Am steve,my hp laptop failed to power.when i plug in the charger,only a green light blinks that is on the far left of the laptop.am so worried
  • 97 Answers
Remove your laptop battery and reinsert it
Posted on Sep 14, 2010
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
Sep 25, 2013 | Gateway Computers & Internet
My screen blinks dark for a sec every tme i plugin and unplug the charger
That is your laptop switching between power settings and is nothing to worry about. Laptops have 2 power settings basically. Full power when plugged in and a power saving mode when running on battery. One setting is screen brightness which changes. Probably what you are noticing.
Apr 06, 2011 | HP Pavilion dv1000 Notebook
The charging indicator light no longer comes on when the laptop is plugged in. Just replaced the battery. Also tried a different power cord.
Possibly a failed or damaged charging port (does it feel loose)? After that, charger may not be chucking out the voltage (19.5 volts)? Test with multimeter set to DV volts, with one probe on the inside of the plug ant the other on the outside.
Does the charger LED light blink when connected (sign that power is not making a circuit)
If the above fail to work, then the problem is with the connector on the mobo, this may just be a Charger port needing replacing (wired or soldered version), or the charging circuit of the motherboard gone
Feb 10, 2011 | HP Pavillion DV6227 Notebook
My laptop (hp x9010)is not switching on ,i pressed the reset button but still not responding whats the problem and solution
This could be down to several problems.
Firstly, check that the battery is being charged by the charger and indeed if power is getting to the laptop via the charger. The simplest way is to see if the charger LED light is green. Flashing green indicates that the power is being "spat back".. ie: not completing the circuit and this indicates that the charging circuit on the board may be damaged.
Secondly, is the charger plug tight in the port? A loose plug will not make enough contact (if it is try wiggling it and see if that helps. If it IS loose and works whan wiggling, you will need to get it replaced.
Thrirdly, try removing the battery and AC power, press the on button for 30 seconds, reconnect the Ac adaptor only and see if it then powers up
failing that, it would seem that the main fuse on the motherboard has bloen and you need it replacing
Jan 22, 2011 | HP Computers & Internet
My charger works and the light is solid green when i plug it in, but when i plug the charger into my computer the light blinks and my computer wont charge. what's wrong?
Either the battery has failed beyond the point of taking a charge or power connector on the mother board is broken. Check out my website www.micromendllc.com
Feb 26, 2010 | Acer Aspire 3680 Laptop
Laptop stopped working and now not starting up. I think the battrey is dead and charger not working. it is HP laptop
If the charger has a light on it when it's plugged in and it's not on when you plug it in, then yes your charger is bad. if the light is green then you have issues with the laptop. If no light, check the voltage with a volt meter to see if the charger has power. good luck.
Sep 05, 2009 | HP Pavilion dv1000 Notebook
Won't turn on, but the charge icon blinks 3 times
It has enough juice in the battery to light up the lcd lights but not enough to turn it on. Could be the power supply. Consult a reputable service center and have it checked out. Good luck.
Aug 04, 2009 | HP Compaq Presario V2000 Notebook
Blinking red light
blinking red light with battery icon means that you are running out of battery power. if the computer is plugged in to the wall and it still does the same thing you may have to replace the ac adapter or charger. the charger should have a green light on it to indicate it is getting power.
hope this helps. thanks.
Nov 13, 2007 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
