Question about LG Televison & Video
LG 42l85D this is the kind of flat screen I have want to hook up dvd and how how I find the right channel
2 Suggested Answers
  • 1043 Answers
SOURCE: I'm trying to get my dvd recorder and vcr hooked
DVD players do not connect using regular cable connections Your flat screen TV should have separate Audio and Video connections. These are the connections that you should use to connect your VCR and DVD player. If you have a combo unit, that is a single unit that has both DVD and VHS in one box, you might be able to get your VCR to work on the cable connection. However your DVD will not be able to work as the cable connection doesn't allow enough information to pass through. If you go to your local Audio Video store and tell them what you want to connect they should have the cables you need for less than $10.00. Good luck.
Posted on Sep 15, 2009
LG hd tv..only on the hd channels does the screen flicker black every 10 seconds or so...why?
A way to test the HD on your TV is to hook it up to another HD source. (HD DVD player, Xbox, ect.) If it does fine, then you know It's not your tv. It sounds like you have a bad cable box or cable service. I'd contact your cable company.
Dec 09, 2013 | LG Televison & Video
Only get blue screen
check to make sure dvd player is hooked to tv with correct chords, then check to make syre tv is on right channel, if you have no aux. channel the correct channel is likely 2 or 3
Dec 20, 2012 | Craig CLC501 15 in. TV
Channels will not program into tv so that my dvd player and Playstation2 will picture can be seen. I can hear both, but it TV is on wrong station and will not program in
You have a DVD player hooked etc to either channel three or four? Usually this equipment is connected into the Jacks on the rear of the set, that is to say hooked to a video input and not with the tuner, if hooked that way select the input with the remote for the set and see the picture....
Clarify how you are hooked and where
Dec 05, 2012 | Emerson Lc190em2 19" Class Lcd Hdtv
How do i hook my dvd player to my jvc 32 inch flat screen tv
U might be putting them in the wrong places or the wrong channel try and go through the channels but make sure they are hooked up right cause it will mess the TV up I did it on time and had to go get me another one cause I messed the sound up Hope this helps ya
Feb 20, 2012 | Televison & Video
I have and old emerson tv (ewt19s2) that i want to use a dvd player with. the remote isnt working. what can i do to the tv to make the right screen work?
HI JENN,
I ASSUME YOU DON'T HAVE A REMOTE FOR YOUR TV EITHER SO...
I WOULD EITHER PURCHASE AN INEXPENSIVE UNIVERSAL REMOTE COMPATIBLE TO THE DVD PLAYER AND EITHER USE PATCH CORDS, OR AN A/B SPLITTER, SO YOU CAN GO OUT THE DVD INTO THE TV...THE SAME AS YOU WOULD HOOK UP A VCR.
YOU DON'T NEED A REMOTE FOR EITHER, YOU CAN TURN BOTH ON AND OFF MANUALLY...
YOU ONLY NEED TO MAKE SURE THE TV IS SET TO THE SAME CHANNEL AS ON THE DVD PLAYER 3 OR 4.
HOPE THIS HELPS! I WOULD APPRECIATE A RATING FROM YOU.
KIND REGARDS!
MARTIE
Sep 08, 2011 | Televison & Video
How do I hook up coby 5.1 300watt to my rca flat screen
audio out on the TV to audio in on the "home theatre system"
Feb 27, 2009 | Coby 5.1 Channel Home Theater Speaker...
Hooking up a dvd
You want to hook up the cables to any of the VGA input sets. Red= right audio channel, White= left audio channel, Yellow= Video. Don't plug them into the sets that have Red, , Green, and blue inputs. Just the set with red, white and yellow. Now you won't get HD from this since it's not bluray or HD-DVD. Just be sure you select the corresponding input on the TV when you want to use the DVD player. For example, select input 1 from the on screen display if that's the one you plugged it into.
Nov 07, 2008 | Sharp Aquos LC-32GD6U 32 in. HD-Ready LCD...
Hook up vcr
Unhook the dvd cables from the AV1 ports on the tv. Then hook these DVD outputs to the inputs on the vcr. Then hook the vcr outputs to the tv inputs (AV1). The tv and the vcr must then be set to channel 3 in order to watch the dvd (and possibly also some menu settings such as setting everything to "component video" and/or setting the tv/vcr button to "vcr. Also set all "3 or 4" switches on the back of all equipment to channel 3. Also, don't forget to go into your tv menu and choose AV1 when you want to watch the dvd and/or the vcr.
You can also try connecting your dish to the vcr and then the vcr to the input on the tv where you HAD the dish connected. There are several combinations you can try, but just remember to always put output cables to the INPUTS of the next piece of equipment in line, and set your menu settings appropriately on all equipment whenever you change from one machine to the next.
If all this fails, then here is a 100% positive solution. Buy an "A/B" switch. It has two inputs and only one output. You could leave the dvd connected as is and connect the dish and the vcr to the two inputs on the A/B switch. Then hook the one output of the A/B switch to the tv. When you change the position of the A/B switch back and forth, you will be changing over back and forth from dvd to vcr. You can move the A/B input selection switch manually or you can buy a remote controlled A/B switch and do your switching with the remote that comes with the switch.
Keever
Mar 04, 2008 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
110 people viewed this question
Computer Repairing
Computer Repairing
