Question about Kenmore Dishwashers
Leaking suds out the bottom and no draining of water
    Scholar:
  • 150 Answers
Did you recently install a garbage disposal? suds coming out is from too much soap or hand soap making suda which come out over the tub. the no drain is from a blockage or bad pump or divereter depending on model
Posted on May 15, 2008
Frigidaire dishwasher leak
run it with no soap. if you get no leaks then cut back on your soap. you may need to run washer a few cycles to get rid of excess soap.
Sep 02, 2012 | Frigidaire Dishwashers
Wrong dishwashing liquid used created out of control suds won't finish cycle. cleaned away suds towel and wet vac but foes not work
HI- Ah yes, the suds. Your flood switch has probably been tripped. Unplug the machine or flip the breaker. Remove the lower kick panel and you'll see the white plastic bottom of the dishwasher pan. This is designed to catch the water (or suds) if there is a leak or the water (or suds) over fill it. This will take awhile but get some pliable rag and carefully put it in the space between the bottom of the dishwasher and the pan. There is a styrofoam float on the left side about halfway back, this has to be down for the dishwasher to advance the cycle and get out of drain mode. Just keep soaking the water up (you kinda have to go over the plastic lip of the pan and down wherever there is an opening large enough to get the rag into. Once it is pretty dry it should run ok. Regarding the suds. If you get the machine to run ok then start a rinse cycle and once the water is done filling open the door and add about 4 tablespoons of any cooking oil to the water. Shut the door and let the machine run for about 10 seconds, open the door check to see if there are still a lot of suds, if so cancel the cycle to drain the machine and repeat. Hope this helps, good luck.
Sep 24, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Water and suds leaking
if you have any suds your either using too much soap or the wrong kind. does the washer drain all the water out each time? is this a new machine where you're washing your clothes in it for the first time? I've seen clothes with resisual soap in them causing over sudsing.
May 20, 2010 | LG WM2487H Front Load Washer
I have an electrolux front loading washing machine it is leaking water at the bottom and produces chunks of melted plastic during the cycle
Hello. If water is leaking from your washer, check the list below:
  • Is the drain clogged? If you have a clogged drain, it will need to be cleaned – contact a local plumber if necessary.
  • Is the drain hose restricted, or out of the standpipe? If the drain hose is out of the standpipe, you’ll need to secure it. You can do this by bending the end to form a hook, placing the hooked end into the standpipe, and tying the hose to the standpipe or a faucet with a cable tie (one was supplied with the washer), strong filament tape, or duct tape.
  • Are the fill hose connections loose at the faucet or washer? Check them and tighten the hose connections. If they’re loose, you might need to install or replace the rubber sealing washers.
  • Are you using a high-sudsing detergent or is your water soft? Using a high-sudsing detergent, or using too much detergent in soft water, can cause suds to overflow the washer. This may seem like a leak if the suds flow or drip onto the floor. Use a low-sudsing detergent and reduce the amount of detergent you use if your water is soft.
Apr 22, 2010 | HP DVD DRIVE DVD Drive
Dish washer is leaking soap suds from bottom of door and doesnt seem to want to drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Jan 09, 2010 | GE 24 in. Profile PDW7800 Built-in...
Water leaking from bottom, lots of suds.
Hi
Thanks for using FixYa. This may happen due one or more than one of these issues with your washer--
Probably there is something(coins, socks, dirt, debris, etc) stuck inside the drain filter of your washer. You'll need to check the drain filter. To access the drain filter. To check the drain pump follow these steps:
Unplug the washer to completely disconnect electrical power.Remove the bottom front service panel as shown in the first image below.
Also check your drain hose for a kink or clog. Check the washer house drain for a clog or restriction. Test the washer to see if it will drain properly.
This issue can also be due to clogged drain pump or drain filter, due to which the hose have developed leak. This will cause suds
Please rate the solution if you find it useful and helpful.
Thanks
Rylee
Sep 22, 2009 | GE Washing Machines
GE dishwaher leaks with standing water in bottom
Check to make sure regular dish soap did not end up getting inside the dishwasher. This will create a lot of suds that will overflow onto the kitchen floor. Standing water from not draining can mean the drain hose is clogged somewhere or the check valve has something caught in it. If you remove the front kick plate, you will be able to check those.
http://tclaundryrepair.com/
Feb 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
After adding Jet Dry to the dispenser my dishwasher started to leak water and suds from the bottom of the door. I now will not drain completly.
BE Sure you are not using detergent that has the softener/rinse agent already included. The electrasol 3in 1 tablets will cause an over abundance of suds if you use the two together. The water becomes very soft. You have locked up the pump with suds.
use 1/2cup salt to flush followed by 1/4c oil.
Thanks
Mar 06, 2008 | Dishwashers
Suds and water staying in Whirlpool Quiet Partner III
I believe you may be over sudsing, Try a few cycles with vinegar and no soap. Do not use dishwashing soap at any time ever. See if the vinegar trick helps...helijm
Dec 01, 2007 | Dishwashers
Dishwashers Logo
102 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
