Question about AEG Washing Machines
AEG oko lavalogic 1820 Machine begun to make a noise like if drainning , and in the screen appeared the legend "error code EF3 please call your local service force" could not switch it off , so i unplugged it , then plugged again and the same thing happened , a noise and the same legend
Take the backside of, clean the water or moisture from the bottum of the machine, pluch it in and start, check for any leaks. This is a safety device that set in by any possible case of leaks.
Posted on Sep 22, 2010
Remove housing
How to replace a washing machine door seal on an AEG ...
? 5:38
https://www.youtube.com/watch?v=KlAXmnKJQ9k
Aug 17, 2009 - Uploaded by eSpares
This video will show you how to remove and replace the door seal. ... Do you have video repair instructions for AEG washing machine OkO ...
AEG removing drum Washing Machines Questions ... - Fixya
www.fixya.com/tags/removing_drum/washing_machines/aeg
AEG washing machines removing drum related questions and answers. ... into thehousing and get the object out. well as we say in my town you got a "toston" .
Aeg/electrolux lavamat 76810 waschmaschine E20 - YouTube? 0:28https://www.youtube.com/watch?v=1WX5rKxFrXsMay 3, 2015 - Uploaded by jusuf jerkovicAeg/electrolux lavamat 76810 waschmaschine E20 ... front load washer from not draining -- washing machine error code e20 - Duration: 2:52.washing machine error code e20 - YouTube? 2:52https://www.youtube.com/watch?v=2B7FxovrxKoOct 25, 2014 - Uploaded by teppichkopfSave some money and fix it yourself. Totally bizarre how stuff gets stuck in the drain!
Dec 21, 2015 | AEG Washing Machines
How can I correct error code 25 on an AEG OK-LAVAMAT 74640 update washing machine mean?
Family error code "E20" means difficulties in draining, but I never heard for error code E25 on this model. Could be : E21, E23 and E24 error code.
Dado
Aug 24, 2014 | AEG Washing Machines
AEG Lavalogic 1820 Bricked / No Backlight , on the screen are only hieroglyphs
The display board needs to be replaced, that is just about all that would cause this problem, the LED display and board are all one part.
Dec 23, 2011 | Office Equipment & Supplies
AEG oko Diplomat E Update frontloader. Error message blinks E20. What should I do?
Error code E20 indicates that water cannot be pumped out of the machine. Possible causes:
  1. Sieve filter is blocked. Open the sieve lid, (lower right of machine) and clean.
  2. Drain tube bent or blocked. Check for bends and straighten the tube, open hose band clips and check inside for objects or dirt.
  3. Some small object (coin, children's toy, ...) blocks the drain pump. Pump needs to be dismantled and cleaned.
#1 and #2 you should be able to do yourself. With a little aptitude for repairs, you can do the fix #3 yourself, too. If you don't trust yourself to get all parts back together, let a service technician do the repair for you.
Dec 23, 2010 | AEG L86800 Front Load Washer
Aeg oko lavamat 72600 update, ce error code showing any idea?
error code ce is a faulty water distributor fault . you have to replace the top part of the soap dispensor compartment. sometimes you can hear a clicking noise when its trying to operate
Jul 09, 2010 | AEG Lavamat 72640 Front Load Washer
Lavalogic 1620 fails to come on - there is power to the machine - any idea what next to check kind regards
I also have problems with AEG Lavalogic 1600. It is caused by the control knob and the poor contacts. One service repair person fixed it and lasted 1 month. Then the problem reappeared. Now, I turn on the knob and the machine does not turn on, but I push lightly the button, not to a full path, just to cause a contact and it starts.
May 31, 2010 | AEG Lavamat Lavalogic 1600 Front Load...
CA Error Code - AEG OKO LAVAMAT 86700
c-a error message poped-up.washer stop working.............please help.
Sep 15, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
AEG OKO LAVAMAT 86741 UPDATE. WASHING MACHINE
I have washing machine AEG 62800 model.
When I tried to start a washing the error E60 was displayed on screen.
The following actions were done:
1. Turning knob to right to first position "COTTON LINES 95"
2. Pressing on all 5 functions except START button (Rinse Hold, Rinse+, Time Saver, Pre Wash, Stain).
Red lights will flash .
3. Pressing on Start button and simultaneously starting to turn clockwise till OFF position.
It will reset error and will release machine.
I'm hoping it will help.
Boris.
Feb 25, 2008 | Washing Machines
AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
Dec 10, 2007 | AEG L86800 Front Load Washer
Anti-flodd Aqua Control
exact same problem here, we had power cut and after power came on the pump was continuously running with error EF3 showing.
This has happened before - design error with AEG
May 27, 2007 | AEG Lavamat 88840 Front Load Washer
Washing Machines Logo
605 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
