Question about Qca Spas Dream Series Dream Master Hot Tub with Flex Cover
WHAT DOSE OH MEAN - Qca Spas Dream Series Dream Master Hot Tub with Flex Cover
  • 310 Answers
Over Heat. This unit probably has a 24 hour circlation pump that is clogged or lagging. Clean or replace pump.
Notes:
This could also be a bad temperature sensor on the heater control box.
Posted on Oct 27, 2010
Hi just wondering how u caliberate a esspresso shot on a La Cimbali M23 machine. all heads only run for half of a second.
* You will need to program dosing on each group head.
* I'm surprised I did not record and upload a programing video *sigh*
Oh well, somebody did it already:(check at 3:57 on the following vid)
https://www.youtube.com/watch?v=0-3SbS-PU4Y
* Set up each shot with a filled portafilter (for the appropriate dose setting. Single for single, double for double, etc.)
* Press and hold "Stop" button till it light (and/or beeps). Release stop button
* press and HOLD the appropriate dose button (within 5 seconds or it cancels out)
* Watch the coffee dose as it pours out into cup or a shot glass (for accuracy)
* Release the dose button just before it hits the desired amount. You may have to do this several times to practice.
* Continue with setting the dose on the other settings (long, double, etc.)
* Note; you can set the "least used group" as in a 3 or 4 group head machine with specialty doses. Like a triple if you have the proper portafilter for this shot. Or an "American" long shot (though I don't recommend running 6-8 oz of water through a single coffee dose. Though I have found some shops using drip coffee through a triple basket and very long dose to fill mugs. They didn't want to get a regular 12 cup brewer.)
* There are other dosing tricks like copy over to other groups. But I've found that setting each group and dose is good practice. (and I have to do it several times a day as a Espresso Tech.)
Aloha, ukeboy57
Jul 31, 2016 | La Cimbali Coffee Makers & Espresso...
P0500 code what dose it mean
check the wires at the speed sensor, depending on what unit you have its usually on bottom of rear transmission. I just replaced mine, must have been a stick that hit it and broke the plug.
Sep 02, 2014 | Arctic Cat 2013 Prowler 700 HDX
My gas gauge in 1995 ford does not work
I have the same problem with my gas Gage I tried the full pump and the sending unit Idk what else to do. Oh and can someone tell me where in the hell is the speed cable or dose it have a sensor. Oh and its a 95 Ford
Oct 21, 2012 | 1995 Ford F150 Styleside Regular Cab
Error 5 what dose it mean
(Condensed from the iRobot site...) "Uh Oh Error 5" or "Uh Oh" and 5 beeps means Roomba's Side Wheel is stuck. Pick up Roomba and with Roomba right side up, push the side wheel up and down a few times to clear debris. Manually rotate the side wheels to clear debris. Blow air through the side wheel pockets (or vacuum them with an upholstery tool on a traditional vacuum) to clear debris. If this doesn't clear the obstruction, then contact iRobot customer support.
Jul 02, 2012 | iRobot Roomba 560 Robotic Vacuum
Blue screen & A message pop-up on my ToshibaSatellite A105-S4011:
try removing some unwanted programs. run disk cleanup, then defrag
Apr 04, 2010 | Toshiba Satellite A105-S4011 Notebook
When it says LINE ERROR what dose this mean
That indicates that there is static or interference on the phone line. You will need to call your phone service provider for them to test the line.
Feb 11, 2010 | Office Equipment & Supplies
My washer say LG what dose that mean
My washer stopped and displayed the LE error code. I turned off the power button and tried again, but after a few seconds it want back to LE. Finally, I unplugged the power cord, plugged it back in, and the washer ran normally.
Dec 21, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Wat dose it mean when your battery sign on ur sk is a thermometer
means your battery has gotten to hot to charge, take if off the charger for a few and try again.
Jun 09, 2009 | T-Mobile Sidekick® 3 Cellular Phone
It sux!! BLACK screen when we can see the picture
Try another scart cable if this dose not work take it back "no return"deal or not.The player was sold to you as a dvd player not a paper weight.
Hope this helps.
CABLE GUY.
Apr 18, 2009 | Denon AVR-3802 Receiver
Qca Spas Dream Series Dream Master Hot Tub with Flex Cover Logo
99 people viewed this question
Top Qca Spas Pool & Spa Experts
john h
Ian Summerfield
Ian Summerfield
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
