Question about RCA F27641BC 27" TV
How do i set my tv to watch a dvd for an rca f27641bc tv without a remote?
SOURCE: RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Posted on Apr 05, 2008
XRAYRON
  • 156 Answers
SOURCE: rca remote
Here is the link for the manual to the URC-3220
Posted on May 03, 2008
SOURCE: lost remote to 27in rca tv, how can i switch my tv to input/output mode so i can watch movies on my dvd playter?
channel 91 was my av channel mad random but whatever it works heh
Posted on Jun 26, 2008
abhishek33
  • 1239 Answers
SOURCE: No connection DVD to G25189TK. No external channel set. (3 or 4)
hi you can change the external channel manualy or follow the steps mentioned here . http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=DCP750/37&scy=US&slg=AEN&grp=HOME_ENTERTAINMENT_GR&cat=AUDIO_SYSTEMS_CA&sct=SU00303_SU
if it doesnt work best to buy remote from https://secure.logmein.com/home.asp?lang=en
Posted on Dec 06, 2008
  • 346 Answers
SOURCE: problems getting a RCA universal remote to work for Prima tv/dvd
after you press the code search button you have to press the dvd button then enter the code
is the remote the rca systrem link?
Posted on Feb 02, 2009
I have two RCA remotes. 1st RCU 310 5538P. 2nd RCU 400 2420BB.
Remote Control Support - RCA ' Made for Moments
www.rca.com/support-remotes
RCARemote Control Support. Select your Type of Remote. Remote Code Finder ...RemoteProgramming. Cable/Satellite Receiver Codes. Select Your Provider.
RCA Universal Remote Control- Target Programming ...
www.thompsontv.com/rcarc.html
RCA Universal Remote Control-Programming Codes. ... Universal Remote. The remotemay already be set up to operate your brand of TV, VCR, or Cable Box.
Program an RCA Universal Remote Without a "Code Search ...
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowHow to Program an RCA Universal Remote Without a "Code Search" Button. Do you have an older RCA universal remote that you want to use, but it lacks a ...
Jan 23, 2016 | RCA Televison & Video
How can I make a DVD play using a RCA remote control? I have the menu up but no combination of button pressing will allow me to play the DVD.
The Logitech Harmony Remotes are the best thing I have run across for universal ease. I have set up 5 for different clients and the start at about $50. I think you might be happy to switch to one.
Don
Jan 05, 2015 | RCA Televison & Video
How do i manually program my channels on older tv without a remote
Nothing you can do without the original remote. One cannot get into the setup pages. Replacement remotes usually don't work on this point either. They are missing this special setup button. In order to watch DVD, VCR, connect them with a SCART cable. When you switch on the player, the TV will detect this and go automaticaly to this input. If connected with RCA plugs, you can choose the input with the program Up/Dwn buttons on the TV set itself, going "lower" than channel 1.
Jan 04, 2014 | Philips Magnavox 20MT133S 20" TV
The power went out and my RCA tv needs to have the time set to continue watching. But the remote does not work, and I can't access the menu from the tv
Hello
If the remote control doesn't work, just buy one RCA RCR model universal remote control. Without remote control, you can't set the time to this set.
Mar 04, 2012 | RCA Televison & Video
What channel does the TV need to be on to watch a
If your tv has input [rca connections] jacks, look at the original remote and use the input button.In some cases....pressing 00 on the remote will access an input. If you must a converter box...set your tv and the DVD player to channel 3.
Dec 25, 2009 | RCA F27442 27" TV
My remote control is broken. How do I watch DVD's
Hello Boye4522,
If you connect your Dvd player up via a scart lead directly to the back of your Tv when you turn on the DVD player this will send a voltage to the tv telling it to change to the input that your Dvd player is on.
Job done.
Cheers Little Dish Fitter.
Nov 15, 2009 | RCA RCU300WBL Remote Control
Cant get vidiogame channel
look on the remote for av/tv or input select av input
May 02, 2009 | RCA F27641BC 27" TV
I have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Apr 13, 2009 | RCA DRC8320 DVD Recorder/VCR
Dead remote = no dvd access?
Try a RCA universal remote with an input button. Try the codes for Orion , Sansui and RCA. Access the menu by holding down both volume buttons on the front of the set. There is no access to the jacks on the front of the set without a remote. If all else fails get a RF Modulator. This will allow you to watch your dvd by using the antenna jack on the back of the set.
Aug 10, 2008 | Durabrand DU1301 TV
Input Selection without a Remote
On either the front of the TV or a universal remote (which I assume you have already programmed) hit the MENU button. Go to option 4 "Channel". Go down to "List and Labels." Hit the CH up or down key until you see "FRNT" come up under the channel # heading. If your DVD is connected and playing, you'll see it playing now. Exit the menu to watch. You'll have to reverse the process to get back to watching TV, but there doesn't seem to be any way around this if you don't have your RCA remote. This process is guaranteed to work on an F27442 and will probably work on some other RCA models.
May 24, 2008 | RCA F27442 27" TV
Televison & Video Logo
51 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
