I have a Lenco L450 turntable that has a bottom disc (die cast) that is cracked & warped & causing the platter to scrape.Is it possible to obtain a replacement part or have one made?
MicrowaveSvc
  • 9098 Answers
SOURCE: The turntable makes grinding niose when engaged
That model number doesn't ring a bell. Is that right? Is it foreign?
Chances are the coupler and/or turntable support will be damaged or warped.
Also on some brands, the "packing" (often a rubber grommet) must be replaced.
Posted on Oct 22, 2007
djproaudio
  • 515 Answers
SOURCE: Ion ittusb turntable drive belt
If the belt is stuck, it will be hard to take off without damaging the belt. Send it back.
- OPTiC
Turntable Repair Expert
Digital Analog Therapy
Posted on Dec 13, 2008
  • 42 Answers
SOURCE: Can't remove platter after removing lock washer
It should just lift off, but might be a little stiff.
Posted on Jan 25, 2009
mirdan
  • 13 Answers
SOURCE: going too slow
You might try cleaning the motor shaft and belt with isopropilic alcool to remove any trace of grease that might make tre belt slip.
Posted on Apr 23, 2009
Grubhead
  • 5349 Answers
SOURCE: turntable wont spin
If the mat lifts up to reveal a hole then you might get at the belt that way. I would have thought that the platter will lift up anyway. It might be held by a clip washer, around the spindle, from the top, sometimes hidden under a glued plastic piece. If you can't get in that way unscrew the base.
Posted on Jul 12, 2009
Platter warped
Most platters are fixed by a horseshoe clip under the centre spindle. You might have to force-ably remove what is around the centre area to get access to the clip. You can glue it back on if the platter itself is fine and not warped. If it is warped it would be cheaper to get a new deck than search for a new platter.
Dec 10, 2015 | Audio Players & Recorders
My turntable appears to be uneven. it looks like a rolling hill when spinning, can this be fixed
Is it just the matt that records sit on that's the problem or the whole platter?
If it is the matt you can peel it off and get a new one from somewhere such as as Amazon. It doesn't have to be the same brand as the turntable as long as it fits on.
Just search for "turntable matt".
If the platter is the problem it might be caused if the platter is plastic by either a chemical or heat warping the platter. Has it been exposed to the sun for example? Some chemicals such as oil and polish can cause it to bend out of shape.
It's likely if the platter has warped that it will need to be replaced.
May 15, 2015 | ION Audio Audio Players & Recorders
The turntable on the Crosley I have just brought,spins round unevenly(up and down),is this a problem as it plays some records ok but will not play others.
The platter should be level. If it is not then it could either be warped, by oil, heat affecting in the past. Or just faulty. Even if a warped turntable plays a record OK, it could damage it, as it is so easy for a record to be damaged, it could cause a scratch on the record. It should be checked out.
Feb 23, 2015 | Crosley Cruiser 3-Speed Portable Turntable...
I have only 1 channel output on my lenco sterio
The cause of this could be a faulty cartridge, a bad connection to it. Or faulty cable or plug to amp. Or an internal pre-amp fault on the amp.
Aug 24, 2014 | Audio Players & Recorders
My thorens turntable makes a grinding/scraping sound on every revolution. platter is scraping on frame.
The only thing I can suggest is that you remove the platter. They often are attached by a horseshoe clip at the spindle. This might be hidden by a plastic cover. Once off you might see the cause. It might just need some grease or oil. Or something might have got inside it!
Aug 24, 2013 | Thorens Audio Players & Recorders
Crosley CR249 warped table
Sounds like you need a new platter. Has the platter worked OK before or has it always been like this?
I suspect you might have to contact Crosley to see who supplies parts.
Jan 10, 2013 | Crosley CR249TA Turntable
No sound from left channel on turntable
One of several things could be causing this. Let's start at the begining. Look at the cartridge on the tone arm and make sure that all four wires are attached. Remove the bottom or the unit from the bottom to access the wires underneath. Using a DMM check continuity for each wire from the cartridge to the end of the cord where it plugs in to the amplifier. Somewhere there could be a break. If this all checks out and there is no break then I would purchase a new cartridge as the left channel is bad, provided that you know absolutely that the amplifier does not have a problem. If you have another amp you should first try it to make sure that the amp is not the problem. When you are absolutely sure that the cartridge is the problem go to www.mcmelectronic.com where you will be able to get a very good, possibly better, cartridge at a very good price. Let me know how you make out or if you need more help.
hardrocko
Replacing the belt on any turntable requires removing the platter. There are various schemes to keep them on but most involve a "C" clip clipped in a groove just above the platter on the spindle. You may have to remove the rubber mat to access the clip. Most rubber mats are glued down but can be pried off with patience and some force with a 1" scraper. Once the mat and platter are removed the belt can be discarded and a new one installed. Replace the platter. There will be one or possibly two oblong holes in the platter. Using a flat screwdriver hold tension on the belt and rotate the platter to get the belt around the drive and continue with turning the platter until you are sure the belt is around the drive ring on the platter and the motor spindle. You can tell because the platter will have some resistance due to spinning the motor. Reassemble the mat. It can just be placed on the platter. Unless you are going to run it upside down, which wouldn't work, it won't fall off. You are done and the unit should work like a new one. If you haven't purchased a belt this website www.mcmelectronic.com has belts for most units and also a variety pack of different length belts which should have one which will fit. Let me know how you make out or if you need more help.
hardrocko
Thanks for using FixYa
Feb 12, 2010 | Technics SL-1200 Turntable
Platter not spinning properly
Make sure the platter is seated correctly. Lift it off, and set it back down. Also check to see that there is no debris or foreign matter stuck underneath the platter or where the platter sits.
Check to make sure the platter itself is not bent or warped. Do this by removing the platter (lift up), and then put it on a flat table/surface. Look at it from the side. Is it warped?
Hope this helps
- Davis
DJ Pro Audio
www.djproaudio.com
www.repairnyc.com
Jul 24, 2008 | Vestax PDX-2000MKII PRO Turntable
How do i put my belt back on a technics dc servo automatic turntable system SL-B210 i havnt used it for a while so when i got it out to use the belt was lose uder the thing the disc gose on
Remove the platter, then take the belt, and wrap it to the bottom lip of the platter. You'll see an inner lip underneath the platter... this is where the belt goes.
Next, put the platter back on, and you'll see 2 holes on alternate sides of the platter. Rotate the platter until the brass shaft of the motor is exposed - usually @ the 11 o'clock position. Pinch the belt and pull it out, to wrap around the shaft.
That's it.
- OPTiC
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
Jul 21, 2008 | Technics SL-1210 Turntable
High-pitched, repetitive squeaking noise from under platter on 1210MK2
Make sure there is nothing on the magnet part of the platter. Also, sometimes, the screws that hold down the plastic protective cover underneath the platter might not be seated all the way. Lastly, look at the bottom of the magnet, and make sure that it is in tact, and nothing is bent, broken, or cracked.
Other than that, try switching out the platters from your other turntable, and see if the problem persists. You need to rule out what it is not, before you can proceed with finding out what is the problem. So if the noise moves to the other turntable, you know the issue is with the platter. If the noise remains on the same turntable, then you can rule out the platter being the culprit, and can isolate the issue to the turntable. I've never heard of this, and I've fixed well over 3000 Technics 1200MK2/MK3/MK5 turntables in the past 10 years. I am also considered THE 1200s MASTER. So, I am not sure what could be causing this noise, other than some foreign matter. If your in the NY metro area, bring it on by, and I'll take a look at it, or give us a call, and I'll try and refer someone locally for you:
http://www.tweakrepair.com
- J
Jan 14, 2008 | Technics SL-1210 Turntable
116 people viewed this question
 Grubhead
Grubhead
