Question about Fujitsu C600 (LKN:GBR-651211-014) PC Desktop
My thumb drive, all the folder change to chortcut when i fix to the pc
How to copy and paste pictures
It depends on where you are copying the pictures from. Are these photos already on your computer? A thumb drive? Or are you trying to copy photos from a website?
If you have photos on your computer or an external drive like a thumb drive that you want to "copy" to a folder, you simply highlight the files, right click, select copy, then go to the folder where you want to put the photos, right click and select paste.
If you want to "move" the files from one folder to another it is slightly more complicated. The easiest method is to have both folders open and visible on your computer. Highlight the photos you want to move, hold down the left mouse button and drag the photos to the new folder.
Aug 05, 2014 | Computers & Internet
How can i change where i can down load a program to on my hp laptop (compaq) ! i want to down load a file straight to a thumb drive !tr
When you download and save the file you click on the folder icon, navigate up to My Computer then down to the thumb drive to save the file on the thumb drive.
Nov 27, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
Need to know how to stop thm from downloading into computer
Assuming you are using Windows XP, the following solution applies to remove the thumbs.db file from your picture folders. The function of thumbs.db is just to cache the pictures in that folder so that previews load faster, so you can safely disable this feature and delete the file.
First let's turn this feature off, so that no new thumbs.db files are created (the thumbs.db already created will have to deleted manually:
1) Open My Computer or any windows folder
2) From the top menu options, click on "Tools"
3) Open Folder Options, click on "VIEW" tab (right of "GENERAL" tab)
4) In "Advanced Settings", under "Files and Folders" sub heading, put a check mark in the "Do not cache thumbnails" option (by default it's unchecked).
5) Now, click Ok and close the folder.
6) That's it, no more annoying "thumbs.db" files.
Next follow these steps to remove the thumbs.db files already created in your hard drive.
1) Click on Start button and open "Search"
2) Click on All Files and Folders (by default XP search is set to standard. Advanced mode is slightly different and can be selected from "change preferences" --> "change files and folder search behaviour", but basically the procedure remains same.
3) Type "thumbs.db" in "all or part of the file name"
4) In the Look in box, make sure all local hard drives is chosen or you can select "my computer" too from the drop down menu.
5) Now, this step is important, expand "more advanced options", by clicking on its arrow and make sure all the first three options, ie, search "system folders", "hidden files" & "subfolders" are selected (have check marks). If not select them. (Remember, most "thumbs.db" have an "hidden file" attribute, so if hidden file search is unchecked, either no results or very few only will appear.
6) Click "Search" and wait till search is completed. It can take a long time depending on your hard drive size and contents.
7) All thumbs.db files in your hard drive will be displayed
8) Click "Edit" from the top menu options and click "Select All" from the drop down menu.
8) Click "File" menu (left of EDIT), now click "Delete" rom its drop down options.
9) Click "yes" if asked for confirmation. Close "search", now go to "Recycle Bin" and empty it.
10) Your PC is now free of "thumbs.db" pest forever.
Jan 15, 2012 | Cell Phones
USB port keeps turning off
Possibility
thumb drive error. Chances are, your thumb drive firmware is damaged. So a normal laptop USB port.
Solution
To repair damaged thumb drive firmware, the solution can be found on google seach engines. Example; Fir transcends flash drive, Fix sandisk flash drive, Fix PQI flash drive, etc.
Dec 24, 2011 | Toshiba Satellite C655-S5056 NB PC w/...
I am trying to use Picasa 3 and was doing great, now when I try to use it I am getting a message that says CBlockFile::open Block err=2 thumbs ob I love the program and use it daily please tell me how...
Every folder on your C: drive that contains any picture will contain a file named 'thumbs.db'.
So, close Picasas.
Open "My Pictures", and then open the folder that contains the picture.
Click 'Tools".
Click "Folder Options".
Click "View"
Change the setting to "view hidden files".
Delete that 'thumbs.db' file.
Change the setting to "hide hidden files".
Re-open Picasa.
Picasa will rebuild that 'thumbs.db' file.
Jul 12, 2011 | Computers & Internet
Uploading photos
Both the thumb drive and the picture frame are USB slave devices, not USB masters. They both need to be connected to a USB master in order to transfer files.
Do you have a standard USB cable from some other device, any other device? If so, that should fit into the picture frame. If not, you'll have to buy one.
Connect the thumb drive to your computer. Create a folder on the computer and copy your photos to that folder. Then connect the picture frame to the computer and copy the photos from the folder to the frame.
If you have two or more USB ports, you can skip the folder and just copy photos from the thumb drive directly to the frame.
Jun 04, 2010 | Pacific Digital MemoryVue MV-800 Digital...
Cell phone is restarting
chortcut.
change battery and clean the mainboard
May 05, 2010 | Nokia 3110 Cellular Phone
My sandisk when kept in pc show as a folder please
your pendrive is effected with virus formate it it will shown the original image
Oct 02, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Free Space C drive
Start by running the "Disk Cleanup" from the accesories menu
This will clean up any Temporary files and junk that's not needed.
Next from the control panel/programs and features, uninstall any unwanted programs.
Next run the Defrag from accesories menu.
This should be a good start.
Mar 02, 2009 | Acer Aspire 3680 Laptop
Fujitsu C600 (LKN:GBR-651211-014) PC Desktop Logo
106 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
