Question about HP Photosmart 320 Digital Camera
My camera suddenly stopped working,inspite of placing new battery cells.On switching the indicator red light glows once &stops
  • HP Master
  • 17,130 Answers
Check if the battery is having the right voltage, if it is rechargeble type , then recharge the new cells before being used the first time.
If the battery was charged then it is possible that the camera has problems in the controller board.
In ssuch case contact HP than to tamper upon as it is not a DIY job.
Posted on Sep 14, 2010
The remote has stopped working for my DP 300 DVD player. I changed the batteries, and I have operated another remote successfully with the new batteries, so it is not the batteries
Try to check the battery terminal the one that is connected into the pcb it might be loosed. sometimes the lead that holds the battery terminal is not properly connected. or try to check the led sensor the one that looks like a bulb, in order to check it you must have a cellphone with a camera then point the sensor into your camera lens then press any button you will see in your cellphone monitor that there is a red light glowing that indicates that the remote is in good condition.
Jul 09, 2011 | Norcent Technologies DP300 DVD Player
My remote wont work,tryed new batteries its for a lcd tv,dvd player
Try to check the battery terminal specially the one that is connected in the pcb, Then if you have a cellphone with a camera try to point the led sensor in to the camera lens then try to push any buttons and look at the monitor of the cellphone if you see a red light that glows it is indicating that your remote is in good condition, if there is no glowing red light it is indicating that your remote sensor is defective try to replace it but observe the polarity.
Jun 10, 2011 | Televison & Video
I mistakely deleted pictures from my camera (Kodax Esay Share M340) Move picture to internal memory.How can i get the pictures back
If Try one or more of the following
Ready light does not turn on and the camera does not work.
Ready light blinks green.
  • Camera is operating normally.
Ready light blinks amber.
  • Wait. Resume picture taking when the light stops blinking and turns green.
Ready light blinks red and camera turns off.
Ready light glows steady red.
Ready light is off or glows steady green.
Mar 10, 2011 | Kodak Cameras
My humidifier all of a sudden just stopped working. Can you tell me of any common issues and their remedies for this humidifier ?
From the troubleshooting section of the manual (http://www.crane-usa.com/manuals/HumidifierManual2008.pdf):
Problem Humidifier power light is staying red and not turning green Humidifier is working than stops: ? Solution Ensure that water level sensor is assembled properly. ? Clean water float ? Call service center and request replacement water float ? If humidifier does not work at all: ? Ensure it is properly plugged into a power outlet. ? Check that the switch is in the ON position. ? If Power On indicator light does not come on, bring to authorized service station.
Nov 01, 2010 | Crane Frog EE-3191 1 Gallon Humidifier
My camera has stopped taking photos.
Please check your batteries. If they are rechargable it's possible they are losing their abilility to store electricity and if you use Alkaline then I'd advise switching to NIMH rechargeables or place a brand new set of High Output Alkalines in the camera.
Quite often low batteries can have enough power to switch on and light up but just don't have enough to fire or even charge the flash if it's switched on. Or to focus and take the picture. Batteries are the digital cameras biggest problem maker. It's the first thing I always go for because of this and also it's the cheapest repair if they are faulty. Even if you do use rechargables it's possible for one cell to suddenly die and that stops the other cells from doing their job. Obviously, in your case some power is getting through but check them anyway with a known good set.
If your fresh batteries don't do the trick then it looks like you will have to call into your local service agent. Obviously if your camera is under warranty it will be covered by the manufacturer and you can take it back to the place of purchase. Just remember to take you purchase receipt with you.
Good luck.
Apr 23, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Hot Point stove oven and broiler won't turn on
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Aug 16, 2009 | Hotpoint RGB745 Gas Kitchen Range
Cookworks microwave not working
replace the fuse see if it blows again you can get those at radio shack 250 volt either 15 or 20 amp get 3 or 4 of em
Jul 29, 2009 | Microwave Ovens
Harging problems
use canned air to blow out connections on camera and dock.
this problem is due to bad connection
Apr 23, 2009 | Kodak EasyShare Z760 Digital Camera
HP Photosmart 320 Digital Camera Logo
32 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
