Question about Directv RC-64 Remote Control
Remote beeps when I hit a button more than once (like hit down twice after hitting guide). I need to pause a few seconds before hitting the next button or the TV beeps. Replaced the battery and fixed the issue. But after couple days problem comes back. Replaced batteries again and once again solved for couple days before happened again.
2 Suggested Answers
SOURCE: I enter my code... it blinks twice to show acceptance of code... but then does not work
IF the codes in the book do not work go on line for new codes www. directv.com
the book I got with my remote has copyright date of 2006
Posted on Jan 07, 2009
3 remotes and two of them are number 2 and conflict
Hello, Daniel Busa here with Dish Network's customer service department. What you need to do is reprogram one of your number two remotes, to do this:
1.take Your tv2 remote to tv1
2.hit menu twice on the number 1 remote you'll see the sys. info. screen at the bottom it will say secondary remote address you want to change this.
3.hold down the "sat" button for 4 seconds and hit any number between 1-15 then hit the # key once, and than record 3 times.
The secondary remote address should now be a different number and it all should work.
Dec 11, 2010 | DISH Network IR Remote Control
How do I access the service menu on a lifefitness 9500HR treadmill?
To get to the service menu start by pressing the pause button and keep it held down as you hit the clear button twice. The treadmill will reset and go into the service menu, and now you quite pressing the pause button.
Mar 31, 2010 | Life Fitness 9500HR Next Generation...
How to program 1997 Maxima remote
Try this it works for the 95 and 96 models it should also work for all models 95 thru 99. 1st you need to get in the car and hit the lock button on the drivers door switch. Make sure doors and windows are all shut. To program the remote you must insert the key into the ignition 6 to 8 times rapidly in a 10 second time period and when you have done it correct the hazards lights will then illuminate twice. Next then you must hit the lock button quickly on the remote due to a slight time delay only hit the button once. Keep repeating this step until it works and to find out if it worked hold down the trunk button or the unlock button(the front windows should let down on you Mad-Max.
May 24, 2009 | 1997 Nissan Maxima
How to reprogram Sears Mult-Function Keyless Entry garage opener
On the garage opener that actually opens the door the one on the ceilling has a green or orange button that is called the learn button just press and release it you have 30 seconds to punch in a 4 digit code and when your done press and hold the enter button until the lights on the garage open blink once or twice then just press the code again and it will open the door press enter once to reverse the effect and and twice to stop the door completely.
Hope that helps
Jan 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Unable to set clock
hit shift and clock (9) on your remote.
use the left double arrow and right double arrow buttons on the bottom to change the time...note: once you hit the shift and clock buttons, you have only 4 seconds to press another button...
once you have the time set, you can hit the pause button on the lower section to finish.
Dec 04, 2007 | Aiwa NSX-AJ200 Shelf System
Remote does not work
Do the buttons on the front panel of the unit work?
If so, try doing this:
Hit the tivo button, go down to messages and setup and into to system information. Go down a few screens until you see remote code. Hold (on your remote) the tivo button and pause button for about 5 seconds. Then hit 0-9 on your remote to set the code. It's a single digit code only. You'll see your remote light flash. Now, try hitting the back button and see if your remote works. If it does, great. If it doesn't that means one or more of the following:
1) Your remote is defective
2) Your IR receiver on the unit isn't working correctly.
If #2 is the problem, you'll need to open up the unit, powered down! and make sure the thin, greyish ribbon cable in the front of the motherboard is 100% in. If it's not all the way in, it will cause issues.
Nov 20, 2007 | Hughes SD-DVR80 DirecTV / TiVo DTV...
JENSON vm9312 Video Bypass
check this out man, go to fm/am mode. with the remote hit the setup botton. then enter 543210 and be sure it beeps on every diget. then hit the hammer/screwdriver icon and turn the parking brake "on"
Oct 09, 2007 | Audiovox Jensen In-Dash DVD/CD Receiver w/...
Directv RC-64 Remote Control Logo
165 people viewed this question
Top Directv Televison & Video Experts
john milligan
rundiggity
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
