Question about Kenmore 63942 Dryer
Kenmore dryer will not heat
The machine will not dry clothes at all.
Everything else seems to work fine .
  • ironmag May 26, 2008
    It takes 3-4 time to set dyer to have the cloths dry. I cleaned out the lint from the heating conductor leading to the wall. I still have the same the problem with heating. It is a 80 Series.
  • 481 Answers
This problem is almost always an airflow problem, check everywhere the air flows including inside the drum to inside the wall.
it is very rare that the thermo switches will cause this problem, but it is possible.
Posted on Jun 28, 2008
2009 Kenmore Dryer. Wondering why it seems to only work on 1 drying cycle? Everytime I try to put it on another cycle all the lights flash and beep...and nothing...
sounds like the washer might not be spinning the water out of the clothes good enough . 1 60 minute cycle should dry them more than dry enough .
Oct 18, 2015 | Kenmore 8804 5.8 cu. ft. Electric Dryer
My dryer doesnt heat. I checked the voltage, and ran through all the diagnostic tests to try to get an error code. Everything works fine when in the test mode. Figuring that all was well i went back to...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;'
Jul 17, 2011 | Kenmore 84072 Electric Dryer
I have a dryer # 67832791 and doesn't seem like it heats up and takes longer to dry the clothes. Seems to run fine and operate fine just not drying the clothes.
restriction in the venting, disconnect vent tube, leave disconnected dry clothes and if they dry then clean out vent tube(vacuum, leaf blower, etc). Hope this helped Tim
Nov 28, 2010 | Kenmore Dryers
No heat-Kenmore (Whirlpool) Elite He5 Steam 110.8775
Check that there is 240 volt at the plug as sometimes a breaker will be weak on one side and only produce 120 volts which will let the drum spin but produce no heat
Mar 20, 2010 | Kenmore Elite 45986 Front Load Washer
My dryer runs but does not heat up or dry clothes. What could be the problem?
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
Feb 16, 2010 | Kenmore 62602 Electric Dryer
Gas Dryer drying clothes cold, no heat...
if it heats for a while and then no heat you have bad gas coils,when the coils are on there way out they work until they heat up then they cut out,see if you have heat when the dryer is cold,if it is change out the gas coils
Jan 25, 2010 | Kenmore 63942 Dryer
The dryer won't dry the clothes. I cleaned out
it needs a new heating element. they are cheap and easy to replace.
Apr 25, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Elite HE4 Electric Dryer - heat but not drying
you have thermistor failure/ located inside machine reason for premature heat
Oct 07, 2008 | Kenmore Elite HE4 Electric Dryer
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Kenmore 63942 Dryer Logo
229 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
