Question about Video Game Consoles & Games
Three of four red lights go red when you turn my xbox 360 on what do i do fix it
  • 4,102 Answers
Hi you have got the dreaded red ring of death, this is very common with all xboxes and their are people out their that will fix them for you for a fee.
their is nothing you can do yourself to solve this problem as its a case of taking the xbox apart and removing the heat sinks and the x clamps and fitting new parts and new heat sink paste, this is a big job and requires special tools. so its not for the novice to do.
i do the repairs to these on a regular basis and 8 out of 10 i fix work again but others tend to be to far gone.
any way the reason you are getting this warning light is due to it over heating, check the date on the sticker on the back of the xbox as it is covered by warranty for 3 years for this exact fault so if its less than 3 years old go to the xbox website and get them to replace it for you, if its outside this time then you have 2 options you could either repair it or sell it.
you can buy repair kits and get the instructions off the net but without having done it before it can by really hard to do and you could do more harm than good.
when they built these they used cheap parts and cheap heat sink paste now over time this causes it to over heat and then you get the dreaded red ring of death and this shows you the either the gpu or cpu chip has over heated.
now the repair involves taking the xbox apart which is not easy but can be done you need to then remove the x clamps and then remove both heat sinks. once their removed you need to clean them up and remove all the old heat sink paste and use new paste, you also need to get xbox rrod repair kit as you wont be using the cheap x clamp bits anymore these will go in the bin as this is what caused the problem in the first place.
let me know what you would like to do or if you need further assistance ok
i also be damaged xbox's but im based in UK
if you are going to do this yourself then make sure you have no warranty left as this fault is covered for 3 years by microsoft so if the date on the sticker on the back of the xbox is within this time all you need to do is go to the microsoft webiste and tell them and they will give you a replacement.
i charge 25pound to do the repair so you should be looking around this price if you are paying someone also their is no guarantee the repair will work as the damage caused by the over heating could have destroyed the cpu or gpu chip but you wont know this till after the repair work has been done.
if you are doing the work yourself then you need to get a erpair guide off the net so just google rrod repair guide and this will list loads of sties with these guides, you will also need to buy an xbox 360 rrod repair kit, you can get these off ebay for next to nothing, then you need to get some heat sink paste and some special torque screwdrivers to remove the xbox case.
this is not an easy job to do and getting it wrong can do a lot more harm than good if you put to much pressure on the heat sinks when you put them back on this will destroy the gpu and cpu chip so be warned.
make sure you get a guide and correct tools or if you are unsure get someone to do it who knows what their doing.
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Sep 14, 2010
XBOX had no power, so I found and repaired bent USB port pins, then the XBOX came on with three red lights. Any DIY repair possible?
Thanks for your question. To fix the 3 red lights what you will need to do is stop the heat getting to the GPU and the CPU and to do this you can use a good Xbox 360 Repair guide or of course you can send it in to microsoft.
Jan 09, 2013 | Microsoft Xbox 360 Console
I have problems with my Xbox 360 everytime i turn on the 360 there is a red circle. I tryed to fix it but it just won't work anymore how do i fix this Problem
Is there three red lights???? or a complete circle???? Three lights is the red ring of death. Four red lights or a circle is either a bad a/v cable (try a different one) or a bad hard drive....(try taking it off of the side when power is off then turn it on.).
Nov 14, 2010 | Microsoft Xbox 360 Console
Xbobx 360 3 red lights
3 Red lights problem is a drawback of Microsoft Xbox 360
Check out the blog post at http://www.fix-xbox360.info/2008/08/23/xbox-360-red-light-fix/ to know more information on fixing your xbox
Jan 07, 2009 | Microsoft Xbox 360 Console
Xbox360ringofdeath
if it is just three than something on the motherboard is melted and you have to buy a new one but if it is four than the power plug is not plugged in all the way in your 360.
Dec 30, 2008 | Microsoft Xbox 360 Console
Xbox360 and the 3 red lights
Three of the lights on the Ring of Light on the front of your Xbox 360 console flash red View products that this article applies to. if (!loadTOCNode) {var loadTOCNode = function(){}} Expand all | Collapse all if (kb_page_object) { kb_page_object.kb_imageExpandHoverText = 'Click to expand this image'; } SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Dec 06, 2008 | Video Game Consoles & Games
Xbox 360 2 rings
One red light signifies a major hardware failure or system error[4] , depending on which hardware failure or system error it is depends on how the problem can be fixed but in some cases there is no easy recovery and the console must be repaired or replaced. Two means the console is overheating and must be switched off and left to cool. Three, the infamous 'Red Ring of Death', means a general hardware failure and the console must be sent to Microsoft for repairs. All four red lights simply means that the console cannot detect its AV cable.
Nov 23, 2008 | Microsoft Xbox 360 Console
When i turned on my xbox 360 three red lights came on the console
When someone say that his/her Xbox is having three red lights problem, It means it needs to be repaired. If you are using Cooler than it is not a cure but a prevention. You could have used cooler before acutally having the problem just to prevent your Xbox. But now you will have to either get it repaired from Microsoft (in case your Xbox's warranty is not expired, but one thing to note is that you will have to wait for at least 3-4 weeks to get back your Xbox) or you can Fix your Xbox's three Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
Oct 17, 2008 | Microsoft Xbox 360 Console
4 red lights
it say e74 an one red light is on
May 29, 2008 | Microsoft Xbox 360 Console
Xbox 360 Video Problems
try using another input " a/v input on your tv " thos inputs may be fried.
May 24, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
16 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
