes that they sell and all of them that are the same size physically will work. I have three of these tv's and all of them were the same problem. I replaced the diode in each with one of each of the same physical size sold at radioshack and they have been working like new since.
Dec 12, 2008 | Protron PLTV-37 37 in. LCD Television
Protron PLTV-32 Television Logo
35 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
