Question about Motorola Televison & Video
Ref: Motorola DCH3200 Problem with channel input. When I enter three digit input, the response is painfully slow and the result is a wrong channel. For instance, when I enter 702 on the remote control, the receiver does not record 02 after 7 and plays channel 7. need help.
Unplug the comcast digital box and wait 20 seconds or so, then plug it back it. I had the same problem and was given this solution and it worked. NOTE: the program guide will require at least 24 hours to "fill up" again. I was told that the problem is that the cpu in the digital box gets overloaded and needs to be rebooted/reset.
Hope this works for you
Posted on Oct 18, 2010
  • AndyB May 22, 2011
    Thanks, Daphne99....Thought the batteries in the remote were dying (until I saw that cursor/navigator on the box itself exhibited the same glacial rate when changing channels (as well as tantrys' problem of not being able to punch in a 3 digit channel)...Motorola's installation- and user guides are not much help in their section on troubleshooting...Hey, you saved me the trouble of calling Comcast.....I'm happy to say that, at least in my case, the program guide "refilled up" within about 10 minutes rather than 24+ hours. Thanks again.
    A quick follow-up....Afraid I have to backtrack on the "fill up" time......Did the reset 5/22/11 around 5:40 PM, saw programming available on MOST channels, but only up to 10PM, after which programs are "to be announced", and couldn't scroll past 11PM....Guess I gotta be patient.
Where is the serial number on Motorola dch3200?
MAC I D but I would use chat and they should help.
Mark
Motorola support
Jun 15, 2014 | Arris SURFboard SBG900 802.11g/b...
Missing user guide for DCH3200 hi def receiver
IF this is the Motorola DCH3200 HD Set-top you can get a download manual from;
http://www.generalmanual.com/TV-Tuners/Motorola-DCH3200-HD-Set-top.htm
If not you will have to supply more information.
Feb 14, 2011 | Televison & Video
How do I get to channels above channel 99? I have a small GE television model 09GP110. It autoprogrammed the higher number channels but I still only have 2 spaces for channel number.
For GE televisions, press and hold the "1" button on the remote. The input display in the upper right corner will change from two-digit mode ("1 -") to three-digit mode ("1 - -"). You can then enter the final two digits for the channel you want.
May 05, 2010 | GE Televison & Video
Comcast remote: all of a sudden channel input is slow
Unplug the cable box from the wall socket, wait a few seconds, and then plug it in again. I've heard that this solution works.
Feb 28, 2010 | Televison & Video
Red light flashing.set will not start up.
When the TV does this, the RED LED on the front will blink. For digits 1-10 it will blink pause then repeat. For numbers with 2 digits it will blink the first digit slow and then second digit fast. So 25 would be 2 slow blinks followed by 5 fast blinks.
Error Description Error/Prot Detected by Device Defective module Result
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
14 Supply Class D amplifiers
14 Supply Audio part SSB
17 MPIF1 audio supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
43 Hi Rate Front End
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Dec 06, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
Motorola DCH3200 cable box: sound and sometimes video cutting out
Sounds like your SNR is getting too high and causing the signal to overload. A few things can cause this a bad splitter that causes the signal to bleed and introduces noise, or a more common issue is having a weak signal coming from the cable provider and once it goes through a splitter it causes the signal to become to weak to be stable.
Since it sounds like your cable has been working up until recently, you may have had a cable or splitter go bad.
Call comcast and have a technician come out and test the line.
Sep 11, 2009 | Motorola Televison & Video
Recording HD channels
well you would need to hook up cable box to dvd recorder. the only draw back first off is one you cannot get hd onto a dvd. you can down scale and it will seem a little cleaner than standard def but of coarse it will never be high def. I'm not to familiar with the motorola boxes but if they offer dvr's in your area i would suggestgetting one you can record all channels then afterwards transfer them to a outside device. but as i said before high def cannot fit onto a dvd unless you plan to copy one movie to 6-7 disc. Just keep in mind a standard high def channelcan only fit 2 max on one freq due to the amount of data transfer as opposed to 10 to 12 standard def digital channels
May 08, 2009 | Televison & Video
Need subsidy password for motorola T720
contact customer service. that means u have inputted the wrong sim pin too many times.
Apr 29, 2008 | Cell Phones
Motorola DCH3200 Cable Box
Be sure that you took the time to force the output of the DCH3200 to 1080i. They do not seem to come set that way by default! This is true whether you are using either the component or HDMI output.
Power OFF the unit and immediately push the Menu key on the front panel. Using the remote, be sure that the 2nd line of the config is set to 1080i and not something less.
Mar 27, 2008 | Sony KP-57WS500 57" Rear Projection...
Wrong or 3-Digit Channel Numbers
that request is not available...firm-wared chip proprietary from orion
Jun 01, 2007 | Orion STV2763 27" TV
Televison & Video Logo
862 people viewed this question
Top Motorola Televison & Video Experts
Jaime Hernandez
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Motorola Televison and Video Expert? Answer questions, earn points and help others
