Question about Philips Audio Players & Recorders
My Philips GoGear Raga 2GB is not working properly. Its earfone jack socket is causing some problems, it doesnt give proper sound now!
  • Philips Master
  • 32,281 Answers
The fault could be the earphone, check the earphone in a different device/player, if the fault still appears the the earphone is faulty, probably a broken wire in the cord.
If the earphone is OK then the earphone socket in the MP3 player is faulty. If may be too expensive to repair, unless you can DIY.
Posted on Sep 14, 2010
Cannot transfer MPEG-4 (.m4a) files
Hello, friend, you may convert the m4a file to mp3 file for a try, I know GOGEAR RAGA MP3 Player supports mp3 well. If you don't know how to do that, this audio converter will help you a lot.
http://www.freedvdripper.net/audio-converter.html
Hope it helps. Contact me if you have any other question.
May 27, 2013 | Philips 4GB GoGear RaGa MP3 Player
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
"memory is full conect to
You can repair your device using this steps:
Please install Philips Songbird software on your computer and then launch the program.
If you don"t have it can be downloaded from Philips website.
In the Philips Songbird menu bar (at the top), click on the Tools pull-down menu and then select Repair My RAGA.
Follow the on-screen instructions to complete the repair procedure.
I hope it will be successful.
Thanks.
gylacz
Apr 28, 2011 | Philips GoGear SA2RGA MP3 Player
There Is Not a Manual With Go Gear RAga 2Gb Device which i have just purchased
Depending on the model of the RAGA 2GB device:
SA1928/37B:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA1928/37B&slg=en&scy=US
SA1929/37:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA1929/37&slg=en&scy=US
SA1929/37B:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA1929/37B&slg=en&scy=US
Dec 07, 2010 | Philips GoGear HDD060 MP3 Player
On my Gogear Raga 2GB I can't make a playlist. (SA2RGA02). With WMP I can synchronise the music, but there's no playlist on the device. All the music is stored in different folders on the Raga and not in...
Sync all the songs you want onto the raga via 'songbird'.
Stay connected, then go to windows explorer, identify your device. Then in 'Music', make folders for your playlists. Manually transfer (drop and drag) your songs to the required folder/playlist.
When using the raga use the 'folder' option. Works as playlists.
grayza
Jul 10, 2010 | Philips GOGEAR SA6045 MP3 Player
ENTER saa7130 tv capture card not working properly
You need to make a cable with both ends with 3.5 mm jack socket. Plug one jack socket in audio out from tv tuner and the other in the line in from your sound card and will work.Good luck
Apr 01, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
Sound comes only in one earphone..
your headphones probably blew in the one ear. Try another pair of headphones.the same thing happened to me. if that doesnt work the recepters in the ear jack youll have to have a professional to fix it
Feb 28, 2010 | Philips Audio Players & Recorders
My gogear raga philips mp3 player - how do i know
Next site shows the support site for all available RaGa players in the UK:
http://www.support.philips.com/support/search/search.jsp?fetchWhatData=CountryCategoryData&_dyncharset=UTF-8&userLanguage=en&userCountry=gb&searchValue=raga
When the player is bought in the UK, select your player from the list to get the matching support.
When having the RaGa player in another country, select yours in the page top on the right and enter the word raga in the bar next to [Find now]. Next choose the exact model number.
Look for the Quick Start Guide how to connect and charge the player.
e.g. Quick Start Guide for RaGa player SA1982 on page 6.
To register see the Register your product phrase in the page top of the support site: on the page showing up you can create an account.
I hope this gives all the information you are looking for.
Dec 28, 2009 | Philips Audio Players & Recorders
2GB philips audio player
Charge it. If that doesnt work, take it back to walmart for a refund.
Aug 03, 2009 | Philips GoGear Flash MP3 Player
My mp3 doesnt play music properly
This is caused by the ground connection from the earphone socket not making contact with the main PCB.
This can be repaired by anyone competent with a soldering iron.
The four contacts on the earphone socket need to be re-soldered.
Aug 28, 2007 | Philips SA1100 MP3 Player
372 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
