Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
My canon ixus 75 will suddenly no longer turn on. I have tested the battery - it works in another canon we have, and have plugged the camera directly into the computer. Nothing happens.
  • pirrie4 Sep 14, 2010
    I have removed the battery & will let it sit for 1/2 hour. Will let you know what happens.
    Hi Taran,
    No go....unable to get any response from camera.
    President:
  • 1,194 Answers
As per the description you have done all the things in order to fix the device, I think ON/OFF switch may be malfunctioning (shorted) or possibly the camera circuit need to be repaired, you have no other option but to take your device to the canon service center.
Thanks..!!!
Posted on Sep 14, 2010
  • 10,515 Answers
This is a common problem. Most of time the same kind of the problem occur because of some malfunctioning in the circuit board.
First of all we will try to reset the system.. Most of time this fix the issue..
To reset, please Switch off and disconnect it from power supply. Also remove any other units connected to it. Leave the system for 30 minutes then restart it.
If the reset doesn't help then surly the problem is with the circuit board.. Most of time some capacitors goes shorted or get fused because of high electric supply to the unit.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
  • taran_2005
    taran_2005 Sep 14, 2010
    Thanks for your response!!
    You are most welcome. You could also try to clean the battery connectors. Sometimes that could also create a problem.
    I hope these above options work unless you need to send the unit for repair which might not be cost effective.
    Hope i helped you.
  • taran_2005
    Unfortunately, in this case camera has to be send for repair. Do check the quote before sending the camera.
    Hope i helped you.
The camera is not turnning on
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jun 25, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Can we use canon ixus 75 as a webcam
A raw image is an uncompressed format your camera takes the picture in. Usually it gets transferred from the camera into a .jpg compressed format to your computer (which simplifies everything and is able to be viewed by anything like photo viewers). I would search for a canon IXUs 75 driver for your computer, and turn your camera 'on' plugged in with your USB using a standard computer photoviewer program to see if it has a live mode?
Jun 18, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
PowerShot SD750 / IXUS 75 Digital Camera: HOW DO I CHARGE MY BATTERY...
Take the battery out of the camera, put it into the supplied charger, and plug the charger into a wall outlet.
May 17, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
My canon ixus 75 displays a black screen when in the shoot mode,this happened suddenly while taking a number of pictures,although I can still veiw pictures on the memory card.
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Apr 25, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon SD750 does not turn on. Battery is fully recharged and tested on another camera. Just no power to this camera.
Your problem is the fuse on the main board or the battery door switch. if you cannot repair we do it for 85.00
Jan 22, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Blurry photo Problems
the problem is the unit ccd ,you need the send to canon is free the repair okay ,only call
Dec 18, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Ixus 75 battery discharges overnight even if the camera is turned off.
That's it, the battery's defective, it's not the camera...unless you've tried another (new) battery...
Sep 27, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Battery display on canon ixus 75
Its same for everyone. You can only see the battery when its about to run out. IN that case a red flashing icon appears on the upper right corner of the screen otherwise there is no indicator for ixus 75.
Jun 12, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Won't turn on
Are you sure the battery is back in the right direction? If it is, try holding the power button down longer than usuall. If none of this works then it might have some internal damage.
May 12, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon ixus 75 digital camera reset?
The manual states that the battery door was opened during use. Close the battery door and turn it on and off. You may need to push it closed to make sure the battery connections are made.
Mar 21, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
