Question about EnGenius EOC-3220 (EOC3220)
Confirguration how do i configure this product
    Brigadier General:
  • 6,966 Answers
After installing the hardware and physical mounting, basic configuration is something like below:
1. Set your computers TCP/IP address temporarily to be a static IP address such as;
2. Open your browser and type in in the address bar. The EnGenius password prompt should appear. The default user is admin and the password is also admin. The control interface should now be accessible;
3. Under the Wireless heading click on Site Survey. This will display all the access points in your area. Your ISP or to whatever WiFi network you would want to connect should be listed in the ‘Wireless Site Survey’. Select the access point with the highest signal level or your choice. Click ‘Connect’;
4. After clicking ‘connect’, it should confirm that the EnGenius has connected successfully;
5. Click Ok and it will take you back to the list of wireless site surveys;
6. To confirm that the SSID has been changed go to the ‘Wireless Basic Settings’ page which is in the Wireless submenu in the left side bar. Once on the wireless page go to the box with SSID. The value should read "Your ISP or the WiFi network you would want to connect"; this has to be exact and case-sensitive to connect successfully.
This is just the start, all settings are configurable and actually depends as to how you would want to use the device; as a WiFi Access Point, as a client router mode or Wireless outdoor bridges in WDS mode.
After all settings have been changed to your requirement(s), go back to the PC's control panel and your network connections, and change your TCP/IP address back to DHCP settings (obtaining an IP address automatically). panel window.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 16, 2008
I have a Plantronics headset on Cisco 7945 and after about 30 seconds you have to hit the headset button to continue the call
The issue is most likely because the Electronic Hookswitch Control setting is disabled on the phone. You can check it by following the instructions below. This setting can be changed by the phone system administrator and only applies to Cisco 7900 Series sets.
Press the settings button on the phone (checkbox icon).
  1. Choose "Device Configuration"
  2. Choose "Media Confirguration"
  3. Note the value "Headset Hookswitch Control"
Best of luck from Macondo Networks
Jan 24, 2017 | Plantronics Radio Communications
E was in the process of insatlling and on the one page it said to reboot but i did not pick the wierless section on the confirguration page
If you have a problem during setup on the DIR-412, this is how to reset it to factory settings.. (so you can try setting it up again).
- Ensure that the DIR-412 is plugged in and receiving power. - Press and hold the reset button on the rear of the device for 5 seconds. (on the back).
Note: Resetting the product to the factory default will erase the current configuration.
May 06, 2011 | D-Link Network Router DIR-412 Mobile 3GB...
I cannot connect to the internet using the USB cable port. My laptop is not recognizing driver files so I cannot execute installation of .dll files even if I have the correct drivers to install/ confirgure...
Consider just using the ethernet cable that usually comes with cable modems and plugging it into your computer. No drivers needed and simpler to configure since most routers and laptops default to auto-negotiating the settings for you.
Feb 23, 2011 | Computers & Internet
I am getting a 1005 2082 error on my HDS 9985 (NCS-55) when I try to delete a LUN assignment. Can you help?
1. RDP (mstsc ->IP address) to SVP of this storage (you can also connect via serial cable to storage)
2. Make sure SVP is in modify mode
3. Go to Install -> Change Configuration -> LUN Confirguration
4. Go to particular port on which your Host Group is reside.
5. Check LUN status: If it's other than "Normal" then you have to generate password to unreserve LUN. (password you will get from HDS support.
6. Once you have password right click LUN & do force reset. Enter Password & it's Done :) LUN status will come back to Normal & you will be able to release the LU path.
Oct 28, 2010 | Computers & Internet
Need belt confirguration for a 42 inch deck
if you have the new belt look on the box for the belt
Jun 27, 2010 | John Deere 195HP Hydrostatic 42" Cut...
Are there any hidden pages in SURFboard SB4100 Configuration Mgr?
Hi there.
No there's not any additional pages or other technical info on the modem page.
All it gives is the mac address and so on, you cannot make any changes to the modem as you will need modem hacking software to do this.
Thanks for using FixYa!!
Apr 23, 2009 | Arris SURFboard SB4100 Modem
Hotpoint stove fuse confirguration
Remove the old ones ONLY if you know what you are doing, and take them to the parts place with the modl # and serial # found on the tag plate!
Sep 06, 2008 | Hotpoint Ovens
Games not play
you have a bad cdrom player. google bad ps2 laser if you want to try and fix it yourself.
Jan 04, 2008 | Sony PlayStation 2 (PS2) Console
EnGenius EOC-3220 (EOC3220) Logo
246 people viewed this question
Top EnGenius Computers & Internet Experts
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
