Question about Brother MFC-7420 Printer
How to check page count on "BROTHER-MFC 7420"
SOURCE: Refill toner Brother MFC 7420
open front cover, press OPTION button, on the LCD will appear a message "NEW DRUM?" ....DO NOT RESPOND....just type on the keyboard "*00" and there will appear a message "Accepted" and use it in your pleasure.
PS. in any case i blocked with paper labels the viewing windows from transparent plastic on the toner itself....
Mr. Brother, do not try to be smarter than your customer
Posted on Jul 17, 2008
SOURCE: I can't find the back door sensor on Brother MFC-7420
I have the answer. I just fixed mine. The sensor is not really on the door. You have to remove the door by openning it all the way and carefully sliding it out ( one of the pegs holding the door is hourglass shaped. This will slide out first. The other is round. You will see a black flap that covers a red drum. Pull the flap down carefully. There will be a six inch long rod it's about 1/8 of an inch in diameter. It extends from the middle of the flap all the way to the right side. This probably popped out of place. Make sure that it is all the way to the right as this is where the sensor is. There is a little spring on the bar on the left side. This should be straight up and down. if it is not, then you need to fiddle with the bar.
The trick was that the sensor is NOT on the door, but on this inner flap. When the door closes it pushes this flap agains the drum and the little bar activates the sensor.
Please do not applaud so loud, you are ambarrazing me!!! hehehe. Good luck!.
Posted on Aug 11, 2008
jtuminaro
  • 56 Answers
SOURCE: BROTHER MFC 7420 PRINTER SOLID VERTICAL LINE...
Open te lid and look at the glass. You have dirt or white-out or something on the thin strip of glass to the left. Clean that glass!
Posted on Jan 15, 2009
  • 320 Answers
SOURCE: error 2001 on brother mfc 7420
please tell me more! i just checked my brother manual and i do not see a error code 2001????????????
Posted on Feb 16, 2009
leroyal
  • 2120 Answers
SOURCE: mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Posted on Mar 10, 2009
HOW DO I un-lock the scanner on a Brother MFC 7420?
Unfortunately, the MFC-7420 doesn't have a physical lock switch. You need to turn off the all-in-one and wait for the unit to clear its memory. If the error recurs after you press the power button again, wait 30 minutes and try again. (Note: you will lose any faxes that are in memory. See the User Guide page 11-5 to save this information.) You can find the manual on the Brother support page for the MFC-7420: https://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=MFC7420 . Click on the Manuals & Documents tab. Then click on the Manuals on our Online Solution Center for the English version of the manual. The direct link to the User Guide is currently: http://download.brother.com/welcome/doc000387/ALLFB_UsaEngUsr_B.pdf .
You can also try unplugging the all-in-one for several minutes to reset the error codes. If the error persists, contact Brother if the MFC-7420 is still under warranty (1 year). If it isn't under warranty, consider replacing the unit. The repair costs may be unreasonable.
I hope this helps.
Jan 09, 2017 | Brother MFC-7420 Printer
MFC 7420 CONTROL CENTER FOR WINDOWS 8
Go To Below official Brother Printer Page For Your problem, MFC 6490CW Others Brother Solutions Center Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Brother Printer Support
Apr 01, 2014 | Brother MFC 7420 All-In-One Laser Printer
Drive hp brother 7420 for win 7
If you are searching for drivers i.e. Multifunctional Brother 7420 model, check out this LINK.
On the link Page " Brother Models compatibility between Windows® 7", scroll to the "MFC Model" scroll down to "MFC-7420" & click on "Download" to get the Win 7 driver for your Printer.
Hope it helps.
Jun 15, 2011 | Office Equipment & Supplies
How to Reset Factory Brother 7420 like page counter/copy/fax Thanks
plz solve my problem ,how to re set page count forbrother 7420 machine
Jan 19, 2011 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 change drum soon light, did, still says change drum soon, how do I rest the drum, I cannot find my manual. Tks
Simply open the front cover.
Press the Options key on the control panel.
The display will show "REPLACE DRUM - 1.YES 2.NO".
Press 1 to reset the drum count.
Close the front cover.
This procedure wil work on the majority of the Brother MFC series of laser based Printer Scanner Fax Facsimile machines.
Good Luck and Thank You for using Fixya
WheatlandServices
Nov 05, 2010 | Brother MFC-7420 Printer
Scanning images onto mac
The scanner driver is separate from the printer driver. This link will take you to the downloads page of Brother-usa.com, where you select the machine family, then the specific model. Click the downloads link at the bottom, then, and you'll get to a page to select what you want and for what OS. Brother lists Mac os's from 9.x to 10.6.
Even if you have a driver on CD, the website usually has a newer version.
Jan 21, 2010 | Brother MFC 7420 All-In-One Laser Printer
Cleaning blade did not work
error code c00f0401 of my hp officejet v40 printer
Jan 07, 2010 | Brother MFC 7420 All-In-One Laser Printer
Mfc-7420 Black Line horizontal across paper in 3 places
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
Oct 07, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7420
I need to down load driver for Brother MFC-7420
Sep 03, 2007 | Brother MFC 7420 All-In-One Laser Printer
Open Questions:
See all Brother MFC-7420 Printer Questions
Brother MFC-7420 Printer Logo
216 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
