Question about Sony - XM-ZR604 4/3 channel car amplifier
Hi. I have the sony xplod amp xm-zr604 and I have a problem with wiring and choosing the right speakers. the manual says that it has 60w rms by 4 channels (4 ohm speakers) and 65w rms by 4 channels (2 ohm speakers). my problem is, what will happen if I wire two 4 ohms speakers in parallel to each channel. I know this will present a 2 ohm load to each channel so does that mean that the amp will deliver 65w to each channel like the manual says or will the amp deliver 120w to each channel like an amp is supposed to if the resistance is dropped by half? is it even safe to wire pairs of 4 ohm speakers in parallel with this amp? and how many watts would each speaker receive with this setup? also, is hooking up a 2 ohm speaker the same as hooking up two 4 ohm speakers in parallel?
SOURCE: V12 MRV-1507 or Xplod? Amplifier - XM-ZR1252 good quality sound
Alpine is just a better brand in general. I have the older MRV-1507, sounds GREAT, i have had friends who has had the Explode line, but it was always a temporary system until they got something better, like the alpine or kenwood.
Posted on Aug 16, 2008
  • 14 Answers
SOURCE: wiring diagrams
Look here: http://server4.nodevice.com/down/3a1657608f40b3f62b18e5416ded9ec7/xm-zr607.pdf
Posted on Dec 07, 2008
  • 11 Answers
SOURCE: will a sony xm-1652z 1000w amp run 2 dvc 4 ohm 800
IT WILL POWER THE SUBS WITH NO PROBLEM. I WILL NEED TO KNOW WHAT THAT MAX WATT THE SPEAKERS CAN HANDLE BEFORE GIVING PROPER ADVISE. RMS IS RECOMMENDED MINIMUM SETTINGS.
Posted on Feb 24, 2009
  • 12 Answers
SOURCE: Amp burning speakers.
one of the channels your using may be burned out or there is sum wire touching inside the amp so take the cover off and make sure nuthn is touching and see if sumthn is burnt and also try using a different channel on the sub
Posted on Feb 26, 2009
  • 3 Answers
SOURCE: Sony STR-DB940 Receiver Speaker Impedance Question
Whats the rating on the Plasma? How many watts at 4 ohms? If the plasma is rated 100 w at 8 ohm... hanging a 3.4 ohm load would put a lot of strain on the plasma's output amp. At 3.4 ohm the amp would be trying to delive close to 200 watts at full power. But it depends on how hot you normally run the volumn. Remember an amplifier output is AC volts. 1 ohm of resistance is close to a dead short. The amplifier would have to work its *** off to supply that type of power and would probably burn the output op-amps. If the outputs burn & it pumps any DC current through the speaker wire..the speakers would be toast...if not catch on fire. Try to keep the speaker load at or very cloe to the plasma's output load rating. Also if the plasma doesn't state it will handle loads down to 2 ohms...It probably won't.
Gene
Posted on Mar 03, 2009
Hey i have a sony amp (600 watt xm-zr604) with 2 10"sub(sony xplod).when i raise the volume hight enough the amp go off(red light came on) what can i try
sounds as though (at high volumes) the amp thinks it has a short circuit. This may be caused by the way you have them connected.
Speakers have a resistance and amps needs a certain amount of resistance to function right (too little resistance = short circuit)
The way it works out for the speakers is, if the two are connected to one amp output channel, the amp will see half of the resistance of a single sub. (4 Ohms/sub amp sees 2 Ohms)
If the amp instructions say that it's 4 Ohms/channel then you need to use 1 channel for each sub.
Hope this has been some help.
May 07, 2011 | Sony Xplod 800W Class AB Bridgeable...
Amp xm-ZR604 keeps going into protect mode
check the ground and the positive wires to make sure that they are getting good continuity. if your amp is too small for the speakers you are pushing this will also put the amp into protect mode
Feb 09, 2011 | Sony - XM-ZR604 4/3 channel car amplifier
I have two sony xplod 12" speakers wich can hold
You only gave us the model of the amp so I will make an assumption that your 12" subs are the Sony XS-GTX120LW. First, they cannot hold 1200 watts a piece. They are meant to be powered with 350 watts RMS. They will hold 1200 watts peak. That means that 1200 watts for a few seconds will be ok. Past that and kiss them goodbye!
Next you indicated that bridged the amp. Since the subs are both 4 ohm single voice coils did you wire them in series or parallel?
It sounds to me like you wired them in parallel resulting in the amp seeing a 2 ohm load. The amp you referenced is only stable when bridged at 4 ohms.
Has the amp begun working again once it cooled down? If not you could have fried the outputs by having the resistance too low.
Dec 21, 2010 | Sony Xplod XM-1652Z Car Audio Amplifier
Can this amp xm-2252hxcan be use to drive a 800 watts sony xplod
yep, you'll be safe. It's capable of delivering 225W x 2 RMS and 600W x 1 RMS into 4 Ohm loads.
Jun 18, 2009 | Sony XM-2252HX Car Audio Amplifier
How do i bridge 3 subs to a 4 channel amp
My information shows the XM-1652Z as being a 2-channel amp. It will not be stable below 4-ohms in bridged mode. For best power, your subs will need to be 2-ohms with all 3 wired in series. This will present a 6-ohm load to the amp. After wiring the subs in series, connect the positive speaker wire to one channel (+) and the negative speaker wire to the other channel (-). For the 1652Z no other wiring is necessary. For subs you will also want to set the LPF (80Hz) switch to the "ON" position (to the right).
Keep in mind that the rated output is only 400 watts RMS at 4-ohms in bridged mode. That's kinda wimpy for 3 subs. You would probably obtain better results from two 2-ohm subs, each connected to a separate channel. That way each sub would be getting 200 watts RMS, still low but there's lots of good subs that will sound pretty loud with 150-200 watts
Mar 25, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Can a 1000 watt amp run 800 rms subs and best wiring option
yeah it will run them but you won't get your full power because the rms for your subs is high. try bridging them with some 8 gauge wire, and of you got a crossover it will help you out alot
Feb 22, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Will a sony xm-1652z 1000w amp run 2 dvc 4 ohm 800 watt rms subs?and whats yhe best wiring option if so?thx
Feb 21, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony - XM-ZR604 4/3 channel car amplifier Logo
324 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
