Question about Minolta EP4000/5000 CS/PRO Copier
Minolta EP4050 access code - Minolta EP4000/5000 CS/PRO Copier
  • Amirkhan4 Sep 14, 2010
    please email me what is the access code for Minolta EP4050.
    Thanks
    dishhobby@lycos.com
  • Minolta Master
  • 6,161 Answers
Admin or service?????
Posted on Mar 01, 2015
techbuster
  • 5081 Answers
SOURCE: Turn on get error c0500
the error codes means Low fuser temperature during warm-up
To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
2. Insert a suitable object into the hole to actuate the reset switch .
3. The code should clear and a message to close the front door should appear.
Posted on Jul 06, 2009
SOURCE: error code c0200 minolta ep4050
This was of great help as I was able to sort out the corona and now the machine is back working. Great learning experience. Well done to you. You are really a genius in Minolta problem shooting.
From
B Nchang
Posted on Nov 21, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: Just purchased an old minolta EP4050. Says
Easy one....press stop, then 0, then stop, then 1
so stop,zero,stop,one
You will now be in the service mode so be careful.
Look for the counters tab and press it
You should see a screen with multiple tabs. You are concerned with 2 of them.
First one is "Maintenance" Press this tab.
You will get a list of maintenance items with their preset values and the "count" or pages run on them. Look for any where the count is higher than the setting. If there is one where this is the case then use the arrow key to highlight that counter and clear it to zero with the C key. Be sure you are in the counter column not where the preset is. After you have zeroed any that are over the preset, exit out and turn the machine off then on again. See if M4 is gone. If it is great.
If not then repeat this procedure again but this time instead go to the Consumables tab instead of Maintenance and check the 2 counters in there. One is copy kit and the other waste toner collect. Clear them if they are over the preset. If the waste toner is over and you clear it you should empty the waste toner box or it could back up and damage the machine. The waste toner box is located inside of the plastic "box" on the back lower part of the copier. 2 screws remove the cover and the box just slides out. Be careful not to make a huge mess when emptying the box.
Good Luck
Posted on Dec 23, 2009
Testimonial: "You are an absolute genius. This copier has been sitting here for over 5 months with no one able to fix it!! Thanks & Merry Christmas."
RommelF
  • 11 Answers
SOURCE: We have a Minolta EP4050 with an error code C004.
Yes you need to call service this indicates problem in your fusing unit. A busted Heat lamp is the reason or broken thermistor.
Posted on Jan 13, 2010
  • 170 Answers
SOURCE: how to resolve erorr code
ckeck the main motor but try reset first the error to reset that error open the front door then at the left side of the machine you will see the small square attach with 1 screw remove that screw then the plastic square type then you will see the reset botton just press that botton
Posted on Dec 19, 2010
Copier Minolts ep4050 error code c0601
Scanner fault. The bright lite under the big glass. Does it come on To reset. Open the front door to your left a small access plate one bolt. remove the cover press trouble reset.
Nov 04, 2012 | Minolta EP4000/5000 CS/PRO Copier
How to resolve erorr code c0100 minolta cspro ep4050? spdhandri@yahoo.co.id
Dec 14, 2010 | Minolta EP4000/5000 CS/PRO Copier
We have a Minolta EP4050 with an error code C004. Do we need to get serviced?
Jan 07, 2010 | Minolta EP4000/5000 CS/PRO Copier
I have a Minolta model EP4050 and all of a sudden the display panel will not display. The copier works but I cannot see the display...it just lights up with the blue background light and that's it. Do I...
Sounds like the display HAS gone bad. I doubt a new one can be ordered. The best bet is to find a Minolta - Konica-Minolta dealer and they may have one in their graveyard.
Sep 16, 2009 | Minolta EP4000/5000 CS/PRO Copier
Turn on get error c0500 on a minolta ep4050
Jul 06, 2009 | Office Equipment & Supplies
Error code c0200 minolta ep4050
C0200, charge corona failure.
The high voltage wire used to charge the photo-conductive drum is broken or shorted.
It will need to be repaired or replaced.
It is usually a fairly simple job, but you may need the replacement wires to complete the job.
It could be someone has pressed the scoritron grid tensioner and allowed the grid to drop onto the drum.
Great care must be taken when working around the drum area.
If you open the front of the machine.
drop down the transfer section (yellow or green handle)
flip out the toner bottle.
you should see to recessed screws, one behind the toner bottle, one on the far right side of the unit. loosen these all the way,
there may be a plug in each side to disconnect.
you should now be able to slide the unit out.
set it down in some paper, the corona will be the long metal housing stretching front to back on the drum unit.
Remove it by sliding it one way, then it should open like a hinge, open it all the way and it should pop loose of the main unit.
The corona wire is behind the grid, it is the thickness of a human hair. If it is broken you will need a replacement, if the grid was off when you opened the unit up reinstall the grid and reassemble.
If the corona shell or the scoritron is discolored, clean them with a glass cleaner and soft cloth.
Keep the drum covered with paper so it is not exposed to direct light for any great length of time, do not allow the drum to be exposed to direct sunlight.
Hope this is of some help.
Ed
Apr 19, 2009 | Minolta EP4000/5000 CS/PRO Copier
Copier Minolts ep4050 error code C0072 +
C0072 is aerror code for the sub hopper unit. It is having a hard time adding toner or that the toner motor is ON for to long. It is having a hard time kepping up with the ATDC. The M2 is a counter, it can be reset in service mode, but major parts have to be replaced to clear it..
Mar 25, 2009 | Minolta EP4000/5000 CS/PRO Copier
Minolta CF900
try and locate botton called ACCESS.on the OP Panel should be pressed after you enter you access code
hope that help ...if not try the START BOTTON
Jan 11, 2009 | Konica Minolta DiALTA CF910 Copier
161 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
