Question about Lakewood HV 18-c Floor / Box Fan
I have a HV-20G floor fan, And I have no contitnuity between the "white"--(common ) wire and the"red-low", "blue-mid", or "black-hi" wirres.I have 7.3 ohms between the blue&black and blue&red on a 200ohm setting and 11.8 ohms between the red&black with one lead of the 9uf cap disconnected "could this be the thermal fuse?" if so could you email me a wire diagram as to it's location .my email address is "dominic1061@hotmail.com" thank you.
In that particular model, there is a small thermo fuse connecting the white wire and the yellow wire(there are 2 yellow wires coming from the capacitor). It's hidden in the coil so you can just cut the wick in that area an pull those two wires and you are going to see the fuse(small square shape one).
Posted on Sep 14, 2012
2 Suggested Answers
SOURCE: Lakewood HV-18 fan... how to wire switch?
i got the same problem with the wires on this exact switch of the exact fan and aswell 5 to 10 years old heres the type of switch that this fan uses --> any idea? btw im checking the case where the velocitys are marked let me put u the order goes like the this
HIGH_ _ MEDIUM
OFF------ O ------ LOW
http://www.nelsonappliance.com/Lakewood+Switches+for+HV-18+Fan+%7C+HV-12+%7C+P25+Fan.html
Posted on Sep 05, 2008
I have a 3 speed fan with a red, blue, black an white wires, how are the supposed to be wired with power. the wires go to a little black box that appears to just be wires with no circuit board
The BOX is a GE splicer - with 6 wires - 2 grey power wires, then the red, blue, black, and white from the fan motor. I have the same problem and cannot find another GE SPLICER 3 SPEED SWITCH for the fan. All switches that I have tried have 4 connections.........so a WIRING DIAGRAM would be GREAT!
Can anyone offer any help? I have tried every electrical store in the area!
Thanks
May 29, 2011 | Patton U2-1887HO Floor / Box Fan
I am installing a Mars 1/3 hp fan motor. It has a black wire,red wire, blue wire, yellow wire and (2) brown wire that go to a capacitor. May Furnace has Black power wire, red wire (speed) and white common....
Hello, Typically your common wire will be white, high speed- black, medium speed- yellow, medium low-blue, red- low. The motor could still run for a short time if it was wired wrong but will either trip a breaker or go off on it;s overload when it's gets hot.
Feb 26, 2011 | Heating & Cooling
Hello, I have to install a Hunter universal remote receiver, Model 27185 toa Hampton Bay ceiling fan w. light, Model 468-282 today. The receiver has 5 wires, red to light, black to fan, a live black to...
Red from receiver to blue light feed. Black from receiver to black feed to fan. White common from receiver to ground.(bare copper)
Black from receiver (hot) live in, to black from household wiring switch. Common in from receiver to neutral (white ) from house (switch.)
Sep 26, 2010 | Hunter Ceiling Fan Remote Receiver...
Wht is the correct wiring (red, white, blue, black) for the three speed switch?
White is the common or neutral...
Black is the high speed...
blue is medium...
red is low speed...
hook them up right in that order....
heatman101
Aug 17, 2010 | Lakewood HV 18-c Floor / Box Fan
Replaced old Ge 1/2hp fan blower motor w/ emerson motor wire not the same couldnot get to work. motors has blk,blue,red,white/brown, brownw/white strip/furance wires are blk,red,white could some tell me...
I am assuming you still have both motors, if you look on the side they will show you what wires go to what. Your Brown/white should be for the capicator. blk should be blk, blu might be white and red be red. I couldn't really say for certain with out looking at the diagram on the side of the motors. I hope this helped Tim
Aug 02, 2010 | Heating & Cooling
Wiring instructions are terrible. Ceiling wires = Red, Black, White, Copper. Fan wires = Black, White, Copper. Remote wires = Neutral in(Black), Live In(Black), Light out(White), Fan out(White),...
That is dificult to follow .. here is the usual wiring plan for ceiling fans .. green to green or bare and mounting bracket ... ceiling black and red are live from the switches, fan and light.with a remote you really only need one of these , so cap off the red and use the black as your input to the remote .. the neutral to the remote should be the white .. there are only 3 wires from the fan so I am assuming that there is no light , or the light will be activated from the remote .. the black for the fan and the black for the lights connect to marked wires on the remote. .. lights out, fan out
or looking at your description .. ((Remote wires = Neutral in(Black) white ceiling wire, Live In(Black) blaxck ceiling wire, Light out(White) blue Fan/Light wire, Fan out(White) black fan/light wire, Common(White) white ceiling and white fan/light wires.
May 21, 2010 | Hunter 27148 Remote Control
Stock audio wiring diagram
Car Radio Battery Constant 12v+ Wire: Green
Car Radio Accessory Switched 12v+ Wire: Green/Orange
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Yellow
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Under the Driver Seat.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Tweeter Speaker Positive Wire (+): Blue
Left Front Tweeter Speaker Negative Wire (-): Brown/Red
Left Front Mid Speaker Positive Wire (+): Black
Left Front Mid Speaker Negative Wire (-): White
Left Front Low Speaker Positive Wire (+): Yellow
Left Front Low Speaker Negative Wire (-): Blue
Right Front Tweeter Speaker Positive Wire (+): Blue/Orange
Right Front Tweeter Speaker Negative Wire (-): Green/Orange
Right Front Mid Speaker Positive Wire (+): Black
Right Front Mid Speaker Negative Wire (-): Brown/Red
Right Front Low Speaker Positive Wire (+): Black
Right Front Low Speaker Negative Wire (-): White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Blue
Left Rear Speaker Negative Wire (-): Green
Right Rear Speaker Positive Wire (+): Yellow
Right Rear Speaker Negative Wire (-): Blue
pls rate
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
May 11, 2010 | 2003 Kia Sorento
Replacing blower motor in furnace w/Fasco brand #D727
Some one missed the wiring diagram. I believe its like this:
L1 = Line 1 = (Hot all are same thing)
Black Hi
Blue Med
Red LO
Now usually the black is for AC and connects to a normally Open (NO) contact on the blower relay.
The heater speed (either red or blue) go the the normally Closed (NC) on the blower relay and on one side of this wire or contact on the relay it goes to the heating blower thermostat on the furnace.
The remaining wire (blue or red) you tape off.
L1 also feeds the Run Capacitor on 1 side and the Brown wire feeds the opposite side
The white wire is Neutral and goes to the neutral on the main line.
If this helps you please rate me accordingly and good luck.
Mar 13, 2009 | Kitchen Appliances - Others
My switch unit also fell apart as I took the back off and I didn't get to see the correct position of the switch. After much trial and error, I found this to be the initial "Off" position (see photo)
Oct 13, 2007 | Lakewood HV 18-c Floor / Box Fan
Lakewood HV 18-c Floor / Box Fan Logo
1,501 people viewed this question
Top Lakewood Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
