Question about Antec SP-400 400-Watt Power Supply
My power supply Model SP-400 died not working at all. What should i do now.
    Master:
  • 752 Answers
Replace ?
Posted on Dec 25, 2014
2 Suggested Answers
pravinbhavsa
  • 348 Answers
SOURCE: My computer just died the morning. I removed the
red- +5v
yellow- +12v
orange - +3.3
black- 0v
blue- -12v
white - -5v
green - ps-on(+5v)
gray- power good(+5v)
purple- stand by (+5v)
disconnect smps from motherboard give the power to smps and short green and black wires and measure the above voltages
Posted on Mar 21, 2010
Turn on the computer nothing happen then smell burning from the power supply! turned off right away.
That power supply is probably dead. try your motherboard witha known-to-be-good power supply to determine if your system has survived. IN my experience the failrate for antec sp450 watt psu is close to 40% over 4 years (300 pc:s at university), so there is a high probability that your psu is unrecoverable.
Feb 13, 2011 | Antec SP-400 400-Watt Power Supply
Ricoh 2045 copier toner does not. shows continuous empty.
this problem comes when TD Sensor fails or toner supply motor fails or defective toner which is not support to this model or ID Sensor fails, if you feel all the above sed things are good condition please follow the procedur first go to SP mode and cleare the memory and set to SP-2-201 to 1 image pixcel mode adn set the SP-2-209 make it 90 ok (Note: After memory all cleare you have to excute the 400 & 600 dpi Initial Setting)
Dec 15, 2010 | Office Equipment & Supplies
My Samsung SP-R4232 has some type of power supply issue. I called a tech who came out and verified it. He thought it was the main power board, but wanted $400 to fix it when I found the part online for...
U replaced the tv power supply board,the board u replaced,that is the board where the power a/c cord plug into it?Check ur old power supply board,examines all parts,see if u have any capactors parts are bulging or puffing up on it tops.Yes,than it is power supply board issue.But by replacing the power supply board only get 50/50 chances for the tv to work.Might be the problems,might not be the power supply board issue alone some times.The chances are tv Tuner signal board is dead also.That the board,where the tv incomming broadcasting signal cable plug into it.Try website like Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Dec 04, 2010 | Samsung SP-R4232 42 in. Plasma HDTV
Fan in power supply not working, computer powers up but no video display. Tried a different graphics card same result. It is possible that the power supply is not providing power to the adapter card
If the fan in the power supply is not running it might be due to old age and dirt and lint keeping it from turning. In almost every case I just replace the fan in the power supply and every thing is ok. If the power supply doesn't keep cool it will shut down on thermal overload.
Sep 13, 2010 | Antec SP-400 400-Watt Power Supply
The power supply on my gateway pc died on me ,i replaced the power supply with a dynex 400 watt power supply ,now my pc won't boot up
i had a bad on right from the box recently. could be a compatability issue as well. try another power supply, the cheaper generic ones work best
Sep 04, 2010 | Computers & Internet
red- +5v
yellow- +12v
orange - +3.3
black- 0v
blue- -12v
white - -5v
green - ps-on(+5v)
Mar 19, 2010 | Antec SmartPower 2 SP400 400-Watt Power...
I get no power at all to my computor. There is
The easiest and safest way is to purchase a power supply tester. Just unplug the power supply wireing harness from the motherboard and plug it into the tester. It gives led readouts. Its around five dollars. or just simply take it to a computer shop, most will check that for free
Aug 31, 2009 | Antec SP-400 400-Watt Power Supply
Will power for bios but restarts at windows xp screen
Try to check for memory modules.Remove memory and then reseat.Also try 1 memory at a time.
Aug 17, 2009 | Computers & Internet
Plugged computer back in after move and won't start. green light in mb on.
pls try change the power cable if it works then check your power pack if the FAN doesn't roll that means you have to change the power pack thanks. abass_october@yahoo.com
May 24, 2008 | Computers & Internet
Antec SP-400 400-Watt Power Supply Logo
Top Antec Computers & Internet Experts
Dimitar Todorov
Julie Endres
Wahs Team
Are you an Antec Computer and Internet Expert? Answer questions, earn points and help others
