Question about Cuisinart DCC-1200 Coffee Maker
A couple of days ago, coffee maker turned it self off after brewing. This happened 3 times. Tonight coffee maker would not turn on. Nothing lights up. Unplugged and plugged in again, still nothing. Maker is less than 2 years old.
Spoke w/ Cuisinart. Unplug unit for 1 hr, then plug back in, reset clock & Auto Off setting. This resets the unit back to the factory settings.
Posted on Sep 14, 2010
Testimonial: "great it works!!! thank you so much!!!!!"
  • jesseannemye Jan 15, 2011
    bummed. tried your suggestion and it didn't work
Syntia out of service code?
If it is under warranty ,call the manufacturer .There are many causes to the service code , coffee beans ground too fine ,setting for 3 beans may be too much if the beans are small, try setting with one bean...
Valve, round cover , spring loaded , on top of brew group dirty, metal valve pin may be covered with deposits from coffee oils . check manual or call a service center , screen of bottom piston plugged with coffee oils , to silver screen plugged with coffee oils .
none of the super-automatics like oily , shiny or over roasted beans .
Dec 19, 2013 | Saeco Syntia Espresso Machine & Coffee...
Coffee does not brew
If you are elictrically inclined you
could take it apart and jump
across the switch with a jumper
wire or whatever avaialable means
see if it works all the time
thereby proving the switch to
be defective
Dec 07, 2007 | Krups Aroma Control 229 Coffee Maker
Coffee maker turns on but will not brew
why question to all of this is with a "self clean" button, why doesn't it every tell you to clean it..... ??
Sep 07, 2012 | Cuisinart DCC-1200 Coffee Maker
Dcc-1200 coffeemaker self clean light blinks
There is no self clean button on mine, and I have done the above with vinegar and water......what next?
Nov 11, 2011 | Cuisinart DCC-1200 Coffee Maker
How do I program the stay or go coffee maker to turn on at a certain time, I worked the past few evenings, but the green light will not come on, I did have trouble the other times also
To Program Automatic Brew
1. Make sure clock is set for correct
time of day.
2. Press PROG button and digits will
flash.
3. Press H and M buttons until desired
brewing time is reached.
4. Press PROG button to confirm setting.
Digits will stop flashing and
return to set time of day.
5. Once brewing time has been set,
follow this procedure:
• Follow steps in "How to Make
Coffee."
• Push AUTO-ON-OFF button once
and "Auto" will be shown in display
indicating the brew cycle will begin
at the set time.
NOTE: If AUTO-ON-OFF is pushed
twice, the light will glow and brewing
will begin immediately. Press AUTOON-
OFF once to turn off and once
more to set programming mode.
Jan 13, 2011 | Hamilton Beach Stay or Go 45234 Coffee...
Brewing wrong cup size and sometimes will not brew at all
In Uk i would take it back to shop as faulty and get either replacement or full refund as it is not fit for purpose. Depends where you live and what consumer rights you have.
Mar 23, 2017 | Keurig Platinum B70 Coffee Maker
Put in water turn on green light is on nothing happens
The green light is used for setting an automatic brew time. Turn the brew button until its red and your coffee will begin brewing.
Oct 24, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Need assistance on how to program the timer for my cuisanart 12 cup coffee maker
1. Set the desired Brew-Start time.
a. Turn the FUNCTION KNOB to “Prog”.
b. Set the time you want coffee to begin
brewing by using the minute and hour
push-buttons. Follow the same instructions
you used to set the time of day, in
the To set the time section above.
2. Turn the FUNCTION knob to the “Auto On”
position. LCD will display the current time.
3. Lift and release the FLIP SWITCH. The
green indicator light will come on to remind
you that the programming function is in use.
At the programmed time, the red light will
come on as well, indicating that the brew
cycle is starting. Both lights will go off when
keep warm cycle ends.
NOTE: To reactivate the auto-on feature to
start brew cycle at the same time another day,
simply lift and release the FLIP SWITCH. The
green “auto-on” light will illuminate.
The manual can be found here:
http://www.cuisinart.com/share/man/25_man.pdf
Mar 24, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Coffee maker won't brew
This one has two AUTO dial settings - AUTO-ON and AUTO-OFF. AUTO-OFF merely keeps the hot plate warm for a fixed period of time. AUTO-ON is the one that allows your coffeemaker to go off at the pre-programmed time in the morning.
If it is set to AUTO-ON, but is not brewing at the set time, unplug the machine for longer than 20 minutes. Then plug it back in, reset the clock, reset the prog time for a time that is just a few minutes into the future, and then test the auto-on feature.
If it stil ldoes not brew, just turn the machine to brew and press on. If it brews a pot, then your problem is electrical. If it doesn't brew a pot on the regular brew setting, then you either have: A) Calcium buildup/clog, or B) a hose leak (or worse).
To rule out the calcium buildup possibility, let half a caraffe worth of vinegar sit in the water reservoir for about an hour. After the hour, turn it to brew and press on, and brew the vinegar just as if it were coffee. If the vinegar goes through, your problem is solved.
Otherwise, call Cuisinart and find out if you are still in-warranty. Thep roduct has a 3-year warranty.
-Tha Mp3 Doctor
Mar 20, 2009 | Cuisinart CBC-00FR 12-Cup Coffee Maker
Cuisinart DCC-1200 Coffee Maker Logo
3,138 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
