Question about Samsung HPT5054 50 in. HD-Ready Plasma Television
It just died. but there is a red light when plugged
No power,adaptor light on when i connected to laptop the light flash and off
see the flowchart attached, and proceed according and fix it.
God bless you
Nov 23, 2013 | Acer Aspire 3680 Laptop
1996 gmc c 1500 won't start back fired & died & red light us on on my hyper teck power tuner
Sounds like your timing chain has jumped out of time, if the timing chain is old, the chain jump a few teeth putting it out of time having it fire at the wrong time when the exhaust valve is open. Check timing by pulling #1 plug - bring #1 piston to the top and line up timing mark , Ifind it easy to put thumb over spark plug hole and have someone bump the engine over and feel the pressure relief stop before you feel vacumm - timing mark should line up if the timing hasn't jumped
Mar 03, 2013 | GMC C1500 Cars & Trucks
Hi, i have a sony bravia klv-40x350a, last week, we suspected a lizard died inside our tv because of the smell was very strong near the on and off botton. we plugged the tv, the 1st pressed in the remote...
Hello.You need to open the back cover to see where is the location of the burned and died lizard.First you do is to clean the area of lizard died and try to power on again.
Jul 01, 2011 | Sony Televison & Video
I have a lcd monitor citizen tv set LT2010 , suddenly it doesnt work anymore and there is a blinking red light, i unplugged and nothing work.. please help me
Monitor power supply board have dead components parts call capactiors most likely.The power supply board that the board where the power a/c cord plug into it.U have all the tools and know basic electronic also can do basic soldering works?Yes,take it aparts and check the power supply board carefully and replaced all the dying or dead capacitors components capacitors parts,these dying capacitors parts dying are alway bulges and puffing up onto it tops.Replacing all the dying and dead capacitors that are having bulges or puffing up onto it tops,monitor will have red power light indicator LED light stable again and will stop blinking.The monitor will work again.
May 11, 2011 | Televison & Video
It always haves four red rings
4 red rings is a problem with your AV cable its either faulty or damaged try removing it and see if the lights go away altho sometimes if there is no av cable it still dispalys 4 red lights, if that doesnt work its the ANA chip has died or has lifted off the board
Nov 05, 2009 | Microsoft Xbox 360 Console
Panasonic Kx th112 sceen is dead answer light blinks red
Try swapping the AC adaptor from one of the handsets with the adaptor from the base unit. That fixed my problem.
Jul 21, 2009 | Lands Phones
Toshiba tz43v61 TV just died. No red light.
does it have a power strip on the tv stand? if so plug the tv into a wall socket.my power strip went bad and the reset button did not work
Jul 17, 2009 | Toshiba TZ43V61 43" Rear Projection...
Battery light blinking red during charging
Dell or Panasonic? Your post has both listed.
If the blinking light on a Dell is yellow or amber or orange (somewhere in that color range) and continues to blink the entire time it is plugged into AC power (wall outlet) and when you unplug it from the wall the laptop immediately dies .... then you battery is dead and needs replaced.
If the blinking light stops after a while (perhaps a minute?) and then turns green while plugged into AC power, then it is successfully charging - or so it thinks.
When you unplug it from the wall, does it stay up and running?
If it runs, it's OK - just ignore the light and plan on getting a new battery one day, start browsing now. :)
If it dies immediately upon unplugging, then your battery is dead and needs replaced.
Jun 13, 2009 | Panasonic Toughbook 28 Notebook
Samsung HPT5054 50 in. HD-Ready Plasma Television Logo
57 people viewed this question
Henry  Thomas
Henry Thomas
