Question about Protron PLTV-32 Television
SET IS DEAD
NEED POWER SUPPLY BOARD
  • 2,322 Answers
It might be a bit hard to find service parts for these TVs.
The only solution would be to fix the power supply by replacing the components that have failed. Even sometimes is hard to find some of the more specific parts like transistors or voltage regulators that are use on this power supply.
I could service your power supply by replacing the defective componentes.
Posted on May 15, 2008
4 Suggested Answers
  • 16 Answers
SOURCE: dead set
what was the orignal problem you had?
Posted on Mar 12, 2008
  • 8457 Answers
SOURCE: need power supply board
U check ur incomming power sources with other electronics devices yet,tries other A/C outlet plugs?Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Apr 26, 2010
welcomejee
  • 10594 Answers
SOURCE: Pana TC-50PX14 dead set with
Blinking light indicates that tv went on protection mode due to internal problem and 7 times blinking is an error code that shows problem with SU, SD, SC boards in Panasonic TC-50PX14 plasma tv.
Below is an image of boards location in tv, taken from service manual, above said boards have been marked for convenience.
Let me know if you have additional question.
Thanks.
Posted on Dec 27, 2010
How to reset tv
hi Tracie,
is the set making a clicking noise?
is the power light flashing on the front?
or no power light at all just dead?
if the set is just dead, just put your ear to the back vents can you hear like a very faint screaming noise and can you smell and burning in the vent?
if so it just could be capacitors on the power board.
if its clicking the that will need a service kit on the power supply board.
if the power led is flashing then you will need to count how many flashers from start to finish when you first turn set on.
hope this helps.
Panasonic TH 42PX75 80 TH C42hD18 Dead TV Repair Fix TXN P1XGTUS HNTUS... Panasonic TV Won Turn On Learn How to Replace Your Power Supply FIX Panasonic Viera 42 inch Plasma SU BOARD TH 42PX75U Diagnosis Repair...
Jun 20, 2014 | Panasonic "Viera Tc P65 Gt30 65"" Class 3...
I have a LG 42LC5CAUS, when I turn on my set there is no sound, sometimes if I turn the set off and back on I will get sound. It has gotten worse and now I have to reboot to get the sound on and the remote...
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where, if otherwise, Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hoping this will help to solve the problem....
Aug 25, 2011 | LG Televison & Video
It wont turn on at all
Good day to mam wendy311!!!!
If you TV is totally dead set and no red light or green light on the front...
if that so the problem could be cause of dead set power power supply board...
You have 3 choices its either repair it on your own or took it to the technician or buy a new set of power supply board..
But for me I suggest to buy a new power supply board because if you took it to the technician cost of repair is almost or higher depends on the bad parts than the new power supply board...
But before you buy a new PSU please check this simple and common parts that usually cause of dead power supply board..
  1. Transistor----Check if shorted
  2. Capacitors----Check if bulged or leak.
  3. Resistors----Check if open or change value..
  4. Fuses---------Check if busted..
I hope this solution will be helpful..
Thanks for using fixya...
Aug 12, 2011 | Apex Digital LD4088 LCD TV
Set clicks off unexpectedly. On a reboot works for a while then clicks off again. Light flashes 6 times - glows - then goes out. Set three months old and has been working ok. Comet purchase
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where,if otherwise power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this one will helpout....
Aug 06, 2011 | Sharp Televison & Video
Hi I have an LG 32lx28ZE television, excellent up till last weekend when it just died, power in is ok, but will not power up, think its the power supply board, is there anything else I should do before I...
Your power supply board is dead, do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will solve the problem and do take care in handling the set because it contain high voltage......
May 31, 2011 | LG Televison & Video
Sony kv32v15 is dead with no sounds are lights. How difficult is it to replace the power supply / power management components?
since the problem is dead set all you need is open the back cover to trouble shoot, use digital tester. check blown fuse and then power on the unit check the output voltage at power supply panel board which supply the main CRT chassis board. if no output voltage check open fusible resistor its about .1 ohm, then check shorted rectifier diode and transistor sometimes cause by voltage fluctuation. just consider also the horizontal out put transistor it might be shorted cause by over current coming from power supply.
Apr 17, 2011 | Televison & Video
Sanyo tv ic no la76931a57v9 set goes stand by after few seconds at the power supply ok.
Your power supply board is not yet dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem........
Dec 15, 2010 | Televison & Video
Dead set.... Will not turn on when i push the power....
Check the power source?Yes,than the power supply board is dead.Tries websites like Dhopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jun 17, 2010 | Philips 32PFL5332D 32 in. LCD Television
Set won't turn on. has a buzzing soune
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com for a refurbish power supply board.
Feb 20, 2010 | Toshiba MW26G71 26 in. TV/VCR/DVD Combo
The green led blinks 12times. local repair guy guy said somthing about taking out the y.
Power LED blinking it about 90% power supply board is dead.The other 5% are both boards some time are dead.The power supply board and the Tuner siginal board is dead.Replaced the power supply board it ur best bet to get power back.After power is back should get picture too.Not than the Tuner board also need it replaced.Tries Websites Shopjimmy.com,Ebay.com for boards parts.
Feb 16, 2010 | Sanyo DP42746 42 in. Plasma Television
Protron PLTV-32 Television Logo
88 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
