Question about Kenwood KDC-135 CD Player
DCER error (people spell it "ocer"
The error is flashing, nothing worked to fix it. I cut back all of the speaker wires, reset the unit and it still comes up
  • colfels Apr 09, 2009
    was riding along and everything was fine. Stereo stopped playing and has a constant OCER message. What can I do to fix it? Is there a reset button maybe?
  • 132 Answers
Problem is the internal amp chip, if it was a speaker problem or shory they flash Protect.
OCER oe DCER is the amp chip Part #KKZ10 REF# ic5
Posted on Jul 25, 2008
  • Mohd Rizal Jemain
    Mohd Rizal Jemain Feb 25, 2016
    i have a same problem, but i'm fixing another way.. takeout all cabel from device than disamble unit.. i found surprisely.. a coin in the unit.. after asemble agin, my unit come to play normally..
I have model kdc-138 & it show "ocer" on the screen & nothing works-radio or cd player...help???
Please check this message. If it is DCER, not OCER, you have a short-circuit in the speaker wiring or a wire is touching the vehicle chassis. Until the wire is fixed (insulated or replaced), the receiver will remain in the Protection mode. This keeps the short from permanently damaging the unit. After you insulate all of the wires, press the RESET button, to the left of and below the volume knob.
If the error persists, then you need to have the receiver professionally serviced. The short is probably inside the receiver itself.
I hope this helps. The troubleshooting guide is on page 18 of the manual. It is available from Kenwood here: http://manual.kenwood.com/files/B64-3898-00_00_KW.pdf . The image of the reset button position is on page 3.
Sep 17, 2015 | Kenwood Car Audio & Video
My system just stop working and its only blinking ocer
OCER indicates that the unitis in protect mode. First press the reset button (tiny pinhole button). If the unit comes back on saying OCER then most likely there is a short or a grounding problem with the speakers or speaker wiring. Disconnect all speakers and press reset again. If OCER still shows up the unit needs service. If not, connect each speaker once at a time until the unit comes back in OCER to narrow down the location of the unwanted DC signal.
Apr 02, 2010 | Kenwood KDC-MP235 CD Player
Turn it on in it says ocer
Here's the Manual for your KDC-138 deck...
http://kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/kdcmp238.pdf
On Page 18 it describes the error that you're seeing... let me re-type it here:
PROTECT / DCER: The speaker wire has a short-circuit or touches the chassis of the vehicle, and then the protection function is activated.
-- Wire or insulate the speaker cable properly and press the reset button
I found on Page 3, the reset button is located just below and to the left of the volume knob...
I hope that helps.
Mar 24, 2010 | Kenwood KDC-138 FM / AM Receiver
Error message on screen will not go away
Hello bigdsketch,
The "DCER" error is caused by one of the speaker wires shorted or grounded or a shorted voice coil. Remove the speaker wiring one at a time to determine which one is causing the error, then repair or replace the defective part.
You may need to press the reset button (small recessed button to the lower right of the volume control) after the problem is corrected.
Hope this helps.
Aug 15, 2009 | Kenwood KDC-135 CD Player
I turn on the radio and OCER is shown in the faceplate and it doesn't do anything else.
Hello miguel200819,
The "PROTECT/DCER" error is caused whenever a speaker wire is shorted or grounded by contact with the vehicle frame. Locate and repair the shorted/grounded wire or run a new one and then "reset" the receiver by pressing the reset button to the lower left of the volume control. If this does not work, the receiver is faulty and needs to be serviced.
Hope this helps.
May 20, 2009 | Kenwood KDC-138 FM / AM Receiver
Kenwood KDC-138 Operation Problem
Here's the quote from the manual regarding "dcer": "The speaker wire has a short-circuit or touches the chassis of the vehicle and then the protection function is activated. Wire or insulate the speaker cable properly and press the reset button. If the "PROTECT/DCER" code does not disappear, consult your nearest service center "
I believe the manual can be downloaded from crutchfield .com after you go to the Kenwood KDC-138 page on their website. The reset button is either on the lower left of the face or, removing the face, on the lower left of the body. Hope this helps you.
Jul 24, 2008 | Kenwood KDC-138 FM / AM Receiver
DCER error
the amp chip had died, service time
May 16, 2008 | Kenwood KDC-135 CD Player
DCER error
Every 1 of those i have gotten in service here the amp chip #KKZ10 REF# ic5
May 14, 2008 | Kenwood KDC-135 CD Player
OCER
ok, there is a default button right next to the SRC button on the face of the radio. take a pen or small srew driver and point the little button (it looks like a hole) hold it for about 10 secs and it should reset. when ocer flashes on the screen, this means that one of your speakers is either trying to go bad or is bad. keep ur volume low if u have factory speakers
Oct 17, 2007 | Kenwood KDC-135 CD Player
Kenwood KDC-135 CD Player Logo
1,528 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
